2DOF Simulator by a Newbie
Discussion in 'DIY Motion Simulator Projects' started by mugge66, Jun 17, 2014.
  1. mugge66
    mugge66 Member
    Denmark near Copenhagen
    167Coins
    2DOF, JRK
  2. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
    When I coonect my psu to battery it kind the cooling fan stops to rotate. is it safe to charge the battery with this psu
    "Solved"
  3. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
    Need some help with simtools
    There something i dont understand about tuning center. ? Min and Max If i would like more motion on Surge acc. and less motion on braking do i need to change Max or min. do i need the max at around +10 and min -2 or min at -10. i get a good gear shifting around +3-3 but over that its almost gone. The problem here is there too much power on braking and acc i would like a more smooth feeling. i have read up and down on this forum but dont seem to understand it. Yes i know im smartest guy in this area ;)
    Any good links to a youtube explanation is welcome.
  4. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
  5. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
  6. bsft
    to have big surge on acceleration which adds to gear change effect, a small number in MAX, while to soften the force in braking a larger number in MIN
    Example Max 10 , Min 20, but keep the percentage of the force overall the same in axis assignments.
  7. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
    Helped alot thanks :)
  8. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
    Hi all
    Thinking about buying Simvibe, 89$ is still alot for a piece of software that im not sure will boost the sim feeling. ?
    what are your guys thought, is it worth buying.
  9. Pit
    30,510Coins
    I am SimVibe owner :). Engine sound and vibration, feeling the deep noise switching the gears, that is really impressive and I miss it if the amplifier is off. My seat mover is really hard moving and fast turning, but w/o the vibrations it feels "empty". At the moment simvibe is - perhaps and only for me - not worth the money due to the lack of sounds (no complete data output of AC), but there is no alternative. If you want to use it with other racing sims there are many options of different outputs and the authentic feeling is guaranteed.
  10. Scratch
    Scratch Active Member
    281Coins
    Prize with Simvibe is high, but I love the effects it produces. @Pit is right, now without it rig feels empty.
  11. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
    Ok Think i will take the jump and buy it. :) Will simtools ever support this, or is worth waiting for
  12. bsft
    it will be supported in time
  13. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
    Made some welding on the motor brackets and i must admit what a diffence it makes the noise is gone and much more smooth motion.
    Bought simvibe yesterday had it run once. nice feeling. didnt had the time to test much.
    Thinks still to do.
    Cleaning up the mess behind the cabinet, cable´s etc.
    Actuator for pedals, need to mount this to the pedals.
    a bigger screen
    and maybe alot more ;)
  14. Pit
    30,510Coins
    Great work...and don't forget the video :)I like the detailed finish, I know this needs so much time to complete.
  15. bsft
    looks good man
  16. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
    i could really need some help. ?
    i bought simvibe for shakers, and it runs fine. but i can´t get it to run with simtools i need to repatch games with simtools to get motion back when i have tried simvibe"simcommander"
    Have anyone found a solution ?:(
  17. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
    Hi Guys
    Iracing and traction loss Extra Feature what is it exactly i am suppose to feel i have tried different settings but i dont understand the feature. is the motors suppose to move the same way or different ways. ?
    Maybe this is another silly question
  18. value1
    14,236Coins
    Hi @mugge66
    For traction loss you need a third - yaw - axis. The motion base will rotate around a vertical axis. How that's intended to work can be seen in this video
  19. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
    Thank You. Maybe will add this in future updates. :)
  20. mugge66
    mugge66 Member
    167Coins
    2DOF, JRK
    Hi guys Need your help :)
    i play mostly iracing and AC. but i have this issue that there are at some points where the simulator just tilt to one side, the same places all the time this can be on straights and in turns. its like there are some glithes.
    i just did a clean install with win7 and iracing and now i am having this issue with some tracks that i did not have the problems with before. do you guys have any idea what this can be. ??
