Reasonably Priced 100A Motor Controllers
Discussion in 'Motor actuators and drivers' started by Richard Ortengren, Jan 29, 2023.
Tags:
  1. 204flightsinmotion
    204flightsinmotion Member
    209Coins
    Yes so I had it at 35. That’s what I had it at when I was using at ibt2. Did same thing
  2. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,293Coins
    Hard to tell, maybe something with the wires.
    Here mine.
  3. 204flightsinmotion
    209Coins
    How did you wire the 15k square wave since it’s marked different than the drawing on here on our boards.
  4. Wagnard
    Wagnardsoft
    5,293Coins
    Not sure what is different other than the a1<->a2 and B1<->b2 inverted.
    The 15k is the same.
    15k of motor a goes to pin 9, and the 15k of B goes to pin 10 just like the example
    They are named PA and PB on mine
    Nothing on AG or PW
  5. Pcon
    Pcon New Member
    - 26Coins
    Did some more investigating and turns out the circuit boards are faulty. There was an open circuit on the last channel. After removing the heatsink I noticed that the pin holes were absent there & that's what connects to the back side of the board. Soldered in a jumper cable & the problem is solved. All 3 boards were the same
  6. Wagnard
    Wagnardsoft
    5,293Coins
    Just realise I missed you previous post.
    I have a blue LED not too far of where we connect the wires for the Arduino and 2 oter LED on the sides near the big capacitor (red/green) LED.
    Mine looks different than yours, it has way more solder.
  7. 204flightsinmotion
    209Coins
    So I got motor on working! Wooot! Turned out I had the wires for the 15k switched!!! Now motor one is tracking and working. Moved on to motor 2 and I don’t get anything out of it. Pot is wired correctly but for some reason nothing out of the board. Triple checked the wires. Maybe my boards fault and needs the solder fixed like the gentleman above mentioned!
  8. 204flightsinmotion
    209Coins
    I noticed you circled two areas. Which did you solder the jumper to. Trying to better understand so I can take my heat sink off. Noticed only my channel A works. b does not and I just got my board this week.
  9. 204flightsinmotion
    209Coins
    Any pics of the wire you soldered in without the heat sync on
  10. Pcon
    Pcon New Member
    - 26Coins
    The one on the right was the faulty one. I think someone is selling faulty boards that failed test. One I had just popped the voltage control chip for no reason so now have no faith in them. I think I'll change to a reputable driver for my rig
  11. 204flightsinmotion
    209Coins
    Ya mine is not working. Tried soldering a wire to both of the feeds on the second motor channel but it still doesn’t work. I ordered another one from an another seller and the add had some alliexpress Brand+ certified original badge on it. Hoping that board will work but I’m getting so sick of waiting for shipping. Any GOOD board recommendations from
    Amazon Canada? I just want to get something fast that works.
    153,770Coins
    +11,149 / 57 / -2
    There are a bunch of SMC3 related/compatible options to choose from, depending on your personal priorities: https://xsimulator.net/community/faq/arduino-code-for-use-with-various-hardware-and-simtools.31/
  13. Doon1
    Doon1 Member
    391Coins
    Is there a part # for this controller? ChatGPT can't seem to find it.
  14. Josh_Possa
    Josh_Possa Active Member
    Catalunya
    614Coins
    Hi, sorry for the late response. I don't know because I finally opted for Sabertooth controllers. This cheap controllers wasn't enough for my motors load and the tin melted
  15. Bagof.stupid
    Bagof.stupid New Member
    57Coins
    Hello, hoping somebody can help me, I have motor controllers that are very similar to the one posted at the beginning of this post, I got them off Amazon. They have a blackboard, and the LED indicators are in a different spot if it maters.I have it wired same as the diagram, but for the life of me, I cannot get the second motor to work,with the second motor hooked up both pots control motor 1 but no life for motor 2. If I hook up two of these controllers, it works fine. Is it possible that some of these are only one motor even if they have the pins for two?
  16. noorbeast
    153,770Coins
    +11,149 / 57 / -2
    It would likely help if you link the actual product page and specs.
  17. Bagof.stupid
    57Coins
  18. Gadget999
    12,132Coins
    that should work fine - move the wiring from CH1 to CH2 and thet hould work too
    you may have a damaged CH2
  19. Nicki9knuckles
    Nicki9knuckles Active Member
    Web Developer
    794Coins
    @Bagof.stupid not sure if it helps, but i noticed when I hooked mine up that the diagram has the A1, and A2 and B1 and B2 oppsite.. They were listed A2 and A1 and B2 and B1, so make sure you done have the A1 wire going to the A2 port instead, etc.
    Also the A1 and A2 are for one motor and B1 and B2 are for the other. I also wasn't sure when I got it if A1 and B1 are for one motor and A2 and B2 are for the other, but its not.
    hope this helps
  20. Bagof.stupid
    57Coins
    I did notice that and have tryed it with no luck. Seems that motor one works fine on both of the boards I have but when motor two is hooked up the direction LEDs on the board show forward and reverse at the same time for motor two and no motor function but motor one always works fine the direction LED indicators indicate properly. Guess I’ll just have to use these boards as a single motor driver
