MSFS 2024 Plugin
Discussion in 'Flight Simulator 2020 - FS2020' started by Buj818, Nov 19, 2024.
  1. Mauricio
    Mauricio Member Gold Contributor
    75Coins
    Hello friends!
    I'm suspicious that the small random jerks that occur both when I turn on Simtools and when Flymover is due to the low Boud Rate (9600). Does anyone know how I can change the Thanos controller?
  2. Joe Cortexian
    1,537Coins
    Turn off everything except pitch and roll. Heave (bumps on the ground) were causing my rig to lurch in level flight. I ended up with it set to 10. Add other stuff in if you dare.
    First I turned it completely off and noted the problem was gone but then I missed bumps when landing or taking off.
  3. lysa elec
    lysa elec LYSA ELEC
    16Coins
    i dont see the pluging for mfs 2024
    is it the same of mfs 2020 ?
    153,818Coins
    +11,150 / 57 / -2
  5. Mauricio
    75Coins
    Thanks for the reply.
    When you turn on SimTools, does your platform already show some small jerks? Even before I enter flight mode (choosing aircraft, airports, etc.), it already has these small movements. I notice that it senses any signal, even when moving the mouse. Does this happen to you? Do you turn on SimTools and it already shows small movements?
  6. Joe Cortexian
    1,537Coins
    Yes it can be a bit spastic. There is a “bug” reported on this on the forums.
  7. Firehunter588
    Firehunter588 New Member Gold Contributor
    - 14Coins
    I’m having the same issue with mine as well. As soon as I enter flight mode, there are multiple small, hard movements that shake the rig for just over a second, and then stop just as quick. Sometimes it can over load a motor to shut off and I have to reset everything. Not fun. But once it works, it works well.
  8. Joe Cortexian
    1,537Coins
    When I think of it I hit the estop before starting and don’t release it until after I hit the fly button. Every now and then it starts with the nose pointing down instead of up which leads to a sudden change of mind me pointing up somewhere down the runway.
  9. Arianus One
    Arianus One Tony Rom
    empleado
    16Coins
    i see that msf 2024 is equal 2020 plugins, thanks you firends
  10. Davidsimvr
    Davidsimvr New Member
    2Coins
    Hello, I'm a fan of the FS2020 and 2024 simulators and I have 3DOF. Does it work well? Thanks
  11. Joe Cortexian
    1,537Coins
    It works. Well, ehhh. Well enough. The sway is kind of bang bang so I put a filter there. The gear shifts are prominent and combined with surge. Note the sway is backwards from every other racing game if memory serves.
  12. notfasteddy
    notfasteddy New Member
    42Coins
    I eventually got my rig (2DOF) going on LFS as designed, although I still have trouble saving max min settings and have them available for next time I play. However that can wait as the reason I built my rig in the first place was for MSFS2024.
    I have downloaded the plugging and configured it as for LSF except using pitch and roll. But although the platform sets up (moves to start position) when I start a free flight, none of the controls (pitch and roll) get any response even though I can see the yoke on MSFS airplane move as required. I have done a number of flights before trying it on the rig.
    Anyone else have this issue? Should I try the MSFS 2020 plugin?
  13. noorbeast
    153,818Coins
    +11,150 / 57 / -2
    Can you please post pictures of all of your settings, including the Tuning Center while the game is running.
  14. notfasteddy
    42Coins
    Thanks Noorbeast for quick response,
    I have screen shot everything I can find re settings and I ran the game and screenshot the results. The numbers in the input boxes move up and down randomly and do not seem to be linked to the yoke movements.
    Screenshot 2025-12-22 094721.png Screenshot 2025-12-22 094819.png Screenshot 2025-12-22 094909.png Screenshot 2025-12-22 095104.png Screenshot 2025-12-22 095515.png Screenshot 2025-12-22 094721.png
    153,818Coins
    +11,150 / 57 / -2
    The plugin looks to be working, given it provides data in the top Inputs row of the Tuning Center, suggesting further configuration is required. Try Capture, fly around normally, then Save in the Tuning Center.
  16. notfasteddy
    42Coins
    OK I have tried capture and flying around and I can see the figures changing in the input lines and the Max Min lines when I save, but when I go back in the next time the figures are back to default. I also note that simtools does not close down when I use the x in the top right corner and I have to use task manger to shut it down. Have I got the installation right?
    153,818Coins
    +11,150 / 57 / -2
    Where you encounter SimTools v3 issues please post them to the dedicated thread, for dev visibility and consideration: https://xsimulator.net/community/threads/simtools-v3-public-beta.17329/
