value1
Assetto Corsa Rally Plugin 2.0.0.2
SimTools plugin for Assetto Corsa Rally
  1. Titobial
    Titobial Member
    Zaragoza
    107Coins
    Well, I can't get the ACR plugin installed. Am I on the correct version? Thank you! 17633809932736731436732060963874.jpg
  2. Squarebob
    Squarebob Member Gold Contributor
    Georgia USA
    70Coins
    DC motor, Arduino, 4DOF
    I removed the first version then uploaded new version and get this message. Wonder what I did wrong
    154,286Coins
    +11,177 / 57 / -2
  4. Titobial
    Titobial Member
    Zaragoza
    107Coins
    Now!! Brilliant! It already works! Thank you very much!!
  5. Kenshiro27
    Kenshiro27 Active Member
    253Coins
    2DOF, 3DOF, Arduino
    Thank you so much for this plugin, it's really great to see simtools V2 still active.hug::thumbs
    • Friendly Friendly x 2
  6. Hobbs77
    Hobbs77 Active Member
    Connecticut, USA
    875Coins
    2DOF, SCN5
    Any idea how much longer for the v3 version? Thanks in advance!
    154,286Coins
    +11,177 / 57 / -2
  8. Hobbs77
    Connecticut, USA
    875Coins
    2DOF, SCN5
    Thanks noorbeast, I guess I was hoping 1 of the devs would see it and reply instead of me bothering them directly. Maybe you or a member can answer this....How long on average does it usually take for them to make a v3 plugin for a new game? I think my last new game was ea wrc23 and I'm not even sure if I was using v3 back then. Just curious on how long the process takes on average is all.
  9. Titobial
    Titobial Member
    Zaragoza
    107Coins
    Hello! But is this plugin valid for V.3? I use V.2 and I actually have the printed manual. Thank you!
    154,286Coins
    +11,177 / 57 / -2
  11. Titobial
    Titobial Member
    Zaragoza
    107Coins
    Perfect! Thanks
  12. Majony_gijon
    Majony_gijon New Member
    27Coins
    3DOF, Motion platform
    First of all, i want to thank the great @value1 for creating this plugin for those of us still using Simtools v2.
    I have a Prosimu 5 PRS-200 base, and since it's a few years old, and it's not compatible with Simtools v3.
    I haven't been able to use my simulator with Le Mans Ultimate or WRC24 because there's only a plugin for v3.
    This plugin is a lifesaver.
    I hope you can release in future a v2 plugin version for these games, @value1; many of us are in the same situation.
    Now, a question.
    I have 21 coins but i can't download this plugin, how many coins i need?
    I had read that i needed 10 coins to download it.
    Thanks!
  13. noorbeast
    154,286Coins
    +11,177 / 57 / -2
    Please see the FAQs here re coins or membership and plugin access: https://xsimulator.net/community/faq/coins-and-how-to-download-plugins.2/
  14. JaniK
    JaniK New Member
    Truck driver
    Finland
    69Coins
    The game feels so alive now. Thanks to developers for making these.:cheers
  15. Titobial
    Titobial Member
    Zaragoza
    107Coins
  16. Titobial
    Titobial Member
    Zaragoza
    107Coins
    Hello. This is my basic setup for my 2dof. After many tests, it is the only way to feel the acceleration and braking and the roll of the curves. (If I use other forces, since the terrain is inclined, the roll will be canceled if the inclination coincides with the inertia of the relevant curve) I don't know, let's see if someone has the same problem or maybe uses something similar to mine...
  17. Titobial
    Titobial Member
    Zaragoza
    107Coins
    On the other hand, in Tunin center, I have to have very low values to notice the forces to my liking. I don't quite understand capturing values while driving to do checks...
  18. JaniK
    JaniK New Member
    Truck driver
    Finland
    69Coins
    Tuning center (min/max values)
    Right way if i remember correctly would be to
    Reset, then click capture.
    Drive safely, full acceleration and braking but stay on the road, DO NOT overdo it and crash you car. I just drove for about 5 corners worth.
    Then i hit ESC to pause the game.
    ALT+TAB to see simtools.
    Click SAVE
    There you have normal driving values for the movement and you can the adjust from there.
    If in doubt. Try to match pitch and roll degrees to your rig.
    If you dont know, start with something like 20 and -20 for the pitch/roll values.
    I have set sway+surge min/max to 5/-5 .. that makes it react fast to small movements.
    Still tuning though.
    i use 20% for each action: pitch, roll, surge, sway, +pitch rate(filtered)
    I also use a 10k pot to dial down the movements.
  19. Titobial
    Titobial Member
    Zaragoza
    107Coins
    Thanks for your support! The issue is that, when I capture values in Tunin center, it shows some "rare" and very high figures in real time, which, I don't know what the approximate value corresponds to so that I can set it in my value. I always got involved with this and in the end I end up playing it on demand. But investigating this topic, they emphasize that taking values is important... P.S: I also use 10k potentiomeyros. Greetings and thanks again!
  20. Titobial
    Titobial Member
    Zaragoza
    107Coins
    I think I understand how it works: It is understood that by taking that turn with the tunin center, it captures the maximum values of your way of driving and plotting, as if we were saying the physical forces, centripetal and inertia that you generate while driving... And then those values are the ones that adjust within the range without going overboard. Is that so?! Thank you
