RC Model for Motion Simulation
Discussion in 'SimTools compatible interfaces' started by eaorobbie, Jul 17, 2013.
  1. eaorobbie
    20,473Coins
    Sorry not sure if total understand what you are trying to say, possible you could show a pic or two, better than words.
    9v's attached to RC servos will kill them, if using a 9V psu please only plug this into the ard and the +/- ve of the servos will need to plug into the 5V and the GND of the Ard as per my picture.
  2. Alexandre Kostik
    Alexandre Kostik Member
    realtor
    Brasil
    422Coins
    rsrsrsrs! I said u would be working with me! I see what you mean ... I do not connect 9v direct the servants but in Ard ... can let follow your instructions!
  3. eaorobbie
    20,473Coins
    That's what we are here for Mate , follow my simply wiring diagram on first post and plug the 9v into the Ard via its jack and all will be good.
    The Ard has its own 5V regulator on it which will filter the 9V to a steady 5V that the RC servos need.
    Do a Google search on RC Servos connected to the Ardunio for more information, plenty out there.
  4. Alexandre Kostik
    realtor
    Brasil
    422Coins
    Just arrived! I will begin to download the necessary software .... not the source appeared in the photo!
    • Optimistic Optimistic x 1
  5. Alexandre Kostik
    realtor
    Brasil
    422Coins
    earobbie hello! Began doubts! Downloaded and unzipped ... SimTools also installed at Ard file for the simulator with servants. How to proceed now? I have installed on my pc rFactor, F1 2010 and stockcar as install the necessary plugins? I tried to open the GameEngine and GameManeger, but they have not opened ... I also rode the Ard with the servants as in your post ....
  6. value1
    14,994Coins
  7. Alexandre Kostik
    realtor
    Brasil
    422Coins
  8. Alexandre Kostik
    realtor
    Brasil
    422Coins
    @value1. I did everything like in the installation guide. Now as to the plugins .... must have coins to download, if 250 coins and then keep having to "pay" for this weekly amount?
  9. value1
    14,994Coins
  10. AceOfSpies
    AceOfSpies Living the Dream!
    Kilwinning, Scotland
    19,614Coins
    Hi @Alexandre Kostik as @value1 says your participation on the forum gets you coins. Once you download a plugin and save it to your computer you don't pay anything more for it. Its not a weekly payment.
  11. Alexandre Kostik
    realtor
    Brasil
    422Coins
    Hello @ value1. I can not open the GameEngine and GameManager ... I installed the plugins, and shut the PluginUpdater when I click on the icons appear on the answer "GameManeger is already Running!" and stands, not opening any other screen. This also happens in GameEngine contecendo ... what is or what should I do?
  12. value1
    14,994Coins
    RTFM! :grin
    The programs are hidden in the task list.
  13. Alexandre Kostik
    realtor
    Brasil
    422Coins
    Oh my God! What a shame! Thanks @value1 !Trainee is anyway! :thumbs
  14. Alexandre Kostik
    realtor
    Brasil
    422Coins
    Friends! I'm putting the electronics and testing of servo motor arduino code ... What should I use? For downloaded one that is here in the post, but in the test GameEngine not had success!:sos:sos:sos
  15. Alexandre Kostik
    realtor
    Brasil
    422Coins
    hello @value1. I'm building a prototype controlled by servos. I followed the instructions from the startup tab, but I have the following problem when I do the test in GameEngine, the servos do not move, I am using the wiring diagram suggested by @eaorobbie, with Ard and 2 micro servos, because when test the cursor movement which nothing happens ..... Ard code should I put in, because I installed the ones that are available here in the post, but were not successful.:think:think
  16. Alexandre Kostik
    realtor
    Brasil
    422Coins
    @eaorobbie and friends! Proptotipo gained my life! the servos are working and the first tests were a success! I'll ride the mechanical part of this miniature and put videos of him working! Thank you for helping me .. I am very happy and excited!
    151,461Coins
    +11,038 / 56 / -2
    Well done, we will all be looking forward to your video.
  18. Capitan
    Capitan New Member
    202Coins
    Hi very good start for the simulator ....
  19. Capitan
    Capitan New Member
    202Coins
    Your code works well used?
  20. john a
    john a New Member
    189Coins
    I dont mean to post everywhere but i was curious if this could be done with the Pololu JRK 12v12's. Can the JRK receive feedback(position) from the servo with just the 3 wires? Any help given would be greately appreciated and ill post my entire build process when its completed.
