Tutorial How to convert your Frex SCM to SimTools - Updated
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by MasterYoda, Feb 21, 2009.
  1. Nima
    Nima Member Gold Contributor
    Glaser
    Bad Zwischenahn
    532Coins
    hi,
    is the same actuator but frex has 100 mm scn5 the most other have 150mm
  2. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    The wiring is also different! The Japanese use a different standard for kill functionality than we do! Wiring Japanese actuators with the pics in the SCN5 thread will not work. Wiring them by MaserYodas config will work. The difference is that the ILK voltage is opposite.
  3. punsher
    punsher New Member
    0Coins
    HI folks i have a problem descibet there: problems-with-my-frex-motion-seat-t3236.html#p32770
    The most problems where fixed and the test worked already.
    but the connection between simconbase and rfaktor does not work.
    i already tried it without spaces in the profile names but it does not work.
    do you guys have any suggestions for me?
    I think before i try to convert my system to x-sim i need to get it work with frex.
    i hope you can help me ;)
    cu jose mendiola
  4. MasterYoda
    MasterYoda Active Member Gold Contributor
    Portland/USA
    322Coins
    2DOF, SCN5
    Jose,
    As already stated by Ego (in the other topic your referenced to), if you need Frex hardware or software support, you should contact Frex. :sos:
    The Frex forum to discuss issues with Frex hardware is here: http://frex.xsrv.jp/xoops/modules/newbb/
    However, x-simulator.de is the right place if you decide to convert to X-Sim someday, to get increased motion qualtiy with your SCN5 actuator setup.
    Cheers,
    MY
  5. punsher
    punsher New Member
    0Coins
    hello,
    yes I've also made ​​at frex forum, only because I get no answer so I just try to come with you to the info ....... I will convert to make any case but first I have to bring it to the run so I can make a picture of how it fills. ;-)
    thanks anyway
    Jose Mendiola
  6. TommyTrauma
    TommyTrauma New Member
    Indianapolis In
    1Coins
    Hi everyone. I signed up here a couple of years ago, and have finally decided to jump ship on Frex. Sorry Shige, tired of waiting on service. Some of you might remember me, I painted up a X-Sim Porsche a long time ago for GTR2. I just need to know if the link below is all I would need to convert my Frex equipment over to X-Sim? I read through the first post and it lead me over to egoexpresses cables post. Do I need those too? Just tell me exactly what I need to purchase and if I can just buy the whole kit here or not to do a nice easy plug n play conversion please. I know I need the software and will get it downloaded and ready.
    Thanks everyone. Tom
    ..edit.. I couldnt remember my old login details, so I just rejoined.
    http://www.x-simulator.de/wiki/Image:Adp1access.jpg
  7. TommyTrauma
    Indianapolis In
    1Coins
  8. TommyTrauma
    Indianapolis In
    1Coins
    Hi everyone. Is there still anyone that is making the conversion cables for the USB adapter so I can get rid of my Frex controllers, and switch over to X-sim softwre or even Korres Logykal software? I'm tired of waiting for Shige to release new driver updates.
    Thanks for any help.
  9. bsft
    ask here
  10. Mif
    Mif Member
    Seattle, WA USA
    - 8Coins
    2DOF, SCN5
    So this thread is titled outdated. Is there a newer preferred method to convert from Frex? I have ordered the adapters, but I am still looking at the best way to make the cable harness.
    Anyone still doing this or has done it recently that can point in the direction of the necessary parts?
  11. RaceRay
    Hamburg, Germany
    23,892Coins
    The electronic parts and connections are still valid but we use a new software called simtools. When u succesfully finish your scn powering it would be helpful when you than write a new tutorial about it.
  12. Mif
    Mif Member
    Seattle, WA USA
    - 8Coins
    2DOF, SCN5
    Sounds good. I will work on that. If anyone has a source for the molex connections and wiring so that I don't have to cut into my frex harness it would be appreciated!
  13. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Ok! Updated the tutorial today with what I learned in these last two days using SimTools.
    So, there might me some things that can be improved.
    I need to make a new video, will do it after I finish some changes in my setup here...
  14. eaorobbie
    20,506Coins
    Thanks @MasterYoda the Frex guys will love this. Thanks.
  15. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Added few more tips on how to setup SimTools for your SCN5's... :)
  16. Mif
    Mif Member
    Seattle, WA USA
    - 8Coins
    2DOF, SCN5
    I can't seem to get any motion out of my SCN5's with this new setup. I got the RS485 adapters and actually got new custom cables directly from FREX for about $65 shipped to the US.
    I did notice with the new cables that the actuators dont move and center when power is applied like they used to, not sure if thats normal or not.
    Any hints I may have missed?
  17. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
    Milf,
    Could you send us some screen shots of your Com ports configuration as well Axis and DOFs configurations (similar to the ones I posted in the tutorial)?
    Actuators should move when you start the Game Engine, they go all the way up, down and then center fast!
  18. value1
    14,274Coins
    Is this a spelling mistake or are you spending too much time in other forums?
    :p
  19. Mif
    Mif Member
    Seattle, WA USA
    - 8Coins
    2DOF, SCN5
    Oh jeez. I get that "typo" all the time. Here are my port setups. I am using cables that I got from FREX, so the wiring should be the exact same as what comes off the actuators.
  20. Mif
    Mif Member
    Seattle, WA USA
    - 8Coins
    2DOF, SCN5
    Incorrect settingsthere, its actually set Latency Timer as 1ms and Set RTS on Close is also checked. Still no movement.
