Showroom 6DOF Stewart AC Servo Motion Helicopter Simulator Build
Discussion in 'DIY Motion Simulator Projects' started by GettinBetter, Apr 15, 2024.
  1. Aerosmith
    Aerosmith Active Member
    self employed
    2,987Coins
    3DOF, AC motor
    A simple latch circuit will do.
    Pressing the start button powers the contactor which holds itself latched in the ON position with the NO contact. An alarm or an E-stop will cut power with one of the NC contacts. For the alarm you can use a relay that is powered from all the alarm outputs of the servos in parallel, or servo-ready signals (alarm inverted) in series.
  2. GettinBetter
    CAD Engineer
    Kent, UK
    734Coins
    Thank you, I understand your thinking.
    Looking at the manual, the servos have a dedicated configurable fault output but the circuit board I have, doesn't have any connection to it, and I'm not sure if the cables have been wired internally to use those pins.
    I want to check my docs, and see what I have, before I can create a solution.
    To keep it clean, I'd like to have the servo signal define the fault, and all cabling contained in the existing cables. From memory, I vaguely remember counting the number of wires required and buying a multicored cable to suit. Whether I had any redundancy built in or not I can't remember.
  3. GettinBetter
    CAD Engineer
    Kent, UK
    734Coins
    @Aerosmith I was looking at a project on this forum by @Nicki9knuckles and this character has put gas struts on his sim to offset the weight and reduce the load on his motor.
    My first reaction to this is, it's a bloody good idea, except for longevity. I have yet to find any reliable data on gas strut MTBF (type stuff). Any thoughts?
  4. Aerosmith
    self employed
    2,987Coins
    3DOF, AC motor
    The cheapest gas struts are for trunk lids. They are build to last maybe 10,000 strokes (~10 years, 2 cycles per day) which could be reached within a few hours of sim operation. But I think they last a lot longer if operated indoors and not in the weather. Be sure to mount them upside down (cylinder at the top, rod at the bottom) so the seals stay lubricated.
    For our 3DOF two-seater project we had the same problem. 3 actuators have to carry ~300kg load which was close to the limit. So we have put 4 pneumatic cylinders under the rig near the COG to partially support the weight. They are a bit difficult to spot. See this picture * between the seats. However, with a 6DOF rig and longer stroke it gets harder to find suitable gas struts or pneumatic cylinders.
    Pneumatic cylinders have less drag and a longer life, I hope. But they are also much more expensive and need a compressor and air tank.
    Edit: * picture replaced (full size instead of thumbnail)
  5. GettinBetter
    CAD Engineer
    Kent, UK
    734Coins
    That's what I was thinking (i.e. short lifespan)
    I'll have a look round and see if there are any with a longer lifecycle.
    My plan was to have roughly 100 to 150 kgs of additional support. and divide that by 3 struts strategicaly placed so that they support each motor pair, that way each strut can be on the order of 40 kgs.
    However, I don't want too much support, so that the helo doesn't sink after powering down. So from my spreadsheet I need in the region of 100~120kgs.
    I also need them longer than the distance beween frame and base so that they are not working at their max length, but also the closed length needs to fit when the sim is at it's lowest position.
  6. GettinBetter
    CAD Engineer
    Kent, UK
    734Coins
    Got some more bits... not quite finished, but I plan to heat shrink tube them so... they're probably good enough.
    So thought about getting the cyclic control on the top of them..
    Almost but no cigar, so I can either make two new ones that are a better fit, or make one and sleeve the other. I'll see what mood I'm in when the time comes. :popcorn
    Will at some time need to identify the plug/socket to extent them....
    I also need to buy another one, ideally simpler for the passenger side, but looking on the Virpil site it doesn't look like they do one.
  7. GettinBetter
    CAD Engineer
    Kent, UK
    734Coins
    Looking around the site at some other builds, I see a reference to traveling speeds for a motion sim.
    Running through some calcs I get 637mm/sec, which on first glance is good.
    However, the max RPM of the motor is IMO given as no load RPM, so are these motors likely to slow down under load, and if so roughly how much?
    My thoughts are that they will maintain almost max speed under loads, until max current is reached, and then some, before konking out on overload.
    Any thoughts on this matter?
    Ordered a couple of boxes of 4/5/6mm nuts and bolts and a set of Cleco fasteners to start putting bits together. I was going to rivet it, but have a feeling I might need to take it apart now and then, for mods/access.
    Gas Struts turned up, so thats in hand, as did lots of electrical switches and knobs for the avionics panel.
  8. GettinBetter
    CAD Engineer
    Kent, UK
    734Coins
    I thought it must be time for an update.... :popcorn
    Done lots of stuff, but it's all related to the base frame assembly.
    Drilled the top holes in the moving platform & made the gas strut lower brackets to attach the gas struts (at a later date).
    I can't really do it yet as it'll sit too high, because of the lack of weight.
    Having laid the two centre panels out on the wooden base, I was reluctant to start drilling any holes due to them constantly moving, so I decided to assemble them as a complete standalone assembly.
    I made half a dozen spacer brackets to maintain the centre consol at the 210mm as per my survey this should allow the avionics panel to sit correctly.
    It was still bowing in places that were important building to survey, this prompted me to add some angle to the lengths, which I was going to do anyway.
    I have used wooden fixings to see where they came out, now that I see they are accessible, I will replace them with bolts.
    Pedals all done, with keyway and nylon bearings completed. I'm very pleased with the result.
    I have used some temporary bolts to attach pedals and base, but they will be here by the end of the week and I will replace the temp ones.
  9. GettinBetter
    CAD Engineer
    Kent, UK
    734Coins
    Little update. :)
    Bought some 4mm tool bits with hex shank, to help drilling close to the walls of the panels.
    Removed all temp wood screws and replace with rivets (I managed to get some 30mm long to go through the base) and with a washer on the underside worked very well.
    Also replaced temp bolts in pedals for some nice button head ones, and the temp base fixing bolts were replaced with countersunk ones.
    In my excitement, I laid out a few of the other parts, that will be completed in the next couple of weeks.
    I need to finish machining the other bearing housing to get the mounts for both ends finished wich will allow me to confirm the main cyclic shaft position.
    We're getting there.... :popcorn
