Tutorial SPS - Sabertooth Packet Serial PID motor driver sketch w/SoftStart
Discussion in 'SimTools compatible interfaces' started by BlazinH, Nov 10, 2016.
  1. noorbeast
    153,758Coins
    +11,149 / 57 / -2
    There are 24v batteries available, just do a search, of course geography may be a issue!
    Alternatively, you can use 2 X 12v batteries and there is plenty of online available information, for example: https://powmr.com/blogs/news/12v-batteries-to-24v
  2. Alvaro George Menendez
    Alvaro George Menendez New Member Gold Contributor
    Sydney NSW Australia
    69Coins
    the centre to centre on the motor leaver arm is 92mm
  3. Kevinski
    Kevinski If it doesn't fit, hit it until it does. Gold Contributor
    Australia
    115Coins
    @Michail sorry for the late reply. 90mm CTC on surge motor lever.
  4. Kevinski
    Australia
    115Coins
    @204flightsinmotion I use a combo of PSU's in parallel with a 12 volt SLA battery in my simulator build. It is a 12 volt system though. No problems using it like that. As Noorbeast pointed out, it is recommended by dimesion engineering to do it this way. Have a look at this link from this discord channel. https://discordapp.com/channels/1437286798853275742/1439090709196963850/1439094484565758063
    This gentleman from Canada has built a controller for PSU's to use with his sabretooth. He claims it will likely negate the need for a battery. I'm waiting on him to finish his sim build so I can see the results. If this powers his motors without drop outs, I'll more than likely be changing over to this way of powering my rig and doing away with the battery.
  5. 204flightsinmotion
    204flightsinmotion Member
    209Coins
    So I got the sabre tooth 2x60 wired up to my arduino uno r3 that I was previously using with the 100a board that failed me.
    I followed the steps carefully and am getting “
    Compilation error: expected unqualified-id before numeric ”
    any tips on getting this part figured out?
    153,758Coins
    +11,149 / 57 / -2
    Can you please be more specific about what was done or not done, and which point it fails at following the instructions, and please confirm key steps have been done, such as Step 6:
    Initial Setup
    Make sure Simtools is NOT running.
    1. If you have a new 2x32 or a 2x32 that is not already set to 115200 baud, use DEscribe software to set its baud rate to 115200. (note: setting the baud on a new 2x60 with DEscribe is not necessary) https://www.dimensionengineering.com/info/describe
    2. If you wish to use serial timeouts on a 2x32 you must set them to 100ms using DEscribe also.
    3. Wire up your Arduino to your Sabertooth as shown above in the wiring diagram
    4. Connect your Arduino to your computer via USB.
    5. If not already done download and install the Arduino programming software
    6. Download and run SabertoothArduinoLibrary.exe attached below
    7. If not already done apply power to your Sabertooths motor inputs.
    8. Now use the Arduino programming software to install the SPS sketch attached below on your Arduino. Make sure you choose Uno or Mega and to set the comport number.
    9. Next download and run the Windows SMC3 Utility software attached below and make sure it communicates with your Arduino. Open the accompanying SMC3Utils.ini with notepad to change the comport if needed (see image below)
    10. Set Fpid to / 1. (If you experience motor twitching or other issues then try increasing it)
    11. Set Step to 100 and then set Kp, Ki, Kd, PWMmin, PWMmax, PWMrev to 0 (This will make sure the motors don’t move)
    12. Set Clip to 255 (you need to do this first) and Limit to 255 (This will give you plenty of margin if something goes wrong while setting up)
    13. Now click the -> M2 button to apply the same settings to motor 2 also
    14. Change Kp for motor 1 from 0 to about 400
    15. Set step back to 1
    16. Click the ON/OFF button for motor 1 to ON
    17. Now slowly, increase PWMmax… at some point the motor should start to move. When it does check the “Green” feedback line is moving toward the “Blue” target position.
      • If you are using a 2x60 and the motor doesn’t move, and assuming its wiring is correct, then its possible that your Sabertooths baud rate did not match what was expected when the sketch was run so it may not have autobauded. See the wiring diagram about setting jumpers to try a different baud rates.
    18. Set Step back to 100 and repeat steps #13, #14, #15, and #16 above for motor 2
    19. Motor driver setup is now complete but the PID controller will still need to be turned to work properly with your particular setup. This will be done later though and is not included in the scope of this tutorial
    20. Now start Simtools Game Engine (see image below)
    21. Open Interface Settings
    22. Now set up Interface1 as shown in the image below but substitute your arduino’s ComPort number if it is not on Com1.
    23. Click the SAVE button
    24. Simtools Game Engine Interface is now correctly configured to send data to the SPS motor driver sketch
    25. That’s all. You can now start testing your setup with Simtools.
  7. Kevinski
    Australia
    115Coins
    @204flightsinmotion did you clean out the code on the Ard that was running this 100amp motor controller before you installed the sabretooth packet serial code running the new 2x60 sabretooth? You might have a corrupted eprom chip if you didn’t delete the existing code.
  8. 204flightsinmotion
    209Coins
    I didn’t wipe it out. Should I buy a fresh one or should I run a blank on this one.
    I followed the steps made sure simtools
    Was closed. Made sure it was wired correctly. And then followed the steps. Installed that software package once then installed again as admin just in case. And restarted before running the arduino code.
    “C:\SPS_8.2_softstart\SPS_8.2_softstart.ino:229:1: error: expected unqualified-id before numeric constant
    11
    In file included from C:\SPS_8.2_softstart\SPS_8.2_softstart.ino:232:0:
    C:\Users\Arcade\Documents\Arduino\libraries\Sabertooth/Sabertooth.h:57:28: error: 'SabertoothStream' has not been declared
    Sabertooth(byte address, SabertoothStream& port);
    C:\Users\Arcade\Documents\Arduino\libraries\Sabertooth/Sabertooth.h:70:10: error: 'SabertoothStream' does not name a type; did you mean 'Sabertooth'?
    inline SabertoothStream& port() const { return _port; }
    Sabertooth
    C:\Users\Arcade\Documents\Arduino\libraries\Sabertooth/Sabertooth.h:83:24: error: 'SabertoothStream' has not been declared
    static void autobaud(SabertoothStream& port, boolean dontWait = false);
    C:\Users\Arcade\Documents\Arduino\libraries\Sabertooth/Sabertooth.h:176:3: error: 'SabertoothStream' does not name a type; did you mean 'Sabertooth'?
    SabertoothStream& _port;
    Sabertooth
    C:\SPS_8.2_softstart\SPS_8.2_softstart.ino:233:46: error: cannot bind non-const lvalue reference of type 'int&' to an rvalue of type 'int'
    Sabertooth ST[2] = { Sabertooth(128, mySerial), Sabertooth(129, mySerial), };
    In file included from C:\SPS_8.2_softstart\SPS_8.2_softstart.ino:69:0:
    C:\Users\Arcade\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SoftwareSerial\src/SoftwareSerial.h:106:3: note: after user-defined conversion: SoftwareSerial::eek:perator bool()
    operator bool() { return true; }
    C:\Users\Arcade\Documents\Arduino\libraries\Sabertooth/Sabertooth.h:57:3: note: initializing argument 2 of 'Sabertooth::Sabertooth(byte, int&)'
    C:\SPS_8.2_softstart\SPS_8.2_softstart.ino:233:73: error: cannot bind non-const lvalue reference of type 'int&' to an rvalue of type 'int'
    exit status 1
    Compilation error: expected unqualified-id before numeric constant “
    That’s my error
  9. Michail
    748Coins
    So with 90mm CTC you get ridiculous long 210mm travel this is insane.
  10. Alvaro George Menendez
    69Coins
    Just to make sure we are talking about the same thing ... trolley arm lever CTC length is 75mm and 225mm... check out kevinski's server in discord for others results.
  11. Kevinski
    Australia
    115Coins
    I’d have to double check, but that’s 210mm in total. 105mm forward and 105mm backwards from the trollies centre position.
  12. Alvaro George Menendez
    69Coins
    Correct ... mine is about that too
  13. Kevinski
    Australia
    115Coins
    @Michail yes it is a bit insane building one of these things and taking the time to show others. But hey, others have taken the time to do the same. That measurement for the distance of travel is 210mm in total. 105mm forward travel and 105mm aft travel. And yes, it's enough.
  14. Kevinski
    Australia
    115Coins
    @204flightsinmotion bloody ghosts in the machine. I am by no means an expert on coding micro controllers. Thankfully guys like Blazing H and Rufus Dufus have done the heavy lifting there and made their codes available for us to use. You can buy really cheap uno r3 clones. I've got a couple of them and they cost me like 5 bucks each.
    It might be worth the investment, just so you can try a fresh install on a fresh board. If it works on the fresh board you are set. Only problem with the cheap arduino clones, is the eprom chips on them often corrupts after a short time and won't retain saved profiles.
    But if it works changing over to a new fresh board, you can at least then with confidence purchase a genuine arduino board and install that with the serial packet code. Good luck mate.
  15. 204flightsinmotion
    209Coins
    so the new clone r3 came in and I did the steps on a fresh seperate windows computer and it was successful. Then I moved the board and sabretoooth to my rig and now I’m getting “unknown usb device (device descriptor request failed) in device manager. And “usb device not recognized in the corner of windows as soon as I plug it in. lol man can’t catch a break.
  16. Kevinski
    Australia
    115Coins
    @204flightsinmotion this kind of driver conflict stuff with windows can be really frustrating brother, so I'm feeling your pain. Sounds like the clone is conflicting with the Arduino driver that's in the cache or something. Again I'm no expert on windows, but you'll have to keep working through this shit.
    153,758Coins
    +11,149 / 57 / -2
    Have you tried it in all the other USB ports the computer has?
  18. 204flightsinmotion
    209Coins
    Tried all the ports. Same error. I ordered an authentic uno r3. Comes Monday. Praying it’s my last step lol
  19. RacinFool
    RacinFool New Member
    42Coins
    2DOF, DC motor, Arduino, 4DOF
    New to the community. I have been interested in a motion sim for a while now after getting into sim racing. I've had some success with DIY butt rumbler motors and wind sims with other programs. Watched a few tutorials and looked at some rigs from some of the members here and decided to dive in. I got my DIY license and I have followed the sabertooth 2x32 tutorial from @BlazinH. I have been successful testing my motors on SMC3Utils v1.01 with the SPS_8.2 Softstart on an arduino uno. I got things set up on sim tools interface set up to test using sim tools, but I don't get any motion. Have gone back to SMC3 utili and get movement again. Can you point me in a direction on a post or quick reply as to what could be a trouble shoot option for me. sketch on the arduino seems to work with the SMC3 test, but I don't get any voltage output when going to sim tools. Only thing I thought could be wrong was the baud rate, but I've tried making sure that was correct with no luck. Thanks
    153,758Coins
    +11,149 / 57 / -2
    Can you please post pictures of all your interface settings, my guess is a simple configuration issue.
