FlyPT Mover 3.7.0.17
  1. pmvcda
    15,702Coins
    Compared to 3.7.0.15? or the old one 3.5.x?
    From the old Mover it's not compatible right now, I need to do an importer. For 3.7.x versions it should work, but I'm making some changes and there's some bugs I hope to solve in the next release.
  2. rafeta
    rafeta New Member
    Electronics engineer
    SPAIN
    12Coins
    AC motor, Arduino, Motion platform, 6DOF
    I was trying to use files recorded with 3.7.0.15 version. Playing with 3.7.0.15 was perfect but now with 3.7.0.16 and 3.7.0.17 versions doing nothing.
  3. pmvcda
    15,702Coins
    It will work on the next release. Sorry for the problem.
    I'm adding video to the recording and it's causing problems everywhere...
  4. Marco Annunziata
    919Coins
    Hello, just two questions,
    1. I can't move the sliders in the rig module
    2. Is it possible to implement another parameter in "Follow pretenden pose even if out of range" over that "Prè follow"? To choose the End-of-stroke damping: sharp/steep deceleration near travel limit
    Thank you a lot
  5. Aerosmith
    Aerosmith Active Member
    self employed
    2,881Coins
    3DOF, AC motor
    I also have a feature request:
    Would it be possible to have a choice-box in the "Pose from RPM" window so we can select the source for the RPM value? Currently it is fixed to "Engine RPM" which is perfect for car simulation. But for a helicopter the engine runs at around 50.000 rpm and thats not useful if I want to simulate rotor vibrations (usually 400 to 600 rpm).
    A filter/operation field would be even better than a simple engine vs. propeller selection. This way I could experiment with my own variables or formulas.
  6. pmvcda
    15,702Coins
    The sliders are already solved for the next release,
    For #2, please explain it better, but changing pré follow should have the effect you want.
  7. pmvcda
    15,702Coins
    Yes it's possible, that's the reason to have propeller rpm. It's missing on the UI.
    It would allow the use of both at the same time.
    And I will add a filter/operation also.
    • Friendly Friendly x 2
  8. Marco Annunziata
    919Coins
    I’d like to be able to choose the point at which the deceleration curve begins, so that I can control how sharp the deceleration is and save actuator stroke at the cost of a less comfortable slowdown.
  9. Marco Annunziata
    919Coins
    I wouldn't want the entire actuator stroke to be modified—only the final portion. I understand this is a mathematical approximation, but something similar would still be useful.
  10. SlayerFlyy
    SlayerFlyy New Member
    92Coins
    Hello, while building my 2DOF platform, I encountered a problem with my ETs2, which I used to test the motors and connected. The FlyPT_ETS2_AMTS_MMF.dll file stopped working after upgrading to the new version. Everything worked fine with it before. Now, the connection indicator isn't even lit. upload_2025-11-17_19-12-14.png
  11. pmvcda
    15,702Coins
    There's a new dll.
    In the source window, you have a button to patch ets (pen icon) at the top right. This is going to install the updated dll.
    Before. Not sure, but i think you can keep both dll, they use different memory files.
  12. SlayerFlyy
    92Coins
    Sorry for my English, I'm using a translator. Yes, I did as you said, thank you. But it still doesn't work, and I don't even know what it's related to.
    I also don’t know how to respond to your message specifically, so I’m sending it separately.
  13. Marco Annunziata
    919Coins
    A sort of value like "Amount of the range used for infinite approach to the limit (0 to 1)" in the Logistic 3 function — not exactly the same, because this is not a curve but a ramp
  14. pmvcda
    15,702Coins
    Do it again to put the new patch.
  15. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,766Coins
    Hi @pmvcda! Currently I am working on the CAN-bus-communication between FlyPT mover 3.7.0.9 (UDP-output) and my Odrives via an ECAN-E01S. In order to get the right CAN-masseges, I had to make a python-code, that makes the right packages. This is working now. BUT my current problem is the handover between the FlyPT mover and the CAN-bridge during starting or disconnecting the outputs. The problem is, that the UDP - output values do not follow the real movement of the real rig. The real rig is going down to value 0 (zero) during the transition time, but the sent position of the UDP output stays in the middle of the actuator range (the driving-position). Pls. see following screenshot. The same thing is with the 3D view. this stays also in middle-position.
    This behavior can cause big jumps from zero to middle-position. Also introducing an aditional transition time in the CAN-bridge was not able to solve this problem.
    So my kind request for a modification is, to send the real rig-positons (optional) in the UDP output!
    Thanks! Wickie
  16. pmvcda
    15,702Coins
    Can you try the latest 3.7.0.17?
    Should be solved.
    Download link is in the first post of this thread
  17. Erik Green
    Erik Green Member
    409Coins
    We all know 'dont bother Pedro, let him work!'. So I hope someone else can help me figure out a feature: Through the Carousel, much of the force should be centrifugal rather than lateral G's. Well a combo of both. Is there a telemetry value for that centrifugal force? My g-seat simulates vertical G's which can be felt in compressions but I don't feel a 'vertical G' type response thru the carousel.
    edit: Duh, just looked @ the available telemetry outputs..... What is 'vertical gravity'? Might that be the answer?
  18. Erik Green
    Erik Green Member
    409Coins
    Nope. I think I'm getting the extra vertical acceleration. But since im tipped sideways I'm not sensing it. The problem is that that centrifugal force is not cancelling out the roll angle cue the Carousel presents. That is, as I enter this long banking turn and the g force comes on the rig should roll back toward horizontal.
    How do you flyboys configure your roll axis for a Coordinated Turn? I hope I'm using the correct terminology. I'm guessing its something like:
    Roll Angle - inverse Tan(Vert Acc/9.81)? Vectors?!
  19. pmvcda
    15,702Coins
    Vertical gravity (VER_G) is the the decomposition of gravity in the heave direction. Just like you have lateral and longitudinal. Vertical is 9.8 if you are leveled, but with roll or pitch, you start "feeling" gravity in the other directions (sway and surge)
    You also have the vertical acceleration with gravity (VER_AG), that's the sum of the gravity for your orientation with the acceleration caused by the vehicle in the heave direction (VER_A).
    Now, when sitting in the rig, you already have the gravity naturally, so using just the VER_A should be enough. The changes of the gravity felt in all the directions can be induced by the rotations of the rig.
    But we can use VER_AG, but always with a wash or high pass filter so the rig goes back to zero.
    When you speak of centrifugal force in the Carousel, take a look at this video:
    So centrifugal doesn't exist. What you have is centripetal force or a lateral force, combined with a longitudinal acceleration
    If we are stopped on the slope, we feel just a lateral and vertical force caused by gravity, in a rig this can be simulated with the roll of the rig or use LAT_G in sway and mix it with roll. The mix should be a low pass filter to get the "constant" value.
    If we start increasing the car speed, the lateral gravity will be compensated by the lateral acceleration, and if fast enough, the lateral acceleration is bigger than the lateral gravity. If we are mixing the lateral acceleration in roll, the roll we had to simulate the "constatn" gravity becomes zero and then increases to the other side as speed increases.
    In sway we use high pass filters to get the sudden changes of value and send the low pass to roll. This way, sway that usually is a more limited dislocation on the rigs, is always washing back to zero.
    Now what should we fell in the vertical direction?
    The gravity component in that direction and the acceleration due to the car dislocation in it's vertical axis (LAT_AG). But like I said above, in a rig we already feel the gravity, so using LAT_A is enough. With the increase of speed, cornering in the Carousel, we should feel also an increase in the vertical force, just like a compression caused by the centripetal force (or vertical force) of going around the Carousel. The Carousel should work as a negative slope.
    In reality, the Carousel is a way of reducing the lateral force and increase traction by means of the vertical force to make the corner fast.
    Sorry for the long text and bad English. Hope I gave you some insight.
    You could post here your settings to see what you are using, but you should feel the vertical force variation (maybe the filters are to strong).
  20. Erik Green
    Erik Green Member
    409Coins
    I knew I'd get corrected for centrifugal. I have a g seat so what I get is the sides of the seat press in to simulate vert accel. The g seat is mounted on a 3dof rig. I will get telemetry tomorrow but now believe I am getting the added vert acceleration. The problems is the rig is tipped sideways at the bank angle as I am g-loaded in the turn. Where if I was going just the right speed to get 1 g in the turn my rig should be sitting horizontal. Just Googled how to calc road bank angle:
    ........If you want a load factor of n=1.1g (1.1 times normal gravity felt by passengers): theta =arccos(1/1.1)........
    So since I have that accel value from telemetry I can calculate theta and subtract it from my roll angle.
    Hopefully.
