Arduino uno wiring diagram
Discussion in 'SimTools compatible interfaces' started by hooshang, Nov 9, 2013.
  1. hooshang
    hooshang Active Member
    275Coins
    @eaorobbie
    ok lets back to my set up again freind
    cause i already have another Arduino uno board
    programmed with Racingmat code and i just
    had data to my pololu drive and motors so
    so simtools and connections and motor drivers
    work fine and here is my last setting for my new board with
    Prilad code:
    altough when i click green turn on botton in output testing
    the RX led on the board turn on,but still no data come to the board:think
    thank you
    Hooshang
  2. hooshang
    275Coins
    by the way my windows is 7/32 does it play a role?
  3. prilad
    Dubna, Russia
    9,666Coins
    3DOF, DC motor, Arduino, 4DOF
    No.
    Lets go step by step:
    1 - Upload firmware to Ard by XLoader.
    2 - Unplug Ard from PC and plug in again.
    3 - Start xSimCtrl.exe and setting up COM port. Pick checkboxes and try to receive data from Ard.
    4 - If all previous steps have passed, exit from xSimCtrl and reset Ard and start SimTools.
    5 - In SimTools you should set up interface like this.
    6 - let me know about results.
  4. hooshang
    275Coins
    @prilad
    hello freind
    i have done first 3 steps and all seems going to be smooth!?
    and then did steps 4 and 5 like this
    still no data:think
    regards
    Hooshang
  5. prilad
    Dubna, Russia
    9,666Coins
    Try, please, FW with 9600 and 57600... And do you use btn "SAVE" after setting interface parameters?
    I a little taken aback, to be honest...:blush
  6. hooshang
    275Coins
    @prilad
    i tried both 9600 & 57600,but no communication
    and yes i use SAVE btn after setting and let say
    i have done this setting succesfully several times with AMC 1.6
    and also Arduino uno with Racingmat code but your code
    has much better and smoother signal to the motors but
    unfotunatly problem with sending data...:(
    thank you
    Hooshang
  7. prilad
    Dubna, Russia
    9,666Coins
    Today I have checked communication. And make new Firmware versions. Can you check it?
  8. hooshang
    275Coins
    @prilad
    many thanks prilad
    i've checked all new firmware,
    still silence...
    regards
    Hooshang
  9. prilad
    Dubna, Russia
    9,666Coins
    It's very strange. Yes, I found problem in my firmware with SimTools compatibility. But new version works fine. Try with output type "binary".
    I'll try to create video later.
  10. hooshang
    275Coins
    yes,desprately strange to me too!!
    1- pc windows 7/32
    2- Arduino uno r3
    3- dual motor driver pololu vnh2sp30
    4- simtools
    all works fine with other firmware and comunication is compelet.
    regards
    Hooshang
  11. hooshang
    275Coins
    @prilad
    do you use Ard uno r3 or previous version?
    and do u think it may come to matter?
    regards
  12. hooshang
    275Coins
    @prilad
    let say that i am sure now that there is a bug
    in your code communication with Simtools cause
    for the final test i've run same configuration with X-sim
    and it just work very well,please fix the bug, cause your
    code is great and is better to work with great simtools:cheers...
    regards
    Hooshang
  13. prilad
    Dubna, Russia
    9,666Coins
    In this video you can see Firmware (v3) worked with SimTools. I have not hardware yet, but I can controll PWM signal by oscilloscope.
  14. hooshang
    275Coins
    As you told me and I just did ,I could connect hardware with XsimCtrl2.2
    And simply transfer data but there was problem while connecting with
    Simtools, I think you are the one who knows how to deal with this bug and
    Wrap it up this for community...
    Thank you for all you have done for this nice Code up to now
    Regards
    hooshang
  15. prilad
    Dubna, Russia
    9,666Coins
    "I only want to say..." (c) JC Superstar :grin
    hooshang, let me explicate.
    Yes, in previous software version I found ("with a little help from my friends" (c) The Beatles ;)) "bug"- incompatibility with SimTools. And I have fixed this bug. And I posted video with software worked with Arduino Duemilanove and SimTools (and LFS game). And I think it SHOULD BE WORK in your SIM.
    Please, check it again. You can find SimTools interface setting on my video.
    And I ask community - can anybody else test Ard firmware with SimTools?
  16. Historiker
    9,205Coins
    I installed the firmware but have not had time to go any further than that Prilad. Perhaps tomorrow I can get a few minutes free to try to set it up?
    Thanks for your hard work.
  17. hooshang
    275Coins
    @prilad
    may this problem comes from difference between Arduino Duemilanove and uno?base on arduino.cc overview about Duemilanove...
    thank you
    @Historiker
    eagerly wating for resault of ur set up,it can help a lot freind.
    thank you
    Hooshang
  18. prilad
    Dubna, Russia
    9,666Coins
    Now I post video with Arduino UNO test. There is no difference, both boards works fine with SimTools and firmware V3 (xsim_arduino_uno_v3_by_Ale_SimToolsCompatible)
  19. hooshang
    275Coins
    ok and thank you for your efforts
    i dont have data again
    anyway somthing doesnt work properly.
    the best is that other guys in community involve and do test in different
    system and configuration,thats a reliable proof of the job:sos
    regards
    Hooshang
  20. prilad
    Dubna, Russia
    9,666Coins
    Firewall? Antivirus?
