Motion Simulation Software SimTools SimTools v2.6.1
SimTools Release Version
  1. yobuddy
    51,234Coins
    There is no reason to adjust the tuning center values, just use less % for each DOF in the axis assignments for the game.
    Also, I still have a AMC EZ that works fine with SimTools.
    But if you run the AMC, I would strongly suggest looking into prilad's "Revolution" firmware.
    It simply blows "The other Guy's" firmware out of the water!
  2. yobuddy
    51,234Coins
    have you tried the setting in the picture I posted a few posts back?
    I really think it will help, allot!
  3. yobuddy
    51,234Coins
    yobuddy updated Motion Simulation Software SimTools v1.0 with a new update entry:
    SimTools v1.1
    Tip - Just install over the top of your current install to update the software.
    Read the rest of this update entry...
    • Like Like x 9
  4. hugso
    hugso Active Member
    Glos UK
    611Coins
    Arduino, Motion platform, 4DOF
    Thanks for all your wonderful work. I look forward to installing update when we are back from Christmas jollities. SimTools really has been a dream come true for me.
  5. value1
    15,082Coins
    What a nice Christmas present! :)
  6. eaorobbie
    20,488Coins
    Totally Agree, thanks @yobuddy.
  7. prilad
    Dubna, Russia
    9,663Coins
    3DOF, DC motor, Arduino, 4DOF
    And me too!!! Thanks @yobuddy :cheers
  8. MasterYoda
    MasterYoda Active Member Gold Contributor
    Portland/USA
    322Coins
    2DOF, SCN5
    Tx for the gift! :)
  9. Rinus janssens
    Rinus janssens Active Member
    environmental construction
    Holland
    2,153Coins
    SCN5
    Is there a way to chance the center of the SCN's with Simtools ?
    My scn's are not set in the middle when I start up.
  10. CraCk
    CraCk Member Gold Contributor
    Made in Ukraine
    670Coins
    If you go to the tools menu in GameManager. Manifested message. Within 1 sec.
    OS Windows XP
  11. RaceRay
    Hamburg, Germany
    23,877Coins
    Please click on Details and copy and paste the error log here.
  12. CraCk
    Made in Ukraine
    670Coins
    Sorry but I can not. Windows closes automatically after 1 second.
  13. yobuddy
    51,234Coins
    yobuddy updated Motion Simulation Software SimTools with a new update entry:
    SimTools v1.2
  14. yobuddy
    51,234Coins
    SimTools v1.2
  15. carloscasas
    carloscasas Member
    322Coins
    Thanks for update.
    One question.
    For Iracing, the G-Vert (Heave) is 1 in neutral position. Is possible subtracting 1 (before doing the calculations), so the neutral value would be 0, like the another G-forces (surgeand Sway)
    Cheers
  16. billo2404
    billo2404 Member
    Roma, Italia
    1,236Coins
    AC motor, 6DOF
    ottimo, per caso quest' aggiornamento prevede anche l' uso di velleman VM110 (K8055N)???
    In caso sarei deciso a provare sim tools, cosa mi consigliate:
    Possiedo K8055N e saberthoot 2 x 12, se acquisto un arduino uno posso utilizzare la saberthoot o dovrei cambiare anche quella???
    In caso con cosa mi consigliate?
    Aggiungo che per il momento sto usando motori tergicristallo ma prossimamente vorrei cambiare con altri più potenti
    great, for if this 'update also includes the' use of velleman VM110 (K8055N)?? If I'd decided to try sim tools, what do you advise me: I have K8055N and saberthoot 2 x 12, if you buy a arduino one can use the saberthoot or should I change that too?? If you advise me to do? add that for the moment I'm using wiper motors but I would change soon with more powerful
  17. hugso
    hugso Active Member
    Glos UK
    611Coins
    It does make sense to have g value as 1, zero being weightless, but I tend to agree that if 1g was centre it would be slightly easier to set up as what we want to experience is deviation from normal, which is 1g. As I use servo motors it is not difficult to rotate the servo arm by a couple of splines to centre on 1g.
    • Old Old x 1
  18. carloscasas
    carloscasas Member
    322Coins
    Hi again. THanks for the message.
    I think so, but the problem is this : if i use the G-forces Lat (Zero-G Neutral), Long (Zero-G Neutral) , Ver (1g Neutral), the neutral position of axis is higher.
    For example, if the travel of our digital servos is 250 mm, the neutral position (with the car stopped) is 125 mm.
    Then, with 1G vertical, the axis in neutral position is higher, around 135-140 mm.
    Is possible to subtract this 1 g before SIMTOOLS calculates the Axis position?
    ps=Only is with Iracing, because the rfactor and other similars, use the Vert-G is 0 in neutral.
    ps2=Sorry for my english
  19. MasterYoda
    Portland/USA
    322Coins
    2DOF, SCN5
  20. yobuddy
    51,234Coins
    @carloscasas
    "Is possible to subtract this 1 g before SIMTOOLS calculates the Axis position?"
    yes, but it has to be done in the plugin itself.
    Is the heave always off by 1g?
    @MasterYoda
    Anytime Buddy!
