Tutorial Monster Moto Shield acts as a single motor driver = more power!
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Pit, May 9, 2014.
  1. Pit
    30,497Coins
    DELETED, wrong information
  2. BlazinH
    16,671Coins
    I'm just curious @Pit if you have tested this under full load on a simulator to confirm all is as should be? Thanks
  3. Pit
    30,497Coins
    My weight was the load to move :) I was pressing down the crank to simulate the weight of the seat. Under the same circumstances the Monster Moto stopped by using it as a normal dual motor driver. Now it works fine. But you are right perhaps there will be any issues later not been detected yet.
  4. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,305Coins
    I love your experiments and test results. :thumbs
    Obviously you have it working so my previous concerns are unwarranted... I did check the datasheet for the output drivers and they say that they can be used in pairs for more power so you're definitely on the right track. They do however recommend using one driver for each half of the h-bridge rather than putting them in parallel (similar to the schematic posted by BlazinH). Both ways should give the same output power. While the parallel output works it "may" reduce the life of the drivers - but I can't be sure.
    Here is the example from the datasheet, it seems to be just a minor rewire to connect this way.... But you seem to be having more fun and learning more just taking some risks! :grin Keep us updated.
  5. Pit
    30,497Coins
    @RufusDufus nice to hear that :) The datasheet seems to be just different from what I expected. The sheet shows A and B connected - different from what I did. But the power meter doesn't lie I believe so :) At least it works. I ordered 3 samples from aliexpress, perhaps the Sabertooth 2 x 60 is already history p:
  6. telfel
    telfel Active Member
    4,738Coins
  7. ferslash
    ferslash Active Member
    4,798Coins
    so, using this solution what is the total amperage that you can handle here???
    best regards
    fer
  8. Pit
    30,497Coins
    The tests have not been finalized yet furthermore it is difficult to measure the peak of the current. The maximum current rating of the bridge is 30 A, the
    practical continuous current 14 A. The winches require each up to 25 A. My experience about the bridges (standard) they are working fine up to 20 A, so in the dual mode 40 A should be realistic and to be expected. At the moment I am very busy and cannot continue with the test s, but you can be sure the content is going to be updated soon.
  9. Pit
    30,497Coins
    Unfortunately no second Monster Moto delivered yet but a new video instead. I wired as described below and connected one winches to one h-bridge in "single mode". In the very first posting I added a new video to confirm all is working fine. SMC3 can now handle significantly more power (Before: Kp ~200, PWMmax ~180, now Kp ~500 and PWMmax ~220.)
  10. Pit
    30,497Coins
    Update (see first posting)
  11. RacingMat
    21,059Coins
    The wiring you drew is accorded to VNH specs:
    so, finally you rewrite your first post to follow the specifications of VNH instead of your first tests?
    PS: the same can be done with 2 VNH3SP30 to allow 5.5-36VDC power supply!
    Here is a link @9€ from Olimex = 18€
  12. Pit
    30,497Coins
    Indeed. To avoid any short circuits they are wired as described above.
  13. CalSim
    CalSim building things
    bacteriology analist
    Spain
    1,310Coins
    DC motor, Arduino, JRK
    Hi @Pit in your first post info you say:
    The outputs:
    A1 and B1 will have the SAME polarity
    A2 and B2 will have the SAME polarity, too.
    But in your photo, A1 and B1 have different colour cables, just like driving 1 motor on each channel. I'm a bit confused, have you connected them to the same motor terminal or are they mixed?
    greets
  14. Pit
    30,497Coins
    I am at work so short reply only. Of course they are different because the wires have been soldered BEFORE I found out this new solution. I will post a video this afternoon to show you that it works.
  15. Pit
    30,497Coins
    @CalSim:
    Now with the correct colour wirings. My Monster Motos are running months ago w/o any issues.
  16. RacingMat
    21,059Coins
    @CalSim : I would advise you to read the specs :) it looks boring but always interesting! With trustworthy information
    For what project do you require high current?
  17. CalSim
    Spain
    1,310Coins
    @RacingMat I love to read specs ^^ spent whole nights on it. Well i'm building a nice lineal actuator
    http://www.xsimulator.net/community/threads/dc-actuator-design.5762/page-2
    I'm using those new MotionControlProducts ZYT-90 motor with the 60:1 wormgear. Check it, it is 23A const 48A peak., huge power, 276W . I've already burned 2x pololu dual VHN5019, 1 my bewbishness 1 because headers * 70Amps arent friends.
    This is why i'm looking for some alternatives at the dual 5019 driver. Sparkfun MM is more expensive than dual 5019 and aliexpress MM looks shitty.
    @Pit Cant see the video, Have those been working for months?.... The video preview seems you have a smaller motor.
    IMG_5204.JPG Motor here
    IMG_5447.JPG Global overview, no Pulleys yet.
    Everything is on my post, when electronics are working i'm updating it, I dont want to post em here ^^
    greets
  18. Pit
    30,497Coins
    I can only repeat...
    Check out the forum or Aliexpress for very cheap MonsterMoto (15$).
    The video above is only for demonstration (test unit). My winches are running you can see them in my DIY thread http://www.xsimulator.net/community/posts/62861/
  19. CalSim
    Spain
    1,310Coins
    Yes, i have seen them and read a lot about them, the thing is that i dont really trust those cheap, i have experience in aliexpress and electronics is a critical thing, I'm looking for max quality on everything i can. I also know i'm a bit on the limits of the shields. are them really worth?
    Cant see any of your videos, others i can but not yours :S
  20. Jymä
    Jymä Member Gold Contributor
    Finland
    184Coins
    @CalSim I have same motors as you. Did you measure that 23A continuous and 48A peak on simulator conditions or was it maximum stress? Because I'm planning to use them on 2DOF full frame platform in which VW wiper motors with under 10A(?) peak were almost enough. I planned trying single Moto Monster first but I guess I would have to go to this parallel setup straight if it draws that much. Also I have only one 47A PSU for both motors. Should I buy another PSU?
    And about those Moto Monsters, I don't think it really matters if you buy the "real" one or the $15 one. They are both probably built with same Chinese components, but the first one charges for design costs and the brand etc. Though it might have a little thicker PCB or some other quality factor. And actually I'm not sure yet if my first cheap MM was faulty but many seem to be using them with no problems. Some use these too http://www.ebay.com/sch/i.html?_sacat=0&_nkw=bts7960&_frs=1 if you want to try.
