SCN5 Racing Rig Schritt 2
Discussion in 'DIY Motion Simulator Projects' started by Henning Piez, Aug 29, 2010.
  1. BartS
    BartS Member
    417Coins
    Looks great with nicely timed and accurate movements.
    How does it feel to drive?
    A superb looking and motion sim in my opinion A+++++
  2. Henning Piez
    Henning Piez Member
    Stuttgart
    17Coins
    Hm, how should I say it. The motion looks very good, precise and defined and it feels even better, but... hm, there is no x-sim anymore powering this rig. I am testing a new software because the silence here in this forums afraids me, and this software feels so much better. My old profiles felt spectacular but they never felt precise and realistic like the new ones. . Now I believe my rig what it is doing.
    If someone had let me testride the same rig but said he had upgraded some hardware for movement enhancements I would have spend 2000 Euros after that test ride, just because of that big difference.... But it was only software that was changed.
  3. bsft
    what software are you using now?
  4. Henning Piez
    Henning Piez Member
    Stuttgart
    17Coins
    AW: SCN5 Racing Rig Schritt 2
    The Alpha version of the Sim Commander 3.
    Gesendet von meinem GT-I9000 mit Tapatalk
  5. RaceRay
    Hamburg, Germany
    23,876Coins
    Schaut wirklich super aus..... :) Bemerkenswert, dass die dritte Achse soviel Mehrwert bietet.
    Grüße aus dem Norden
  6. Hardsteel73
    Hardsteel73 Hardsteel73
    Self employed
    bergschenhoek
    162Coins
    At Henning Piez:
    I saw a movie of simcommander 2.... damn that goes easy....does that also work with
    AMC + H-brigde and wipermotors?
  7. bleco
    bleco Member Gold Contributor
    IT Problem Coordinator
    Montréal, Canada
    258Coins
    Commander 2 is not compatible with wiper motors and 3 won't be either. Only compatible with scn5-6 ... It was also very unstable on my Win7 64 and I hated it ...
    Hope Commander 3 is more stable with a better interface ...
    @Henning Piez: your rig looks amazing ...
    Bleco
  8. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    @ Bleco - I would have appreciated a bug report :)
    Of the several thousand users running Commander 2 for X-Sim, there are no known stability issues reported so I suspect yours is an isolated incident that we probably could have resolved rapidly.
    As to Commander 3, it was developed on and for Windows 7 so no WIndows 7 related issues are expected or have been identified in early Alpha testing.
  9. Henning Piez
    Henning Piez Member
    Stuttgart
    17Coins
    And even in Alpha stadium I couldn't find many bugs, some translations here and there and some new ideas.... Works great. Sim Commander 3 will be a great step for motion drivers, I myself never liked the Commanders, because they were based on X-sim. Now the Commander has it's own heart, or better soul. I think you can even see the much more fluid motions, all mixed in effects can be set to different speeds, different travel ranges etc. And, I do one profile for my 3DOF in less then 15 minutes without having to think about it.
    All Effects have a fixed name, no number anymore, and so G-Force Braking is G-Force Braking in every game, so you can use every profile in every game now, you just have to click on the Name of the game in the profiles properties.
  10. bleco
    Montréal, Canada
    258Coins
    Hi Bernard!
    Your pretty fast on the replies! I like it! :)
    This is getting off topic but you are right I could have contacted you, sorry about that ... I experienced a lot of freezing issues in the software and at some point x-sim was not reconizing my actuators at all... There was also something that could not be uninstalled and I was always getting an error with absolutely no details at Windows session startup. After looking at the process it pointed to a simxperience temp folder with missing file. Sorry I can't remember exactly all the details ... I could have added that not because I didn't liked it that it makes it a bad software... not at all ... some great ideas to simplify all the 'get it the game with motion' process were there ... But for me it was not necessary and I prefered spending time on learning how to use x-sim then to debug the Commander 2, I did not liked the interface a lot.... That being said, I can't wait to try your new Commander 3 ... And if you create game plugins as fast as you reply to post then I am sold! send me the sx-3000 kit!! :D
    @Henning Piez: It takes no more then 10min for me to create a very smooth from stratch profile with x-sim. It becomes pretty easy once your used to it. The best is to use profile creation templates. It doesn't take too much recording to get very good values on specific tracks ... You can also easily rename your g-force effects entries...
    Cheers!
    Bleco
  11. bvillersjr
    Ohio, USA
    438Coins
    That would make sense. The Commander 2 for X-Sim implemented timing setitngs that run well with the SX-3000 but are far too agressive for most off the shelf RS485 adapters. This would manifest itself surely as dropped actuator conections or failure to calibrate and possibly as overal stability issues.
    Soon you'll be able to test with the Commander 3 and we can go from there with your issue.
  12. bleco
    Montréal, Canada
    258Coins
    ... Not actuator freezing but Commander2 interface freezing...I was not even sending data when freezing occured...
    Bleco
  13. bvillersjr
    Ohio, USA
    438Coins
    I'm sure glad that the thousands of other users who were unable to figure out how to use X-Sim direclty didnt have these problems with the Commander for X-Sim or my Inbox would be full!
  14. bleco
    Montréal, Canada
    258Coins
    ... If you say so...
    Lets not ruin this topic and lets get back to it..
    Thx.
    Bleco
  15. Henning Piez
    Henning Piez Member
    Stuttgart
    17Coins
    Because my old pictures server (.mac from apple) stopped service here some new:
    here you go:
    more pictures here (and some more gallerys with all construction pictures with details)
    http://s1066.photobucket.com/albums/u413/PiezSim/Final Rig Showcase
    Panorama aus 3 Bildern, daher die miese Qualität
    http://www.youtube.com/watch?v=2srJXTwnRy4&list=UU9_0l62A-wQUU59XDqkZJiA&index=4&feature=plcp
  16. cruiser
    cruiser New Member
    0Coins
    Hallo Henning,
    Dein RIG ist einfach nur genial! :clap:
    Gerne würde ich eine Stückliste besitzen und das ganze im CAD aufarbeiten.
    Und dann natürlich nachbauen :D !
    Jetzt wo Du langsam fertig bist ( Ich gehe davon aus das Du immer wieder ein paar Kleinigkeiten findest, die Du verbessern möchtest), hätte ich Dich gerne gefragt, ob Du es nochmal genauso machen würdest oder aus Deiner Erfahrung heraus gleich das simxperience Paket Nr4 nehmen würdest?
    Auch im Bezug auf die Kosten?
    Gruß Stefan
  17. Henning Piez
    Henning Piez Member
    Stuttgart
    17Coins
    Wusste gar nicht mehr, dass das alte Forum neben dem neuen noch existiert.... Und warum gehen die alten Accounts nicht im neuen, warum wurden die wertvollen alten Projekte nicht übernommen?
