X-Sim Speed Controlled Fans for Racing
Discussion in 'DIY peripherals' started by splendiddd, Jan 6, 2011.
  1. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    810Coins
  2. jamesfondaq
    jamesfondaq New Member
    0Coins
    Hi..
    I am in the way to get all the hardware to make this effect on my Simulator.
    but I have a question:
    Do you know if I may use a Pololu - micro Maestro 6 channel, to activte those fan and activate another hardware like a Bass Shaker that runs with the RPM's engine?..
    Thanks!
  3. Matthias
    Matthias New Member SimAxe Beta Tester Gold Contributor
    312Coins
    Very cool project. I am Building it too. Can you please Tell me where to connect the jumper cables on the 6 Channel Controller?
  4. eaorobbie
    20,475Coins
    Member has not been here since 2012, not sure if you will get a response. Plus we don't support xsim here anymore, Only the new software SimTools which has nothing to do with XSIM
  5. chris1962
    chris1962 New Member
    325Coins
    3DOF, SCN5
    Hi Guys,
    I am new here and have a 3Dof Sim Rig with the very similar Fan System. Splendidd supported me in past to set up this fan System. After Installation of some new features I lost all my adjustments and I was not able to bring the settings back. I used the same settings like here described without any success.
    I assume there is a problem in the set up of the Pololu Mastro 6 Channel Board.
    Seams that Pololu does not communicate with Xsim and if I used for instance the Dual Com on the Maestro Control Centre I have got the error 0x010
    I really hope someone here in the Forum has the same system, because it was a lomg time a projetct on Xsim and can help me.
    Many thanks in advance
    Best regards
    151,596Coins
    +11,043 / 56 / -2
  7. chris1962
    325Coins
    3DOF, SCN5
    thanks for reply. Yes, the thread in the pololu forum is my thread. But I hope someone here has build the same fan sytem and can help me further.
    The other question is, does xsimulator software work similar than xsim?
    And is it possible to set up a fan system like this with this software?
    Best regards
  8. value1
    15,004Coins
    Hi @chris1962
    SimTools outputs the data to drive a motion platform: pitch, roll, yaw, surge, sway, heave and sometimes traction loss.
    For dashboard data like speed, RPM, petrol level, ect. you'll need the additional GameDash app.
    You can find an FAQ with many examples here.
    151,596Coins
    +11,043 / 56 / -2
    I actually think SimTools is easier to setup that Xsim and has more refined motion control, plus a really active community. The best way to find oun though is to try it for yourself.
  10. chris1962
    325Coins
    3DOF, SCN5
    Hi
    yes I will try. But again is it possible to use Universal Comport to control devices like Pololu Maestro 6 Channel board?
    Otherwise I have no chance to run my complete system.
    Many thanks
    regards
  11. Pit
    30,482Coins
    as usual @noorbeast is a gentleman :) I would describe it like that: SimTools is MUCH easier to setup (XSim never worked for me), the XSim community is DEAD. The best way is not to try it out before you will fail :)
  12. chris1962
    325Coins
    3DOF, SCN5
    Alright, understood! Sounds like a must. I will do so.
    Thanks again
    Chris :thumbs
  13. Rocket man
    Rocket man Member
    Canada
    - 325Coins
    Looks great. Never thought of doing that.
  14. daborcito
    daborcito RACING SIMULATOR
    Engineering
    FLORIDA,USA
    254Coins
    2DOF, 3DOF, SCN5, SCN6, Arduino, Motion platform
    Hi Buddy
    do you have some connection scheme for the fans?
    I will really appreciate it
    Daniel
    daborcito at gmail dot com
    151,596Coins
    +11,043 / 56 / -2
