KIKO's Wiper Motor SIM
Discussion in 'DIY Motion Simulator Projects' started by Kiko Tocci, Mar 3, 2011.
  1. rafael_design
    rafael_design Member
    CGI Architectural Visualizations with Blender 3D
    Brasil
    329Coins
    :hi:
    Sorry I did not realize that you mean to connect to a notebook.
    I wanted to do it too, but as the compatible USB cable I found was $ 42,50 I decided to use my desktop and connect straight to the MB.
    digimer.com.br do have the cable you want.
    regards!
  2. Kiko Tocci
    Kiko Tocci New Member
    Brazil
    349Coins
    Actually that was my problem because I do not have a machine with serial output available at home.
    From what I've been reading, I can use a netbook, just to run the engines, will give this information?
    Then I want to connect a powerful desktop to run the games.
    For all the forums ......
    Regarding monitors or projection, what are you thinking of using?
    I am going to choice of projector, what do you think?
    Curved projection screen, works well? What projector do you suggest me?
    Grateful
  3. Kiko Tocci
    Brazil
    349Coins
    I'm having trouble setting up my AMC.
    When I turn it to Computer and connect the two green lights are light up, but when I install ponyprog to configure the chip he calibrates normal, but then when I configure the port it says the test failed.
    What can be?
    Grateful
  4. rafael_design
    Brasil
    329Coins
    Try to restart windows and press F8. Than choose to skip driver signature imposition.
    And always run the programs as administrator to minimize chances of errors.
    regards!
  5. Kiko Tocci
    Brazil
    349Coins
    More errors to program the ATmega.
    I did the procedures required by Raphael.
    I could read the serial port, but when I read the chip, it gives a message missing or unknow device.
    What can it be?
    Does my capacitors are right?
    It may be wrong with the crystal?
    I no longer know which way to go, do you have any suggestions?
  6. rafael_design
    Brasil
    329Coins
    When I was stuck where you are, it was cable/driver related...Worked for me :)
    regards!
  7. DERIY
    DERIY Member
    RUSSIA
    - 52Coins
    Hi!
    I looked up sketches of your simulator.
    Serious attitude!
    Look at the pictures.
    In my opinion, this design is easier to do, but the effect is the same.
    Thus we have roughly the same design as in this video.
    http://www.youtube.com/watch?v=BT_Xnu-gAJU
    good luck!
  8. Kiko Tocci
    Brazil
    349Coins
    Rafael, thanks for the tip, I also think this could be it, but this is another error which I quote below, does that change anything?
    After checking all board and components, I noticed that the font I'm using to connect my AMC is 5 volts and 1 amp.
    Could it be that the reason of not being able configure the ATMEGA?
    As I said above, it recognizes and calibrates the serial port but when I read the chip it's returning a read error message as unknown device.
    Deriy, I loved his choice since I really was in doubt in relation to movements. I was afraid to lose a little sensation of strength g, but after your idea and the video you posted, I will redo the rear of the cockpit.
    Grateful and look forward
  9. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    serial cable sometime lead a problem :yes:
  10. Kiko Tocci
    Brazil
    349Coins
    Here some photos of the production of Cockpit.
    There are a few hours of work, but I hope to finish this weekend.
    Regarding the programming board, I'm still having problems, I'll buy a new serial cable to do another test tomorrow.
    Grateful for the return of all
  11. bsft
    looking good there!
    :D
  12. DOUGLASPORTO
    DOUGLASPORTO New Member
    0Coins
    up.... e isso ai brazukas
  13. fcamargo0101
    fcamargo0101 New Member
    - 30Coins
    estou acompanhando.. parabéns pelo projeto
  14. faelvasco
    faelvasco New Member
    Londrina - BR
    0Coins
    isso ai galera já solicitei os componentes para construir meu AMC estou na espera
