  1. eightbit
    eightbit Active Member Gold Contributor
    Fish Farmer
    Trentham Cliffs
    183Coins
    3DOF, DC motor, AC motor, Arduino, 4DOF
    Welcome Mario:) well you have come to the right spot for your dreams!!!! there are a truck load of genius on xsimulator.net. Historiker has very pointed out some very helpful links. look forward to seeing your progress.
  2. Mario Reinecke
    Mario Reinecke New Member
    Kassel Germany
    587Coins
    Muchas Gracias, thank you guys !
    I'll check it out when im back home from work.
    edit:
    - which kind of Motors can i use with the polulu jrk 12v12 ? Which specifications must they have ?
    - is it much better feeling driving in a 4 dof than in a 2 or 3 dof?
    - will motorspecifications be the same when im running 4dof system, or could ist be smaller ?
  3. Historiker
    9,214Coins
    I only have experience with 2DoF so far (completed my first platform a few weeks ago) so I cannot say exactly.
    But for driving games adding a 3rd DoF for traction loss would really add to the immersion (IMO). Just think of drifting around a corner and having your platform also drift to the side. Hmm...I should redo my racing platform to add that....;)
    From what I have read, and experienced, 4 DoF usually includes heave or the platform raising up higher. Usually this is only for flight sims but many people also include it for racing.
    BSFT is really the JrK guru and hopefully he will chime in here. While I do have a pair of them I never got around to actually using them. I will replace the Arduino/Pololu755 setup on my racing rig with the JrKs eventually so I can use the Arduino setup for my flight sim platform project (3DoF).
  4. Historiker
    9,214Coins
    By the way, a good way to get your feet wet is to build a miniature model of your dream platform. Earobbie posted a thread, including the code helped by Aarondc, about building a miniature platform using R/C servos and an ardiuno. Once you have that built you can get access to Simtools (or just PM RaceRay now) to run it. This is what I came up with as a test setup:
  5. Mario Reinecke
    Kassel Germany
    587Coins
    Haha, that is cool. Lets take a Hamster place seat :)
    I make my decision, i'll try to build a 3dof with that " drifting feeling thing".
    I've ordered 3 JRK's 12v12 and hope to get not much trouble with it.
    Now i have to look for the motors.
  6. bsft
    Hello Mario and Welcome, I suggest you start a new thread for your planned project to we can advise.
    For motors, I suggest these http://www.motiondynamics.com.au/worm-drive-motor-12v-24v-200w-180-rpm-20nm-torque.html as the JRK , which is 12-16v can run 13.8v at 30 amps continuous all day. Enough to make these move. Or look for ebay dayton equivalent.
    Or a 12v boat winch motor, but lets see a design first.
  7. Mario Reinecke
    Kassel Germany
    587Coins
    Thank you bsft,
    ive read some older threads about 3dof where you give support before. I think i' ll build the 2dof first and check it out.( trying different motors for learningeffect) . If it runs ok, than i will mount the 3rd....
    My problem is that i have no idea how to controll that, specially the 3rd dof ( track lossing)
    I ordered 3 JrKs 12v12
    3 wiper motors
    and 3 worm Motors ( they where cheap, i think its chinese stuff)
    for testing
    Thank you,
    Mario
  8. eightbit
    Fish Farmer
    Trentham Cliffs
    183Coins
  9. eaorobbie
    20,491Coins
    Once you have a few things ready we can guide you through setting up the electrics mate and with the new software we can have you running the jrks in no time, very easy to set up , almost plug and (set the settings) play. There is no other driver on the market that is so easy to use, I discovered them in late 2009 and have been using them and recommending them since, 9 build to me name and counting, helped over 40 members in another forum to get them running, with the software here its even easier mate.
  10. bsft
    Rob is the JRK guru, I learnt from him.
  11. bsft
    Which worm gear motors are you buying?
    And yes as Rob says , we can guide you here. JRKS easy to setup and by golly they are a tough little sucker.
    When it comes to 3rd DOF, it should be a matter of assigning an axis setting and a force. Considering the team here on simtools has extracted 6DOF from every game, so a "yaw" factor should be simple.
  12. Mario Reinecke
    Kassel Germany
    587Coins
    thanks for your replie, really a nice helpfull forum :)
    I got my 3 JRK`s and my 3 wipermotors for testing today.
    i have a transformator or something like this, can i use it for a little testing?
    Only want to connect and test it with the jrks to see the motor running ?
    These are the Motors:
    sorry, to large images..
    [fixed, rgds, value1]
  13. Mario Reinecke
    Kassel Germany
    587Coins
  14. value1
    14,178Coins
    Hi Mario
    The "Stromaufnahme bei 12 V" is only about 1,2 A which results in only about 15 W. This is by far too low to move anything. You will need like 200+ watts per motor for a sim. But, well, for that price… You can use it for testing purposes or so.
  15. eaorobbie
    20,491Coins
    beware of wiper please make sure the earth is isolated from the body of the wiper, or if you mount it on a steel frame when the motor goes in reverse , it sends a positive voltage through the earth, anything else electrically earthed to this frame now has 12v+ flowing through it. BOOM, fry. not good please check them.
  16. bsft
    Should be fine but make sure wipers are earth isolated , or you could blow the JRK to hell.
    Look at the photo, test to find if the motor is earthed to the case and fix it.
    Just one of the reasons I dont use wipers anymore, earth isolation issues. testing motor.jpg
  17. eaorobbie
    20,491Coins
    Lol my pics keep popping up , cheers Dave.
  18. bsft
    i will put your name on the corner of them so they know whom really is the guru
  19. Mario Reinecke
    Kassel Germany
    587Coins
    i read about it. I`ll let check that a friend of mine, he is a Master in electronic.
    Thank you
  20. eaorobbie
    20,491Coins
    Yes its an important step a lot of people miss. Can result in failure or motors and drivers doing unexplainable things.
