F1 like 3DOF Simulator with heave
Discussion in 'DIY Motion Simulator Projects' started by _cOdaC_, Jun 25, 2024.
  1. _cOdaC_
    _cOdaC_ Member
    341Coins
    I've tried that before, cause as soon as I put a cable from PIN8 to GND on the Arduino Uno, SMC3Utils won't beable to open up a communication "Could not establish comms with Arduino SMC3, Abort, Retry, Ignore".
    Thats weird, cause the Sabertooth is set to 115200 baud with DEScribe.
    154,418Coins
    +11,181 / 57 / -2
  3. _cOdaC_
    _cOdaC_ Member
    341Coins
    I'm using SPS 8.2 softstart from this tutorial.
    The code says:
    Code:
        // set the data rate for the SoftwareSerial port
    #ifdef SECOND_SERIAL
        mySerial.begin(115200);
    #endif
    #ifdef MODE3
      pinMode(8, INPUT_PULLUP);
      pinMode(9, INPUT_PULLUP);
      pinMode(10, INPUT_PULLUP);
      pinMode(11, INPUT_PULLUP);
      pinMode(12, INPUT_PULLUP);
      if (digitalRead(8) == HIGH){
        Serial.begin(500000);
    else
      if (digitalRead(9) == LOW){
        mySerial.begin(19200);
        ST[0].setBaudRate(115200);
        ST[1].setBaudRate(115200);
        mySerial.end();
      else if (digitalRead(10) == LOW){
        mySerial.begin(38400);
        mySerial.end();
      else
        mySerial.begin(9600);
        mySerial.end();
    So yes, I would expect, jumpering PIN 8 and GND, the Arduino would be set to 115200 and otherwise run with 500000 Baud.
    I think I'll open up the Arduino IDE and try to see if the console using 115200/500000 baud shows something useful.
  4. _cOdaC_
    _cOdaC_ Member
    341Coins
    Ok, so I could prove that jumpering PIN 8 and GND leads to the Baud rate getting set to 115200.
    Testet it with a simple Outut to the Serial Monitor in Arduini IDE. 115200 was readable, 500000 not.
    The Code works, but still, SMC3Utils won't connect with a Baud rate set to 115200 but only with a Baud rate of 500000.
    Do I need to use another version of SMC3Utils? I'm using version 1.01 of the mentioned thread.
  5. _cOdaC_
    _cOdaC_ Member
    341Coins
    I'm really struggeling getting my motors run properly.
    During my tests, I noticed that the rear center motor is carrying significantly more load than the two front motors.
    Although I determined the Center of Gravity according to the tutorial, it's possible that it shifted backward unnoticed during the installation of the upper rig along with the lower frame.
    This, combined with the fact that I tested with incorrect/poor values using SMC3Utils, led to this motor overheating and (still to be verified) likely sustaining damage. The motor had to withstand temperatures of approximately 110 degrees Celsius for an extended period of 1 to 1.5 hours.
    I will now re-measure the Center of Gravity.
    Regardless, I'm finding it extremely difficult to correctly configure or PID tune the motors.
    My motors are vibrating excessively, and I can't find any step-by-step instructions or criteria to determine whether the set values are correct and final.
    I'm having real trouble making progress and want to prevent further damage. I would be extremely grateful if someone could guide me here or provide a tutorial.
  6. Sebastian2
    Sebastian2 Active Member
    515Coins
    Ooof, sounds like you are having a really tough time there.
    I suggest starting out simple and then increase complexity step by step. Here is what I would do.
    1.: Remove the load from the motors. Don't have them mechanically connected to anything. Electrically disconnect the motors from the drivers. Mechanically disconnect the pots from your motors. You need to be able to move them by hand.
    2.: Without any parts moving, check if your pots deliver a steady signal to SMC3utils. Take a look at the diagram to see if the signal is noisy. The green feedback line should be steady.
    3.: Turn the pots by hand. Does the green line in SMC3utils behave as expected? Turn the Pots all the way you expect them to move during operation. Does the signal keep moving steadily or are there sudden jumps?
    4.: Make a very basic setup in SMC3utils like this:
    Fpid: 1 (or higher, if your driver needs that)
    Kp: 100
    Ki: 0
    Kd: 0
    Fpwm: 25 kHz (or whatever your driver needs)
    PWMmin: 0
    PWMmax: 255
    PWMrev: 0
    Max Limits: 255
    Clip Input: 255
    Dead Zone: 0
    5. Again, turn the pot by hand. When the green feedback line is at the same value as the blue target line, the yellow PWM line should be at 0. The more you move the green feedback line away from the blue target line, the higher the yellow PWM line should go.
    6.: Reconnect power to the motor. Leave the pot mechanically disconnected to the motor. Now, by turning the pot, you should be able to control the direction and speed of the motor.
    7.: mechanically connect the pot to the motor. Perform the steps described here, under the section "initial setup": https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/
    Please report back with how much of the described steps worked for you. This will help with further diagnosis.
  7. _cOdaC_
    _cOdaC_ Member
    341Coins
    Ok,
    1. I have removed the load from the motors, its just the levers that are still attached.
    2. Please see the attached Screenshots showing a steady unnoisy green line.
    3. Please see the movement of the pots of motor 1 and motor 2 (motor 3 follows) with motors being OFF
    4. I have set these values for all my motors.
    5. Please see the movment of the pots of motor 1 and motor 2 with motors being ON. Motor 1 runs good but at motor 2 as soon as it starts increasing the speed (softstart) the Arduino loses its connection to my pc and the graph stops. So seems like I have an issue here already somehow connected with the power that the motor increasingly consumes.
    6. For motor 1 its true, motor 2 has an issue getting faster in rotation.
    7. I will do that later, first I wanna find out what the issue with motor 2 is. Further more I'd like to swith the POT to the oposite direction of motor 2, so that it is at the same side as motor 1.
    Add: I just moved motor 3 in manual mode and the result was the same as with motor 2. so there was a peak of the yellow PWM line and the Arduino lost the USB connection to the PC.
  8. Sebastian2
    515Coins
    Unfortunately, I can't watch the youtube videos you have uploaded. It says they are set to private.
    You mention softstart. This sounds like you are using a non-vanialla version of SMC3. To kepp things simple, I suggest you use vanilla SMC3 for now. When the basics work, you can switch to other versions of SMC3.
    I suggest you investigate why the power draw of motor 2 and 3 leads to connection loss of the arduino. How is the arduino connected to your PC? Are you using a powered USB hub? You could try a passive USB hub or connect the arduino directly to your PC. What kind of PSU are you using? It could be that it sends electrical disturbances into your power grid.
    Also, make sure that the USB cables are not directly next to cables that are powering your motors (neither the 220V cables running to your PSU, nor the 12 or 24V cables running to your drivers or your motors). I keep at least 4 cm space between them (they run on different sides of my 40x40 aluminium extrusion profiles).
  9. _cOdaC_
    _cOdaC_ Member
    341Coins
    Ok, I have updated the settings, please check again if you can watch the videos.
    I'm using SPS 8.2 softstart from this post as I'm using Sabertooth and no Monster Motor Board or separate H-Bridges.
    Both Arduinos are connected by USB to a passive USB-Hub and the USB-Hub is connected to my PC.
    For two motors I'm using a 2000W, 24V PSU, for the single motor I'm using a 1000W, 24V PSU.
    The USB cables are routed separately from the power cables (24v and 220V), I've attached Ferrit magnets to the power cables and the usb cables. Furthermore the wires to the pots are shielded.
  10. Sebastian2
    515Coins
    Your wiring sounds solid, so I think it's more likely you are having softwares issues.
    I suggest giving vanilla SMC3 a try. I don't know how well this works actually controlling your sabertooth drivers, but for investigating the connection loss this isn't important. If the connection loss doesn't happen with vanilla SMC3 you know it's an issue with the fork you are using. Then you can talk to the guy who made it or dive into the source code yourself.
    The videos you've posted regarding #3 on my list seem fine to me. The video of motor 2 regarding #5 shows the connection loss. I assume you kept turning the pot even though the video shows a constant green line after about 13 seconds?
    I notice that the connection loss appears the moment the yellow PWM line meets the green feedback line. Does the connection loss always happen at this moment? What if you turn the pot the other way, so the green feedback line goes down instead of up? The yellow pwm line will then meet the green feedback line sooner - Does the connection loss also happen as soon as both lines meet?
  11. _cOdaC_
    _cOdaC_ Member
    341Coins
    Yes I‘ll give SMC3 a try and report back.
    Your assumption is right, I kept turning the POT and the connection loss is what you see.
    What I can‘t get out of my head is the bit about the breaking current. Yes I‘m using 6,8 Ohm/100W Resistors but the soldering was tricky so maybe here is an issue where theyre probably not doin what theyre supposed to do.
    Furthermore I‘m not using a battery, hence the resistors. I start thinking that a battery is pobably the better solution?!
  12. Sebastian2
    515Coins
    I don't think the breaking currents play a role here:
    1. The first issues arise on #5 on my list of steps to take. There, the motor isn't even powered.
    2. Even if the motor was powered, breaking current should not interfere with the connection of the arduino to the PC.
    3. Even if such an interaction would take place, braking current would only happen if the motor slows down. But your video shows the arduino loosing connection while the yellow PWM line is going up (so if the motor was powered it would accelerate).
  13. _cOdaC_
    _cOdaC_ Member
    341Coins
    Ok, I have set up the Arduinos and the USB-Hub to their own power supply.
    The USB-Connection between the Arduino Uno and my PC is now for data transfer only.
    The SMC3 Code won't work with my Sabertooth, because of the PINs/Wiring.
    The Sabertooth has only one cable from S1 to Arduino PIN 13 and 0V to Arduino GND.
    The code says:
    Code:
    // Set to MODE1 for use with a typical H-Bride that requires PWM and 1 or 2 direction inputs
    // Set to MODE2 for a 43A "Chinese" IBT-2 H-Bridge from e-bay or equiv
    The H-Bridge (Mode 1 or Mode 2) require ENA,ENB, PWM connections for the motors. A Sabertooth doesn't have the PINs for that.
    Today i did quite some measurements to figure out where the electric disturbances might come from.
    The weird thing though is, that after the Arduino and the USB Hub have their own power supplies now, I followed your mentioned steps again, and this time Motor 2 was as smooth as Motor 1. Means even with rapid changes of directions I measured constant 24V on B- and B+ of the Sabertooth (the connectors for the PSU) and the Arduino didn't reboot (probably due to its own power supply), but I didn't measure any disturbances.
    The motors are ground isolated as well, that I could measure. And the clamps for the breaking current seem to do their work, I get the expected OHMs Between B+ and P1/P2 on the Sabertooth.
    I made sure that the settings in DEScribe for the Sabertooth are correct.
    Baud Rate is set to 115200 baud
    Disable regenerative braking is inactive (so regenerative breaking is active)
    I set the current limit from 60A per Motor to 22A per Motor, just for safety
    And Motor 1 and Motor 2 are set to Voltage Clamp mode.
    The timeout is set to 100ms (value = 0.01)
    If it is fine with you I'd like to continue with SPS for Sabertooth with Packet Serial as 31 pages of feedback make me beleive that this clone is stable.
    In the end all it does is using packet serial and the same code for the h-bridges converted for sabertooth and added a softstart, meaning that the motors wont start immediately with full power but increase speed in just a couple of seconds.
    The Tutorial for testing the whole set up are mostly exactly the same.
    Meanwhile I figured out why my motor in the back got so hot.
    I made a mistake placing the CoG incorrectly. My base frame is Y shaped and each arm is in 120° degrees to another. My mistake was to place the CoG to far to the back of the frame. It has to be placed in a 1/3 to 2/3 distance though.
    So let's say the two front motors (left and right) are in a distance of 69,28 cm to each other and the distance of each of the three motors to the Y center is 40cm. Then the CoG needs to be 20cm behind the front axis (distance motor left to motor right). The motor in the back needs to be 40cm behind the CoG or 60 cm behind the front axis.
    I'm currently waiting for some parts that I want to replace, before I continue testing. I'll be back in a couple of days.
    154,418Coins
    +11,181 / 57 / -2
    There is SMC3 code specifically for Sabertooth, please see the FAQs here: https://www.xsimulator.net/communit...ket-serial-pid-motor-driver-for-arduino.9277/
  15. _cOdaC_
    _cOdaC_ Member
    341Coins
