Reasonably Priced 100A Motor Controllers
Discussion in 'Motor actuators and drivers' started by Richard Ortengren, Jan 29, 2023.
Tags:
  1. Nicki9knuckles
    Nicki9knuckles Active Member
    Web Developer
    818Coins
    Hi all, I have been using my motion rig without issue using IBT-2 controllers for a long time, but I have recently upgrated to a higher powered controller that I seen on this thread
    But I am having issues with it. The wiring diagram is for 2 motor controllers and I am trying to wire it up using only 1 motor. I have tried every combo of wiring i could based on this diagram but I am getting the same problem, my motor only moves in one direction when I turn on the sin wave in SMC3 utility.
    One thing to note is when I swap the positive and negative of the motor in the motor 1 part of this diagram I get the same one direction problem but its opposite.
    Another thing to note is that in the diagram it shows A1 and under that A2, but on the motor controller, its actually labeled the opposite. A1 and B1 are below A2 And B2. Which you can actually see is thje case in the product photo in the original post. Which makes me wonder if maybe the labeled A1 on my controller should be going to 3 on the arduino and labeled A2 on the controller should go to 2. I have tried both and i get the same reaction.
    For clarity,
    - I have my pot going to A0
    - Arduino 2 going to the A1 labled on the actual controller
    - Arduino 3 going to the A2 labled on the actual controller
    - Arduino 9 going to the PA labled on the actual controller
    Anyone have any suggestions?
    thanks!
  2. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,337Coins
    Did you update the code on your arduino ?
    The IBT-2 use MODE 2, but this board use MODE 1
    154,448Coins
    +11,181 / 57 / -2
    I don't use the controller so it is hard to follow your description without seeing the actual wiring.
    For example, is the Direction wiring as per the wiring diagram hooked up as depicted, Digital (PWM) 2-5?
  4. Nicki9knuckles
    Web Developer
    818Coins
    Oh I did not! I thought I read at the begining of this thread that the default mode worked for this controller. Awesome, I will give this a try @Wagnard thanks!
  5. Nicki9knuckles
    Web Developer
    818Coins
    @noorbeast It is except im only using half of the wiring becuase I am only connecting one motor. So 2-3 + 9. But I think its likly what @Wagnard mentioned
  6. Wagnard
    Wagnardsoft
    5,337Coins
    That's probably it. BTW default mode is 1, so you probably edited it when you used your IBT-2 at beginning.
  7. Nicki9knuckles
    Web Developer
    818Coins
    @Wagnard mode was exactly the problem, seems great now. thanks!!
  8. Pcon
    Pcon New Member
    - 76Coins
    I purchased 3 of these 2 months ago. Just hooking them up today & I'm only getting output from motor 1 on all 3 of them. Swapped the inputs from the arduino over, so it's getting a signal. Anyone else have this issue?
  9. Wagnard
    Wagnardsoft
    5,337Coins
    No, issue with mine, I get both motor working.
  10. 204flightsinmotion
    204flightsinmotion Member
    227Coins
    [​IMG] I saw this thread and decided to order the 100A board from Aliexpress for my motorcycle motion sim and it finally came in. I pulled out my ibt2 boards and wired this one in and opened smc3 with same settings and it shakes like crazy right away. I’ve been messing with the settings a bunch but can’t get it to stop shaking. I did reprogram the arduino to be Mode1 cause I read that here.
    Any advice on the settings on this 100A boards vs the Ibt2
    Attached photos of my ibt2 settings that I am were working before I switched to this new board.
    154,448Coins
    +11,181 / 57 / -2
    With new hardware redo the SMC3 setup from scratch: https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/
  12. Pcon
    Pcon New Member
    - 76Coins
    Thanks for the reply. I see that there are 2 different variations of the driver. Does yours have the led's at the terminal block end or on the side?
  13. Wagnard
    Wagnardsoft
    5,337Coins
    You need to refresh the arduino with the correct mode for this board. Ibt2 board is mode 2 and this one is mode 1
  14. 204flightsinmotion
    227Coins
    This is the board I received. The wiring was labeled on this board differently than on the diagram on the first page of this thread so I did have to make some tweaks to where the wires connected.
    Also I used a fresh arduino and programmed it in mode1. Still shaking
  15. Wagnard
    Wagnardsoft
    5,337Coins
    Same as mine.
    When you say shaking, does is still work (you can move it to the position you want) but you see some shake or it's not even working?
    Also it requires a battery too. Without it the current has no exit and I was getting some hickup.
  16. 204flightsinmotion
    227Coins
    It’s pulsing like crazy. So if I set it to follow a wave, it will but very very shaky and if I set it to the level position it shakes like crazy there.
    It’s 24v I don’t have a battery setup but I’m using a 24v 30A power supply. It worked well with the ibt2
  17. 204flightsinmotion
    227Coins
  18. Wagnard
    Wagnardsoft
    5,337Coins
    does the rumble happen when you are at the limit you set in SMC ? I know that when you hit the limit it tries to bring it back and can shake like that.
    what happen if you select "sine"
  19. 204flightsinmotion
    227Coins
  20. Wagnard
    Wagnardsoft
    5,337Coins
    that's weird because you have the min and max at 0, it means no power it shouldn't move. maybe wrong motor selected on top left.
    5Khz is a little low , probably should at least start at 10khz.
