Reasonably Priced 100A Motor Controllers
Discussion in 'Motor actuators and drivers' started by Richard Ortengren, Jan 29, 2023.
Tags:
  1. Bagof.stupid
    Bagof.stupid New Member
    57Coins
    I have two of these boards and they both have the same result no function on channel 2 channel one works fine. I’ve even tried a second Arduino i’ve also tried moving the pins from channel one which works to channel 2, and it will not work
  2. iLLuac4
    iLLuac4 Active Member
    891Coins
  3. Bagof.stupid
    57Coins
  4. Gadget999
    12,132Coins
    i ordered up some new drivers for a different project and guess what channel 2 is not working !
    Sadly it appears somebody has robbed the quality control failures and is distributing them to suppliers !
    however the fix is pretty straightforward
    we drilled the through hole and fitted a copper wire / rod
    Its so sad that a great little driver board has been a target of dishonesty :(
