FlyPT Mover 3.7.0.17
  1. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,838Coins
    DC motor, 6DOF
    If your car is tilted in a constant side slope of for ex 15deg. you need to create a centrifugal 0.258G-force (sin(15deg.)) in a turn, so the math compensate it and bring your platform flat.
    By analogy, in a longitudinal slope of 15deg. you need to accelerate 0.258G in order to bring your rig flat.
  2. hexpod
    berlin
    7,838Coins
    DC motor, 6DOF
    Important to understand - to tilt your platform, instead of angular positions, you should choose angular velocities (usually present in all titles acting only when you are torquing). What should tilt you platform is the gravity component (if not present natively in the game telemetry, you can add it in mover)
    Than selecting „mix surge in pitch“ and „mix sway in roll“- option should add and subtrac all the forces in a correct manner automatically.
  3. pmvcda
    15,702Coins
    In most sims, accelerations don't include gravity
    When they include, mover puts that value in the AG values and calculates the other ones (A and G).
    So you don't need to know those details from the games.
  4. Flymen
    Montreal, Canada
    2,458Coins
    DC motor, 6DOF
    @pmvcda
    After several attempts, I haven't succeeded with the new 3.7 program.
    I have almost the same setup as you on your Sim, though. 3.5 is still working very well, and I'd really like to have the chance to try the new one.
    If you see anything !!!!
    I have no communication with the outputs / esp32
    If you ever get the chance, I'll send you my program.
    Thanks again !:sos
  5. pmvcda
    15,702Coins
    Latelly I'm testing on another rig that uses UDP. From what I see, your settings are correct.
    I will try to test this weekend on the older rig.
    Do you get any motion? Nothing?
    Are the values updated in the send field?
    Send me the setup to test here (the old and the new one), but should be a bug on my side it it's working on the old Mover.
    The new Mover uses a new logic to generate the data sent to the hardware that is faster than the old one, so using the new one would give you less latency.
  6. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,766Coins
    Hi @pmvcda, I have a strange behaveour when I add a pose from rpm to my rig:
    When connecting the UDP output (for the CAN-bridge), the actuators start driving towards the middle position, but stop at around 80mm (from 175 mm to the middle-position). Then mover sticks and do not react anymore.
    Do you have an idea, why?? Maybe a bug? (Note: I can reproduce the behaveour with attached *.mover - files).
    Without the pose from rpm my rig is working great
    Thanks a lot !
  7. Chris_Beeves
    2,164Coins
    Do you have an idea when the 4dof linear might get a fix?
    Really looking forward to getting started with mover, but my hands are tied! :eek:
  8. Trigen
    Trigen Active Member
    2,891Coins
    Using any filter in Direct. 3.7.0.17 Not working :)
    Code:
    System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection. (Parameter 'index')
       at System.Collections.Generic.List`1.get_Item(Int32 index)
       at Mover.Directs.FromOneOrMoreValues.DIRFilterOperationChanged(Object sender, EventArgs e)
       at Mover.UI.DIR.<.ctor>b__31_1(Object s, EventArgs e)
       at Mover.UI.AFC.set_Text(String value)
       at Mover.UI.AFCWindow.AFCOperationChanged(Object sender, EventArgs e)
       at Mover.UI.AFCOperation.OperationChanged(Object sender, EventArgs e)
       at Mover.UI.DDL.set_SelectedIndex(Int32 value)
       at Mover.UI.DDL_WINDOW.OnMouseDown(MouseEventArgs e)
       at System.Windows.Forms.Form.WndProc(Message& m)
       at Mover.UI.WINDOW.WndProc(Message& m)
       at System.Windows.Forms.NativeWindow.Callback(HWND hWnd, MessageId msg, WPARAM wparam, LPARAM lparam)
    System.Private.CoreLib
        Assembly Version: 9.0.0.0
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Private.CoreLib.dll
    Mover
        Assembly Version: 3.7.0.17
        Location: C:\Users\trige\AppData\Local\Temp\.net\Mover\7OFfb7ewWSih9kSlz2CakOLWN76oNqo=\Mover.dll
    System.Runtime
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Runtime.dll
        Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\9.0.11\System.Windows.Forms.dll
    System.ComponentModel.Primitives
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.ComponentModel.Primitives.dll
    System.Windows.Forms.Primitives
        Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\9.0.11\System.Windows.Forms.Primitives.dll
    System.Private.Windows.Core
        Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\9.0.11\System.Private.Windows.Core.dll
    System.Drawing.Primitives
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Drawing.Primitives.dll
    System.Collections.Specialized
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Collections.Specialized.dll
    System.Diagnostics.Process
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Diagnostics.Process.dll
    System.Runtime.InteropServices
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Runtime.InteropServices.dll
    System.Threading
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Threading.dll
    System.Collections
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Collections.dll
    System.Linq
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Linq.dll
    System.Drawing.Common
        Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\9.0.11\System.Drawing.Common.dll
    System.ComponentModel.EventBasedAsync
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.ComponentModel.EventBasedAsync.dll
    System.Xml.XDocument
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Xml.XDocument.dll
    System.Private.Xml.Linq
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Private.Xml.Linq.dll
    System.Private.Xml
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Private.Xml.dll
    Microsoft.Win32.Primitives
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\Microsoft.Win32.Primitives.dll
    System.Threading.Thread
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Threading.Thread.dll
    Accessibility
        Assembly Version: 4.0.0.0
        Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\9.0.11\Accessibility.dll
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.ComponentModel.dll
    System.Numerics.Vectors
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Numerics.Vectors.dll
    Microsoft.Win32.SystemEvents
        Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\9.0.11\Microsoft.Win32.SystemEvents.dll
    System.Collections.Concurrent
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Collections.Concurrent.dll
    System.ComponentModel.TypeConverter
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.ComponentModel.TypeConverter.dll
    System.Net.Http
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Net.Http.dll
    System.Net.Primitives
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Net.Primitives.dll
    System.Diagnostics.Tracing
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Diagnostics.Tracing.dll
    System.Diagnostics.DiagnosticSource
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Diagnostics.DiagnosticSource.dll
    System.Net.Security
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Net.Security.dll
    System.Security.Cryptography
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Security.Cryptography.dll
    System.Resources.Extensions
        Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\9.0.11\System.Resources.Extensions.dll
    System.Memory
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Memory.dll
    System.Drawing
        Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\9.0.11\System.Drawing.dll
    Microsoft.Win32.Registry
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\Microsoft.Win32.Registry.dll
    Microsoft.Windows.SDK.NET
        Assembly Version: 10.0.26100.38
        Location: C:\Users\trige\AppData\Local\Temp\.net\Mover\7OFfb7ewWSih9kSlz2CakOLWN76oNqo=\Microsoft.Windows.SDK.NET.dll
    System.Collections.NonGeneric
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Collections.NonGeneric.dll
    System.Diagnostics.FileVersionInfo
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Diagnostics.FileVersionInfo.dll
    System.Security.Principal.Windows
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Security.Principal.Windows.dll
    System.Security.Claims
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Security.Claims.dll
    WinRT.Runtime
        Assembly Version: 2.2.0.0
        Location: C:\Users\trige\AppData\Local\Temp\.net\Mover\7OFfb7ewWSih9kSlz2CakOLWN76oNqo=\WinRT.Runtime.dll
    System.Private.Uri
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Private.Uri.dll
    System.ObjectModel
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.ObjectModel.dll
    System.Linq.Expressions
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Linq.Expressions.dll
    System.Management
        Assembly Version: 10.0.0.0
        Location: C:\Users\trige\AppData\Local\Temp\.net\Mover\7OFfb7ewWSih9kSlz2CakOLWN76oNqo=\System.Management.dll
    AxInterop.WMPLib
        Assembly Version: 1.0.0.0
    Interop.WMPLib
        Location: C:\Users\trige\AppData\Local\Temp\.net\Mover\7OFfb7ewWSih9kSlz2CakOLWN76oNqo=\Interop.WMPLib.dll
    mscorlib
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\mscorlib.dll
    Interop.WMPLib
    Mover
    System.DoubleNumerics
        Location: C:\Users\trige\AppData\Local\Temp\.net\Mover\7OFfb7ewWSih9kSlz2CakOLWN76oNqo=\System.DoubleNumerics.dll
    System.IO.Ports
        Location: C:\Users\trige\AppData\Local\Temp\.net\Mover\7OFfb7ewWSih9kSlz2CakOLWN76oNqo=\System.IO.Ports.dll
    Mythosia
        Assembly Version: 1.2.0.0
    netstandard
        Assembly Version: 2.1.0.0
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\netstandard.dll
    Mythosia.Integrity
    NWaves
        Assembly Version: 0.9.6.0
    System.CodeDom
    System.IO.Ports
    System.Management
    WinRT.Runtime
    System.Configuration.ConfigurationManager
        Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\9.0.11\System.Configuration.ConfigurationManager.dll
    WindowsFormsIntegration
        Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\9.0.11\WindowsFormsIntegration.dll
    PresentationFramework
        Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\9.0.11\PresentationFramework.dll
    PresentationCore
        Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\9.0.11\PresentationCore.dll
    WindowsBase
        Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\9.0.11\WindowsBase.dll
    System.Xaml
        Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\9.0.11\System.Xaml.dll
    System.Net.HttpListener
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Net.HttpListener.dll
    System.Text.RegularExpressions
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Text.RegularExpressions.dll
    System.Resources.Writer
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Resources.Writer.dll
    System.Runtime.Serialization.Formatters
        Assembly Version: 8.1.0.0
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Runtime.Serialization.Formatters.dll
    System.Reflection.Emit.ILGeneration
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Reflection.Emit.ILGeneration.dll
    System.Runtime.Numerics
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Runtime.Numerics.dll
    System.Formats.Asn1
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Formats.Asn1.dll
    System.Formats.Nrbf
        Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\9.0.11\System.Formats.Nrbf.dll
    System.Security.AccessControl
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Security.AccessControl.dll
    System.Reflection.Primitives
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Reflection.Primitives.dll
    System.Xml.ReaderWriter
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Xml.ReaderWriter.dll
    UIAutomationProvider
        Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\9.0.11\UIAutomationProvider.dll
    UIAutomationTypes
        Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\9.0.11\UIAutomationTypes.dll
    System.IO.Packaging
        Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\9.0.11\System.IO.Packaging.dll
    System.Diagnostics.TraceSource
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Diagnostics.TraceSource.dll
    ReachFramework
        Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\9.0.11\ReachFramework.dll
    DirectWriteForwarder
        Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\9.0.11\DirectWriteForwarder.dll
    System.Net.Requests
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Net.Requests.dll
    System.Net.WebHeaderCollection
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Net.WebHeaderCollection.dll
    System.Security.Cryptography.Xml
        Location: C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App\9.0.11\System.Security.Cryptography.Xml.dll
    System.IO.IsolatedStorage
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.IO.IsolatedStorage.dll
    System.Net.WebSockets
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Net.WebSockets.dll
    System.Runtime.Loader
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Runtime.Loader.dll
    System.Text.Encoding.Extensions
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Text.Encoding.Extensions.dll
    System.Threading.ThreadPool
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Threading.ThreadPool.dll
    System.Net.Sockets
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Net.Sockets.dll
    System.Threading.Overlapped
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Threading.Overlapped.dll
    System.Net.NameResolution
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Net.NameResolution.dll
    System.Runtime.Intrinsics
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Runtime.Intrinsics.dll
    ScreenRecorderLib
        Assembly Version: 1.0.9247.28713
        Location: C:\Users\trige\AppData\Local\Temp\.net\Mover\7OFfb7ewWSih9kSlz2CakOLWN76oNqo=\ScreenRecorderLib.dll
    System.Runtime.Extensions
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Runtime.Extensions.dll
    NWaves
        Location: C:\Users\trige\AppData\Local\Temp\.net\Mover\7OFfb7ewWSih9kSlz2CakOLWN76oNqo=\NWaves.dll
    Mythosia.Integrity
        Location: C:\Users\trige\AppData\Local\Temp\.net\Mover\7OFfb7ewWSih9kSlz2CakOLWN76oNqo=\Mythosia.Integrity.dll
    Mythosia
        Location: C:\Users\trige\AppData\Local\Temp\.net\Mover\7OFfb7ewWSih9kSlz2CakOLWN76oNqo=\Mythosia.dll
    System.Diagnostics.StackTrace
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Diagnostics.StackTrace.dll
    System.Reflection.Metadata
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Reflection.Metadata.dll
    System.Collections.Immutable
        Location: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\9.0.11\System.Collections.Immutable.dll
  9. Flymen
    Montreal, Canada
    2,458Coins
    DC motor, 6DOF
    Thanks a lot !
    Happy holidays and new year, and... health in 2026!hug:
    Here, the old and new one set up Zip file .
  10. TheTakerPL
    TheTakerPL Member
    208Coins
    Hi, I have a very annyoing issue with outputs when connecting to ODrives (I have 3 of them)
    Serial ports change their names every reconnection, or starting Mover app. Sometimes it adds "(Interface 0)" to the name and Mover cannot recognize port with previous name, so I have to select new one from the list 3 times. How to change the port name permanently? Is it Mover problem or Windows problem? Or maybe ODrive problem?
    Merry Christmas and Happy New Year !
  11. m50b20
    m50b20 Member
    110Coins
    Hi ! What about Assetto Corsa Rally ?
    Just use common Assetto Corsa plugin ?
  12. pmvcda
    15,702Coins
    Use Assetto Corsa Evo, it's the same
  13. SlayerFlyy
    SlayerFlyy New Member
    92Coins
    Hello, I encountered this problem while creating the platform. When I set the pitch to 3, the platform already touches the floor? How can I fix this? After watching your videos, I was surprised how you set the values to 20 and higher, but also 999 for acceleration. Can you explain how to do this?
    I've attached all the photos. 109036
  14. pmvcda
    15,702Coins
    Can you tell me the video please.
    In the new Mover there's some internal changes in the Pose that might cause some problem. I will check.
    But when you speak of 20, 999 I'm not understanding what you mean. Wich values?
    From your other posts, I see you are using SMC3. Did you set the actuators correctlly? Is the pitch in the rig matching the pitch in Mover?
  15. SlayerFlyy
    92Coins
    Greetings to you and happy belated holidays
    Thanks for the reply, I was really looking forward to it, checking my email the whole time, etc.
    I'll send you a video soon with the exact settings and so on. I'm just at work right now... what a bad time, hahaha.
    When I wrote 20 and 999, I meant the results in the range column in the (Pose from motion) tab, specifically 20 in the Pitch and Roll window and 999 in Acceleration and Sway.
  16. Erik Green
    Erik Green Member
    409Coins
    Been trying to keep general questions in the 3.5.3 thread but this is related to 3.7.
    If I connect an 8bit output serial to control an arduino to o-drive everything works fine using 3.7.0.17. The same setup in 3.5.3 does not work. The two attached mover files are one for Mover3.5.3 and the other for Mover3.7.0.17 I first assumed some weird serial port setting or something but tried both configs on a different computer with the same result. Mover3.7.0.17 correctly outputs 8 bit serial to a Nano R4 and Mover3.5.3 does not.
    Hopefully someone has seen similar and has a simple solution. My rig with Mover3.5.3 driving an M4S controller works perfectly otherwise.
    Something to do with how my Arduino is reading the data?
    I assume it's most likely a problem of mine, just not found it yet after lotta hours troubleshooting.
    p.s. cannot attach files for some reason......
  17. Erik Green
    Erik Green Member
    409Coins
    Attached is what I get when trying to open a setup. As soon as a filter is added in my Lt Flap Direct the attached error occurs on opening setup:
  18. Erik Green
    Erik Green Member
    409Coins
    Same failure occurs if you make any change to the Direct, does not have to be a filter. Modify the gain and it'll error out.
  19. hexpod
    berlin
    7,838Coins
    DC motor, 6DOF
    Update request:
    I would like to report inproper recognition (uptating) of attached devices on Mover restart. (Joystick and Midi).
    This brakes the communication with those devices.
    Please confirm the bug. (map joy button, restart and see if the mapping is still working, if not, hit « Update List of devices » and check again).
  20. Erik Green
    Erik Green Member
    409Coins
    Overall Gain : With 3.5.3 I am using a gain of 1.0 and all is comfortable. To get the approx same response with 3.7.0.17 I am using a gain of .050 I assume the new version is treating the inputs differently?
