Arduino UNO/Duemilanove 2dof firmware
Discussion in 'SimTools compatible interfaces' started by prilad, May 29, 2013.
  1. trust928
    trust928 Member
    brazil
    435Coins
    i think its all right now.. when the slider is all up, i got 4,80 in middle 0v in bottom -4,80
    as u can see in the video below.... the motor change direction in middle slider position in 50% it doesn't works after it goes to one side or other...
    its correct?
  2. Historiker
    9,208Coins
    Prilad, you deserve a HUGE Thank You for this thread.
    So...Thank You.
  3. trust928
    trust928 Member
    brazil
    435Coins
    a HUGE thank you? IF i was a woman definitely i would marry this guy hahaha
    so for the peoples who's gonna use 74ls08 change the (resistor for 1k)
    is not everyone that would give this full support.... u could have something for us to support u. you deserve it, u made my day loll
  4. prilad
    Dubna, Russia
    9,663Coins
    3DOF, DC motor, Arduino, 4DOF
    you're welcome ;)
  5. trust928
    trust928 Member
    brazil
    435Coins
    hey prilad sorry to boder u again...im trying to pakage all the pcb into a box.. so far so good.. but i went to run a test to see if is all okay,, and ima having some simple problems i think its in the software
    1) the pcb arduino and h-bridges are all fines.. ive double checked all...
    when i move the slider up... im not having the right voltage on in1 and 1n2
    for example....... in1 up 4,00 and dowm 1v and IN2 dont change nothing.. all components are working perfectly
    it was a suprise for me.. lets see if we can solve this thanks
  6. trust928
    trust928 Member
    brazil
    435Coins
    one thing im testing voltage without pots.. only in slider.. coz the potz are crazy even with screemed cables. may the tests without pots can be a problem :sos
  7. prilad
    Dubna, Russia
    9,663Coins
    What the PWM values you see? If PWM do not change sign (it may be if you do not connect pots and it value = 0 or 255) you should see what you see. Please give me values of PWM and SENSOR or show me video with your trouble...
  8. prilad
    Dubna, Russia
    9,663Coins
    You should not make tests without pots
  9. trust928
    trust928 Member
    brazil
    435Coins
    woww it was the pots.. now its all okay.. im gonna build a small box to put these things :thumbs
    have fun weekend has arrived. buy a beer lool:cheers
  10. Historiker
    9,208Coins
    Take some good high resolution pictures of your boards before you button them up into an enclosure and share them here. ;)
  11. trust928
    trust928 Member
    brazil
    435Coins
    ohh here it goes the boards are not connected in these pictures ... and the 2 h-bridges one done with fan and the other with nothing yet....
  12. taugu
    taugu New Member
    - 58Coins
    Arduino, 4DOF
    yours post are greate, anf help me a lot, i did test on x-sim and arduino and 4 servo hitec as prototype, and i bougth a 1 vfd siemens micromaster 420 for trying. Do you think if i can perform test in AC moto 3 phase using SMC3, thanks Prilad
  13. taugu
    taugu New Member
    - 58Coins
    Arduino, 4DOF
    do you think arduino uno can suport 4 motors or a have to use arduino mega sim.jpg
    from Brasil
  14. eaorobbie
    20,488Coins
    Uno can support 4 servos easily, plugged directly into the UNO , just needs a 5v power supply plugged into the UNO.
  15. doctorxeno
    doctorxeno Member
    607Coins
    What to fill in to use simctrl firmware with simtools at interface output?
  16. Historiker
    9,208Coins
    AB<255><Axis1><Axis2>
    • Useful Useful x 3
  17. eaorobbie
    20,488Coins
    An Interface setting file would be handy for him to be able to download and drag and drop into the Tools in SimTools Game Engine. Maybe placed into the first post for newbies to pickup and get moving quicker in turn we can collect these settings and once confirmed by a couple of people that they are good, we can attach them to future releases of SimTools for all to use. Just makes life easier for more.
  18. DDU
    DDU New Member
    Melbourne
    908Coins
  19. prilad
    Dubna, Russia
    9,663Coins
    No, my current firmware version not support monster moto stacked on Arduino. But I work on next version with support this feature.
  20. DDU
    DDU New Member
    Melbourne
    908Coins
    That would be great! It would make for a quick & easy solution.
    What motor drivers does it support BTW?
