Ultraforce GS-4 DIY - Software
Discussion in 'DIY Motion Simulator Projects' started by Schluzu, Mar 7, 2014.
  1. eaorobbie
    20,487Coins
    Your more than welcome @Schluzu any mods needed to it go for it and republish it as a Gseat code modded by you.
    P.S I can help to mod it further if you require, but its pretty easy and @aarondc did place a good amount of comments in it too.
    How many servos are you running from one card, should be able to run up to 6 servo's.
    This could be taken a step further and use proper rc cards, but would require a custom app between SimTools and G Seat, mmm forget that you would have to write all the adjustment and setting into the app, but would be a cool way for newbies to setup instead of the clumsy Ard IDE.
  2. RacingMat
    21,058Coins
    Schluzu uses 2 arduinos to optimize the transfert of information from Simtools
    For 7€, the "baud rate" is doubled.
    @yobuddy : I'm wondering where could be the bottleneck in the configuration? Simtools / usb / arduino
    With 4 arduinos, linked to 4 interfaces: would actually Simtools send data 4 times quickier?
    Thks
    Mat :)
  3. eaorobbie
    20,487Coins
    Shouldn't be an issue I and others have controlled 6 servos on one Ard, speed is fine no notable lag in movements, The code posted in the first post is not very efficient hence my servo code which he has based parts from , which is fine, had been improved on greatly.
    Most Jrk users would feel lag or something like that if it was an issue in timing of multiply interfaces.
    Timings involved is with in the Ard code , not simtools. This is the trick in writing code for the Ard and both motion software's, you can set SimTools down to 10ms timings if your code is efficient enough to read it. Jrks run down there without issue, Ard should be able too, but personally I run mine at 20ms pid periods, very, very hard to physically feel a difference in motion.
  4. yobuddy
    51,184Coins
    Each interface uses its own thread, so it's able to loop over and over doing it's thing.
    So while each interface is more load on the PC, using multiple interfaces would be faster than using 1 interface and doing the same thing.
  5. RacingMat
    21,058Coins
    Thanks @eaorobbie @yobuddy!
    With 3$ Mini Pro Arduino here: it is a good way to simplify and optimize transfert rate!
    _____________
    edit : these ones have no USB serial :-(
  6. Roadster2
    Roadster2 Member
    1,197Coins
    Hi Martin. In your wiring diagram that you kindly attached, can you confirm the signal names for the pin 8 and 9 connections - based on the attached pinout diagram - D8 and D9 ?
    (just want to make sure I don't screw anything up).
  7. Roadster2
    Roadster2 Member
    1,197Coins
    Found a load more photo's of the GS-4 seat, some including dimensions. Also photo's of the servo's used - Hitec HS805-BB.
    http://www.ultraforcesim.com/pub/GS-4/Pictures/
    This is actually a sub-folder from the page linked to in the earlier post but one that I didn't notice when originally searching through the list.
    I see they use 8 x servo's on the base. Four on each plate and doubled up i.e. two servo's driving one actuator rod.
  8. eaorobbie
    20,487Coins
    You can easily change the pin names in the code to where you have the signal wire hooked in, its all changeable.
  9. RacingMat
    21,058Coins
  10. eaorobbie
    20,487Coins
    @RacingMat , yes totally agree, instead of trying to save a buck use the UNO , or even a bigger one so you can use one card to control all,
    I can control up to 12 servos, well multiplys of 6 with one single UNO, Its actually quite easy.
  11. Schluzu
    Schluzu New Member
    37Coins
    Arduino, 6DOF
    hi guys,
    please dont be angree, concerning silence.
    in the last time i have a lot of familiar problems (death/heart-attack,.....) so i do not spend any
    time on the seat or here, if this circumstances change, i will be present.
    gl 2 all
  12. ferslash
    ferslash Active Member
    4,798Coins
    man, i hope everything is getting better.
  13. RacingMat
    21,058Coins
    Best wishes! and come back soon :)
  14. Schluzu
    Schluzu New Member
    37Coins
    Arduino, 6DOF
    Hello fellas!
    I'm back with changes on the seat.
    The bottom-plates are history - long sessions on the butt hurts more and more - I moved them to the sides to get pressure on my upper legs and save 2 servos as well. The back-plates are also updated. I get much more feeling in the longitudinal and transverse directions , therefor i loose the heave axis, but thats no problem for me. photos will follow tonight - currently i´m seating in the office.
    cu
  15. RacingMat
    21,058Coins
    Good news!
    We wait for update details and picture of course! :D
    Interesting: you're getting closer to gekosystems... rather than GS4
  16. RiftFlyer
    RiftFlyer Active Member Gold Contributor
    1,711Coins
    DC motor
    Glad you are back. Hope all is well. Looking forward to seeing pictures
  17. Roadster2
    Roadster2 Member
    1,197Coins
    Nice to see you back. I pickup my second-hand Kirkey seat next week so will be interested to see your changes before I get started.
  18. Schluzu
    Schluzu New Member
    37Coins
    Arduino, 6DOF
    Hi guys
    so as promised, the photos and a short video
    NOTE this is a Beta-Version, if i satisfied with it i will posh th seat up.
    greetings
    • Like Like x 6
  19. berty
    berty Member
    164Coins
    so that when I want to control 6 servos What code do I put in the arduino?
  20. eaorobbie
    20,487Coins
    I have an RC Model code in the resource section , more axis can be added into this very easily and its all open source.
    @Historiker had built a model and extended this code, not sure if he shared it back thou.
