Motion Simulation Software SimTools SimTools v2.6.1
SimTools Release Version
  1. yobuddy
    51,521Coins
    the K8055 is pretty old now, and while we could add an interface for it, the people using it would be better served to move on to a Kangaroo x2 as they are so cheep!
    But I do realize that this will not work for everybody.
  2. yobuddy
    51,521Coins
    @Balles - SimTools uses one SCN per adapter.
    With the ID of the actuator being the factory set '0'
    you should have 2 interface setups with a different COM port set to each.
    maybe this will help you?
  3. bsft
    no support for K8055, too slow a board, upgrade to ard, kangaroo, and or simaxe.
  4. CraCk
    CraCk Member Gold Contributor
    Made in Ukraine
    670Coins
    GameManager does not work without internet connection. Status Not conected. Please do not make SimTools dependent on internet connection. Do not repeat the errors of both X-sim3!!!
  5. Historiker
    9,205Coins
    Hmm.....mine works without a connection. The "Not Connected" Message means that the Game Manager does not see Game Engine running. Has nothing to do with internet connection.
    Both Game Manager and Game Engine must be loaded to use SimTools.
  6. eaorobbie
    20,502Coins
    Correct Historiker, both the game engine and manager need to running in order for the connected to show, this has nothing to do with internet connection at all. Its stating whether the game engine is connected to the game manager and actual has 3 states , all explained in detail in doc like the other software didnt have, we have full docs on site mate.
  7. CraCk
    Made in Ukraine
    670Coins
    If the firewall block the connection. Then GameManager has Status Not conected
  8. Historiker
    9,205Coins
    I think that is an internal network issue. I am not sure, as I am not a programmer, but I think the game manager and the game engine communicate via your own network. This is to allow the game manager to run on one computer and the game engine to run on another one. Personally I only use one computer but it is a good feature to be able to use networked computers to save on system resources.
  9. ericRacer
    Pilot
    Canada, Quebec
    952Coins
    Question about serial communication, i want to send to my arduino 2 axis : <Axis1><Axis2>
    but if i want to add a start bit like "AB". Do i need to add quote or something else ?
    ex: 'AB' <Axis1><Axis2>
    and if i want to send only a number :
    'AB' <Axis1><200>
    thanks
    Eric
  10. RacingMat
    21,081Coins
    Salut Éric!
    No need to quote or something else
    AB<axis1>200
    Have a look to Quick start guide (see in my signature) there are arduino setup example.
    Yours
    Mathieu
  11. eaorobbie
    20,502Coins
    that is connecting to the forum to check the splash screen, this is a site thing for info to be shown to users if not avail or you block it , up to you, no information is checked on it at all, it should continue and load the offline screen, its an info screen nothing else to fear.Sorry for the confusion.
  12. eaorobbie
    20,502Coins
    No mate AB<Axis1><Axis2> is right no quotes needed. for example if axis 1 is 255 and axis 2 is 155, it will send the string AB255125 depending on how you set it to go, binary,decimal, etc.
  13. eaorobbie
    20,502Coins
    From picture its connecting to xsimulator.net / 178.63.100.131 tcp 80 (http) the loading of the splash screen.
  14. RaceRay
    Hamburg, Germany
    23,884Coins
    Yea i see it now. Had been on the way with my phone and did not zoomed the image.
    Edit: Did a short notice in the download description of SimTools. Maybe should be done in the documentation as well.
  15. ericRacer
    Pilot
    Canada, Quebec
    952Coins
    Thanks ! :thumbs
  16. bsft
    that looks like antivirus blocking it. try disable antivirus and give it a go. Make sure its allowed through windows firewall as well.
  17. yobuddy
    51,521Coins
    Just so it has been said, there is no internet connection needed to use SimTools!
    But if you have a internet connection, you will get a live splash screen with current news and links to the doc's.
    requiring an internet connection for software like this would be a mistake. :D
    I'm not against adding support for the K8055 btw.
    They look to be "Unintelligent" controllers?
    Meaning that the PC actually is the brains of the controller.
    If this is true then a separate app that controls the k8055 is the way to go.
    And SimTools is built to do this.
    Take a look at this.
    Setup Game Engine like this.
    1) you can assign output of the axis anyway you want - but here is an example.
    2)Setup Net output to the app
    3)run my attached vb.net example app.
    Then use the output testing in Game Engine and you will see the app come to life.
    So my question is, Since I don't have a K8055, does anyone with one want to take a shot at taking it from here? I'm more that willing to help. I just don't have one to get it working.
  18. Niko77
    Niko77 Member
    343Coins
    3DOF, DC motor
    @yobuddy,
    i will test, i have 2X K8055 for my 3 DOF.
  19. yobuddy
    51,521Coins
    @moaale
    AB<255><Axis1><Axis2> with 8bit Output Bit Range
  20. eaorobbie
    20,502Coins
    Thanks mate I have one too but a too much on me plate to play with it.
    Only issue i see is we have to pid control it via the app as dustin states it doesnt actual do any thing but switches connection and can read two pots, the app need to manage the card in total.
