  1. value1
    14,995Coins
  2. darkmold9
    darkmold9 New Member Gold Contributor
    Québec, Canada
    56Coins
    3DOF, Arduino
    Hi Sim community,
    I've been following Tanos since a long time now and was working on a simple 3 DOF sim. Now it is almost completed but it is not a sim that will take your pants off. Since i do not have lots of place, i had to do something small so i decided to modify an office chair as a simultator. It is a 3 DOF sim though but quite slow compared to the sims with the SNC5. But as you know, it is not easy to do a 3DOF with Heave movements. The actuators are only .5 inch a sec but you still get a feeling for the type of sim. The steering Wheel needs to get off most of the time since this is the family computer therefor it is set on the desk. This gives a sensation that you get further from the steering Wheel in accélérations. Have some more work to cover the base of the sim with an ABS sheet to cut some noise from the motors and hide the mechanisim.
    I've posted the 3 DOF Arduino code that i modified from the 2 DOF. It may not be perfect since the chair gets wild some times when the i move the slider at the maximum of the line in the Output test bench of Simtools. Also cant get the actuators to move slowly it is kinda jerky.
    Well That it folks, hope i did not took too much space on the Forum.
  3. patritti
    patritti simracer
    composite race car parts manufacturing
    woodstock GA usa
    516Coins
    3DOF, SCN6
    Hello my name is patrick . and i love sim racing . i work every day on real race car . my company manufacture composite parts of porsche race car . i build the last couple year my on racing rig . started with Frex motion . seat mover . then modified it to run on simexperience . like CXC seat mover . then when to the next level . and built my self a simcraft
    where the entire rig move . then build my own . run with simcraft and simexperience software .
    here a link of my prorsche GT3 MOMO racing simulator on vimeo .
    next i want to build a 6 dof F1 simulator . so i hope i can use simtools . but i have no knowledge of programming
  4. bsft
  5. bsft
    got a video?
  6. patritti
    patritti simracer
    woodstock GA usa
    516Coins
    3DOF, SCN6
  7. Albertus
    Albertus New Member
    Manager
    Standerton Mpumalanga South Africa
    131Coins
    Good Day
    I am from South Africa and hope to complete my Albertus Geyser 2 DOF simulator soon.
    Thank You for Software Developers.
  8. bsft
    I will have to drag @eaorobbie into this as he has some figures. I know with big motors at 16 amps they are 20 nm torque at the gearbox shaft, real world figures, but as we overdrive them, more like 30-40nm torque. They are faster in linear speed, about 500 mm per second. And thats under load of 10 kg, I think
  9. darkmold9
    Québec, Canada
    56Coins
    3DOF, Arduino
    Look at 0:46, i have put the streering Wheel and pedals. The first 46 sec. are with the mice. You can see the mechanism at work at 1 min.
  10. bsft
    @darkmold9 , well done, a desk racer chair.
    Thats my next planned build. But a 2DOF
    Do you have any more specs on your build?
  11. Albertus
    Albertus New Member
    Manager
    131Coins
    bsft i am new and would like to know what is best 3 DOF or 2 DOF as i read you said you would build a 2 DOF.
  12. RacingMat
    21,040Coins
    @darkmold9 : very smart and compact setup! Congratulations!!
    Please open a dedicated post: i'm sure many simers would like to get some advices from you!
    Yours
    Mat
  13. value1
    14,995Coins
    The difference between 3DoF and 2DoF is a factor of 5-10 in money.
    While you (mainly) fight with inertia with a 2DoF you must lift the weight of you and the whole sim in the case of a 3DoF (assuming your 3rd axis is heave).
    So you can build a well balanced 2DoF sim with even wiper motors with a total power consumption of 50 W. For a proper 3DoF you'll need strong motors in the region of 1 HP each, totalling a nice 2.5 kW!
    @BlazinH is moving his sim with 5'000 W… :D
  14. bsft
  15. vell001
    vell001 New Member
    559Coins
    I am using simtools to bulid my racing seat, simtools is a great software
  16. datou188
    datou188 New Member
    106Coins
    Hello, I am on my way hopefully to a diy motion-simulator, I hope i will be able to accomplish that with the help of some experienced members.
  17. bsft
    @vell001 @datou188 , welcome to both, when you are ready, please start new threads with your sim builds .
  18. datou188
    datou188 New Member
    106Coins
    I was a newcomer, I hope a lot of attention
  19. datou188
    datou188 New Member
    106Coins
    I am sorry ,my english is not very good.
  20. Jackie Walters
    Jackie Walters New Member Gold Contributor
    Montgomery, TX
    - 408Coins
    Just posting that I'm new to the site I'm interested in building a simulator. I know nothing but I'm about to find out.
    Jack
