[WIP] 6DOF on hoverboard motors and SFU gearboxes
Discussion in 'DIY Motion Simulator Projects' started by TheTakerPL, Jul 23, 2025.
  1. TheTakerPL
    TheTakerPL Member
    198Coins
  2. Chris_Beeves
    2,164Coins
    Oooh, nice!
    I have a feeling this will be quite spectacular!
  3. Will974
    Will974 Active Member
    Industrial Ingeenering Teacher
    Reunion Island
    965Coins
    Your project is very cool with an unusual kinematic for a 6 dof rig.
    Great job ! :thumbs
    How do you control the three odrive ?
    And which software are you going to use to interface the game telemetry ?
  4. TheTakerPL
    TheTakerPL Member
    198Coins
    Hi. I use FlyPT Mover. 3 ODrives are just connected with USB and visible as 3 independent serial devices in Mover.
  5. X.STTONER
    X.STTONER Sttoner
    business manager
    lima
    232Coins
    2DOF, 3DOF, DC motor, AC motor, Arduino, Motion platform, 4DOF
    Excellent work! This is very good. I'm interested in learning more about your project. I have some questions about the FlyptMove software and how it works.
    How do you program the Makerbase ODrive3.6 56V controller board?
    And how do you wire it to the motor? Could you share some information?
  6. GettinBetter
    CAD Engineer
    Kent, UK
    594Coins
  7. TheTakerPL
    TheTakerPL Member
    198Coins
    Feel free to ask anything. ODrives are quite simple to connect, each board has 2 motor outputs and 2 encoder outputs. The only complicated thing is the software setup in console/odrivetool, but there's plenty of information on ODrive wiki.
    https://docs.odriverobotics.com/v/0.5.6/getting-started.html
    And look this video if you want to connect a hoverboard motor specifically:
    FlyPT mover looks a bit complicated. It works on 'nodes', you first make a source node, where you select game, then rig node where you input motion limits and rig dimensions, then pose node when you specify movement and which telemetry data moves which axis. Then output node where you connect your boards. You can even add more nodes of the same type and mix them to get desired result.
    Now time for update:
    Motion frame is ready. This is the first time I welded something like this complex 3D shape, with stainless steel tubes.
    Some welds looks pretty, some ugly, but I don't care. They hold well. It was hard, but not that hard.
    Whole steel frame weighs only 11,3kg, which is even lighter than my FFBeast joystick base (12,2kg)
    FFB rudder pedals needed some modifications to fit in the frame. Wider base plate, and motor moved to the front and below the floor.
    Lower seat part cut and 50W bass shakers installed.
    To do:
    -Wiring for stick,rudder, throttle, shakers, etc.
    -movement calibration in Mover.
    In the worst case when all of this will not work I have a nice tube frame for a gokart or something :D
  8. GettinBetter
    CAD Engineer
    Kent, UK
    594Coins
    Thats looking pretty cool, great effort on the frame.
    You've already had the base working, so the rest should be plain sailing. :grin
    Look forward to future progress.
  9. TheTakerPL
    TheTakerPL Member
    198Coins
    153,818Coins
    +11,150 / 57 / -2
  11. X.STTONER
    X.STTONER Sttoner
    business manager
    lima
    232Coins
    ElTakerPL@, thank you for the information. I'm starting to review it. I'm concerned about the configuration part you mentioned, as it's not my strong suit. If I have any further questions, I'll bother you with them. I hope I'm not being a bother.
    Once again, congratulations on your work, and I'll be following your progress.
  12. Misanthrop
    Misanthrop Active Member
    826Coins
    Really good outcome. I like the mechanical design, looks really well thought out.
  13. accelero
    accelero Member
    france
    287Coins
    2DOF, AC motor, Arduino
    really impressive rig , motion seems good too, what is the tilt noise wecan hear some times?
  14. TheTakerPL
    TheTakerPL Member
    198Coins
    Barely noticable, only at full speed full range. Completely silent during play.
  15. accelero
    accelero Member
    france
    287Coins
    :thumbs I have seen some rigs with that system that use a U joint between the motor shaft ans ballscrew instead of mounting the motor on a rotating shaft, what do you prefer as the best solution?
  16. TheTakerPL
    TheTakerPL Member
    198Coins
    I don't trust u-joints. I think they will wear out quickly with constant vibrations, changing directions. Mounting whole assembly stiff with motor on a hinge seemed more robust for me.
  17. GettinBetter
    CAD Engineer
    Kent, UK
    594Coins
    When mine made that noise, I traced it to a loose bolt on the moving platform. I was only testing at the time, so will pay more attention when time for the final assembly arrives.
    Just saying.... :cheers
  18. TheTakerPL
    TheTakerPL Member
    198Coins
  19. curiousSimguy
    curiousSimguy New Member
    16Coins
    This setup is really impressive. I can definitely see a ton of work went into this project. Are you planning on release your CAD drawings and\or models? I'd love to build these type of setup. Thanks
  20. TheTakerPL
    TheTakerPL Member
    198Coins
    I'll try to do it
