value1
Project CARS Plugin 2.0.3.3
SimTools game plugin for Project CARS
  1. john
    john New Member
    328Coins
    @value1, thanks for that information, I will start with minimum requirements, could be a while before Project Cars is available to non members.
    362442340 New Member
    328Coins
    How can i go to download the plugin /?????
  3. RaceRay
    Hamburg, Germany
    23,876Coins
    1. To download SimTools Plugins you need a Download Package. Buy it with virtual coins which you get for activity in the forum. If you can not spent your worthful time here you are able to purchase Download packages. This helps us to give you steady service and support and gives us more capacities to improve SimTools with your needs. Get Download Packages here.
  4. boons4
    boons4 New Member
    157Coins
    Hi guys can I confirm you all manage to get simtool to work with pcars now? Can someone confirm? Thanks
  5. boons4
    boons4 New Member
    157Coins
    Guys exactly how much coin must I have to download plugin n file needed to get pcars motion to work? 250 coins? I hv 143 now thanks.
  6. value1
    14,994Coins
  7. value1
    14,994Coins
  8. Erwan960
    Erwan960 Active Member Gold Contributor
    3,832Coins
    Hi !
    Since recent updates from Pcars, I can't manage to run my simulator fine. It works well in AI mode, when you are in free practice in the garage for example, but not in manual mode.
    Are there other people who are facing the same problem ?
    I found that the circle representing the effects felt by the driver (braking, acceleration. ..) remains locked in position 0.
  9. value1
    14,994Coins
    I receive all "0"s for surge, sway and heave speed and acceleration from the simulation even with the latest build 729 :(
    So far I haven't found a explanation in the WMD forum.
    • Bad Spelling Bad Spelling x 1
  10. Erwan960
    3,832Coins
  11. value1
    14,994Coins
    Fixed with build 730
  12. Ramok
    Ramok Member SimAxe Beta Tester Gold Contributor
    Slovenia
    1,130Coins
    Hello
    I have a problem with pCars my 2 dof seat mover not work and i dont know where is the problem.
    With Assetto Corsa and WRC 4 work fine.
    Greetings
  13. Erwan960
    3,832Coins
    Since build 812, it's the x64 version of pcars which is used. So it's now pcars64.exe and not pcars.exe which is launched.
    How to change it in simtools ?
  14. value1
    14,994Coins
    value1 updated Project CARS Plugin with a new update entry:
    fix for x64 version of pCARS
    Read the rest of this update entry...
    Thanks @Erwan960 for letting me know. It's fixed with the latest (3.0.6.1) plugin. :cheers
  15. Erwan960
    3,832Coins
    Thanks ! I'll try it tonight.
  16. Ramok
    Slovenia
    1,130Coins
    Hi again
    Here is video of pCars and Assetto Corsa.
    AC works like charm no problem at all.
  17. value1
    14,994Coins
    Hi @Ramok
    Check your axis settings for pCARS.
    Could it be that there is no force selected for all axis?
  18. Erwan960
    3,832Coins
    Check your "Min/Max Value" file. As far as I'm concerned, I have to use this scale : 1 for 1G and not 10 for 1G.
  19. Ramok
    Slovenia
    1,130Coins
    @value1 @Erwan960
    Thanks for help guys.
    I put the same numbers axis settings from AC in pCars and works great.
    Greetings.
  20. Nick Moxley
    17,056Coins
    Where is the MMF output setting in the Game itself ?
    After patching its telling me to turn it on. But being new to the game i have No clue where to find such MMF output.
