FlyPT Mover 3.5.8
  1. michel123
    michel123 Member
    cadre sncf
    lezignan-corbieres
    192Coins
    It seems to be an access problem, the same error occurs, except that for me, half the time the app refuses to continue... in grey it tells me that I don't have access to the Flypt Mover online server.... have you a solution ??
  2. Erik Green
    Erik Green Member
    463Coins
    Same problem all this last 6-10 day. Working fine today. Did today's windows update. Lot of talk about cloud access problems that these patches were supposed to fix........
  3. michel123
    michel123 Member
    cadre sncf
    lezignan-corbieres
    192Coins
    It's good now ! thank's !
  4. Pietbrok85
    Pietbrok85 New Member
    Venlo
    47Coins
    Hello everyone, maybe someone can give me some usefull advice on next problem thx!
    FlyPTMover 3.5.3
    When starting the programm, a lot of times (not alway's) the error message: "unable to connect to remote server" (see att picture). (btw i did not select the menu share / unshare..., its comming automatically)
    When i ignore the message FlyPTmover seems to work all right, however i don't like ignoring error messages.
    Tried on a different pc, same result. Thanks for advice and kind regards, Piet
  5. Andrey Av
    Andrey Av New Member
    75Coins
    Hi.
    I found that for a pose it is possible to set a fractional number as a range, and it looks being accepted, but when I save the config and then trying to load that - it says that the fractional number is not acceptable.
    Is it a known bug?
  6. Tean33
    Tean33 Member
    255Coins
    @Andrey Av From your screenshot it looks like your using version 3.7. You'd be better to ask in the thread for that version.
  7. Tean33
    Tean33 Member
    255Coins
    With the release of Aces of Thunder imminent, does anyone know if the current War Thunder source for Mover will work with the new game?
    154,774Coins
    +11,202 / 57 / -2
    No, as access is required to determine that.
    If the same engine is used with no changes to telemetry or structure then it may well work, but even with the same engine if changes have been made affecting telemetry then further plugin work will be required.
  9. Tean33
    Tean33 Member
    255Coins
    Ah, well I might just buy it regardless and then I'll be able to report.
  10. tadeusz
    tadeusz New Member
    94Coins
    Hi
    I've been using this program for several years.
    I'm very happy with it.
    Recently, upon launching it, I received this message:
    "Mover is already running."
    Please help.
    Best regards,
    Tadek
  11. tadeusz
    tadeusz New Member
    94Coins
    Hey,
    Sorry to bother you,
    I've already solved it.
    It was caused by the program not closing properly.
    Thank you and best regards.
  12. pmvcda
    15,944Coins
  13. tadeusz
    tadeusz New Member
    94Coins
    HELLO
    I recently purchased a Moza Ab9. I'm having trouble getting FlyPt to work with the Moza app on my IL-2.
    I've completely lost telemetry in the FlyPt and I can't seem to fix it.
    Can you help?
    Best regards,
    Tadek
  14. pmvcda
    15,944Coins
    Is this happening with all the games?
    In the Moza app, can you forward the data received over udp? I think that is the problem, because they get the data for the ffb
    Alternativelyy you can also forward in Mover, but for that you need to config the games in the Moza app to ise another port
  15. pmvcda
    15,944Coins
    If you know the port used by Moza (same as Mover I think), change the il2 output to another port.
    In Mover listen to that port and forward to the original one.
    This should work for any game where you can set the udp port
  16. Tean33
    Tean33 Member
    255Coins
    The Moza software is pretty nasty in that in writes stuff into the setup and config files of games without telling you what it's doing. It would be better if it presented the user with some script that that they can copy/paste manually, but I guess they are trying to make the process as automatic as possible.
    It's always a good idea to make a copy of any of the game's config or setup files before running any install process in the Moza software so you can see what's been done and reverse the process if necessary.
    If you look at your IL2 setup file it will have a section that looks like this:
    [KEY = motiondevice]
    addr = "127.255.255.255"
    decimation = 1
    enable = true
    port = 4321
    [END]
    This the the FlyPT script. Notice the port number 4321 (I think this the FlyPT default) matches the port number in FlyPT's input source module.
    If you've run the Moza installer then there will also be this section:
    [KEY = telemetrydevice]
    decimation = 1
    enable = true
    port = 5678
    [END]
    Notice the port number as installed on my system is different. I can't remember if I changed this or not but it needs to match the port shown in the Moza config window AND be different to the port used by FlyPT.
    It's been a while since I set this up but I think there may also be an issue with order these keys appear in the setup file. If the Moza key appears above the FlyPT key then you could try copy/pasting it to the end of the text. I know I have had to do this with some games but can't remember if it's relavent to IL2.
  17. tadeusz
    tadeusz New Member
    94Coins
    Hi
    Great tip!
    Thank you very much for your help.
    Of course, you need to set the correct addresses.
    I have:
    Moza:
    addr = "127.0.0.1"
    decimation = 1
    enable = true
    port = 5678
    [END]
    FlyPT:
    addr = "127.0.0.1"
    decimation = 1
    enable = true
    port = 4321
    [END]
    Important:
    You need to find the correct path to the game,
    and I have it in two places:
    Steam:
    H:\SteamLibrary\steamapps\common\IL-2 Sturmovik Battle of Stalingrad\data
    H:\Program Files\IL-2 Sturmovik Great Battles\data
    Direct game:
    Thank you again.
    Best regards,
    Tadek
  18. Shadow
    Shadow New Member
    29Coins
    I can't find ABS input value in iRacing source. Is this value not available at all for this game telemetry or am I missing something ?
