I am New to DIY sim building. Anyone chiming in with help is great.
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by james wheeler, Mar 17, 2014.
  1. james wheeler
    - 145Coins
  2. bsft
    its for charging, probably no good
    you need to look at a proper power supply like a converted server PSU, proper PSU and or a car battery in parallel with a PSU.
    20 amps is not really enough, look at 40 amps at least for extra power if you ever need it.
  3. james wheeler
    - 145Coins
    well i grab a few old psu from some old laptops i had. they were a 19v 3.7a and a 12v 3.7a. I hooked them both up and the 19v really makes those little motors fly. i don't know about stall force though. (how stronge they are)
  4. bsft
    easy way to find out @james wheeler , thrash the motors till they break.
    As for the power supplies, dunno, try them out.
  5. james wheeler
    - 145Coins
    lol yes that will most likely happen bit they were ten bucks a piece so lets blow them up. since its more like a prototype build I won't be to upset.
  6. Barry
    Barry Active Member
    Web Developer
    Northern Ireland
    3,877Coins
    I bought 2 HP sever power supplies from ebay last week. They cost me £27 GBP for 2 of them delivered.
    47A each so they're perfect for the job. Really easy to find as well.
  7. james wheeler
    - 145Coins
    can you put up a link to where you got them from
  8. Historiker
    9,208Coins
    Not sure if these are the same ones that Barry is using but they are the ones that I use:
    http://www.ebay.com/itm/HP-DL360-G5...-/321323351835?pt=PCA_UPS&hash=item4ad05d3f1b
    Although these are of a lower amperage I think they are better as they have their own internal cooling fan. I had to add fans to mine which increased the labor and cost.
    http://www.ebay.com/itm/LOT-2-HP-DP...=US_Server_Power_Supplies&hash=item56637b5e6f
    Also, James you had asked about a map feature so you could find help locally but you never added yourself to the map. You should do this in case future members also want to find local people in your area to get help from. :)
  9. Barry
    Barry Active Member
    Web Developer
    Northern Ireland
    3,877Coins
  10. james wheeler
    - 145Coins
    thanks for the links.
    now for pots. how do i chose the right one?
    here is a link to a electric hardware store close to where iam building the seat
    http://www.a1parts.com/pots/index.htm
    there are so many i am alittle lost
  11. bsft
  12. Barry
    Barry Active Member
    Web Developer
    Northern Ireland
    3,877Coins
    How hard are the hall effect pots to set up?
  13. bsft
    piece of cake, they wire up the same as a normal pot and you find the centre position on the pot , set feedback in the appropriate controller and off you go.
  14. james wheeler
    - 145Coins
    I took some pictures of the seats hardware after I slaped it together, and yes that is a old patio umbrella shaft sticking out the front. lol I found everything so far for free. I did "f" up on the placement of my ball joints but I will fix it. Just got ahead of myself IMAG0881.jpg IMAG0882.jpg IMAG0883.jpg IMAG0884.jpg IMAG0885.jpg IMAG0886.jpg
  15. james wheeler
    - 145Coins
  16. bsft
    looks good on the frame, love a good "slap" together build. Most of mine are like that.
  17. james wheeler
    - 145Coins
    where can i find post on arduino related question?
  18. BlazinH
    16,665Coins
    Yes. Two of these motor controllers should work with any micro-controller where you have 4 available logic level output pins, two pwm pins to output a duty cycle, and of course, the proper coding to operate them.
  19. eaorobbie
    20,481Coins
    These can be wired in like a std H bridge using a PWM and 2 dir pins.
    Beware they are a bugger to run at 24v, better used at 12-16v. Warning contained on pololu site.
    " While the overvoltage protection typically kicks in at 27 V, it can trigger at voltages as low as 24 V, so we do not recommend using this motor driver with 24 V batteries, which significantly exceed 24 V when fully charged."
    Lots of info here, http://www.pololu.com/product/1451
    Hook up would be like this and doubled for two units but one micro controller.
    **Picture came from - http://www.pololu.com/picture/view/0J3706
  20. BlazinH
    16,665Coins
    I'm curious what part of my analysis you disagreed with @eaorobbie ? I think we said the exact same thing! You said hook up like a standard 2 pin direction controlled h-bridge with a PWM pin. He wants to hook up two of them. Would this not equal 4 direction pins and 2 PWM pins if it is done on one micro controller?
