Showroom my 6dof (reproduction of ckas)
Discussion in 'DIY Motion Simulator Projects' started by vulbas, Mar 27, 2014.
  1. vulbas
    vulbas Active Member
    france
    1,101Coins
    AC motor, 6DOF
    hello,
    I started painting. it's black satin
    I start the wiring is very long
  2. cthiggin
    cthiggin Active Member
    Self-Employed
    Montgomery AL USA
    15,209Coins
    vulbas,
    Friend, it's looking great...
    ? - What are you using the transformer for? Pots/Board??
    Have a blessed one,
    Tom
  3. BlazinH
    16,671Coins
    Black satin is what I use too. I would prefer to use flat though due to little light reflection off of it but it just looks dull and holds on to everything that touches it!
  4. vulbas
    france
    1,101Coins
    AC motor, 6DOF
    I painted matte black. it will be better, it will be less trace.
    the electricity supply 24v used for 6DOF card. usb hub. and fans that I will put on the engines. I'll run over 50hz, they will heat up more.
  5. cthiggin
    Self-Employed
    Montgomery AL USA
    15,209Coins
    Hi vulbas,
    Thanks, that's what "me" thought.
    Are you using the "thanos 6dof" board I saw a couple years ago - another one at ??BFF or BBF site?
    Again, you're doing beautiful work friend.
    Tom
  6. vulbas
    france
    1,101Coins
    AC motor, 6DOF
  7. vulbas
    france
    1,101Coins
    AC motor, 6DOF
    I start wiring card thanos 6DOF.
    it make a packet wire to plug in a very small card.
    I can tell you that it's much more true bazaar :)
  8. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,944Coins
    Hi @cthiggin ... this is a good preview for you ... thanks for the tips:thumbs.
    Hi @vulbas ...very good my friend ... but if you allow me :
    - Safety first buddy ... I guess with all this wires it may look like the tree root at the end ... if you can organize more please ...
    - These resistors tips " red circle-see picture "needs to be shortened or good isolated ... Spark is possible here ... EMF voltages can reach serious values here .
    - Aren't you going to use any CB "circuit breaker" OR Emergency stop with a contactor for the main line ?
    - What is the device in the blue rectangle for ?
    you're really running in your progress and I'm really pleased with that ...
    Thanks and keep up the good work :cheers
  9. cthiggin
    Self-Employed
    Montgomery AL USA
    15,209Coins
    Hi Speedy,
    Good to hear you friend.
    Yes, I watched @vulbas' build of his 3dof about three years ago when I was just getting started looking for hardware. He sure is doing a beautiful build here....Wow!
    Tom
  10. vulbas
    france
    1,101Coins
    AC motor, 6DOF
    very good speedy remark, I planned to shorten resistances;) I waited to see if someone would tell me :)
    in blue rectangles: 24v converter => 12v and 24v => 5v
  11. speedy
    Alexandria , Egypt
    7,944Coins
    Sure @vulbas we wont let down any tiny detail to escape ... And I assume you will cover this box with some plexiglass door or cover ... So, and I'm sure you know that your electronic box have lake of ventilation ...
    you have many thermal loads in ascending order : regulator , the AMC1280USB , a power supply , 6 resistors heat source , 6 VFD's heating up very fast driving your motors with there fans facing the box side too close and circulating the worm air back inside again ... the VFD's here is in danger situation "they are eager for cool fresh air " ...
    I suggest to just drill 6 ventilation holes "just holes" in front of each VFD Fan to through out the worm air ... covered with wire mesh like you did with the shown ...
    put more one or two extra side suction Fans like the one you did ... to pull fresh air into the resistors area ...
    It is really pleasure to contribute with you at least by any comment ... that's what makes me learn more ... thanks for leaving the door open ...
  12. vulbas
    france
    1,101Coins
    AC motor, 6DOF
    hello,
    not made much progress. I just painted in matt black box.
    I'll test it with the box in this configuration. if it heats I do otherwise.
    thank you for your help speedy :)
  13. vulbas
    france
    1,101Coins
    AC motor, 6DOF
    finally I wonder if I'm not going to the box white.
    what do you think?
  14. cthiggin
    Self-Employed
    Montgomery AL USA
    15,209Coins
    Black would be less distracting to the overall build. Don't think you want a first time viewer to immediately focus on the electronics box. IMHO
    Sent from my iPad using Tapatalk
  15. vulbas
    france
    1,101Coins
    AC motor, 6DOF
    This week I received my card. :)
    i'm very happy :)
  16. cthiggin
    Self-Employed
    Montgomery AL USA
    15,209Coins
    vulbas,
    That's great and I know you're very pleased. Know you've been quiet here for a few days....
    The resistors and VFD's just tower over the size of the board....
    Have a blessed one,
    Tom
  17. kermit76
    kermit76 New Member
    The Netherlands (Zwolle)
    357Coins
    Looks great!
  18. vulbas
    france
    1,101Coins
    AC motor, 6DOF
    I worked a little today ;)
    the spacer for the card.
    the card ;)
    the wires for 6DOF card, potentiometers, Emergency stop are connected
    I cut the ends of the resistors to avoid the electric arcs.
    I redid my electronics box that I had broken
  19. cthiggin
    Self-Employed
    Montgomery AL USA
    15,209Coins
    Looking GOOD!
    Have a blessed day.
    Tom
  20. vulbas
    france
    1,101Coins
    AC motor, 6DOF
    the electronic box is finished. everything works. :cheers
