First attempt at a 2DOF motion sim
Discussion in 'DIY Motion Simulator Projects' started by SilentChill, Jul 24, 2014.
  1. -kevin-
    -kevin- Fast e Furious
    Termo Tecnico industriale
    128Coins
    squid bats and chickens :grin:grin:grin:grin:grin:grin:grin:grin
    Apart from the jokes ...;) that are windshield wiper motors? what car? have the steel gear? because I saw that you edited the original pin with a threaded rod that I wanted to do but I have the plastic gear in my engines.
  2. SilentChill
    20,598Coins
    The motors are VW wipers and the cogs are plastic but there is a steel rod running through the middle which goes out to the threaded part where the wiper would normally fit on. It does just look like plastic but just drill plastic cog that in the centre and you will find steel.
  3. bsft
    the welding looks ok, just go over it with a grinder and weld along it again. No problem. My first welds were shocking, but it didnt fall apart.
  4. SeatTime
    I like to run a few beads on a scrape piece of the metal similar to what I'm going to weld to ensure my settings are right before starting on the real thing. If your just starting out, run lots of practice beads before moving to the real job. Videos can only teach you so much, good welding comes with lots of practice.
  5. -kevin-
    128Coins
  6. SilentChill
    20,598Coins
    They look like the same motors but are very pricey ! I only paid £15 each for mine. I will try and get pictures of the cog for you.
    I have got it all setup and working perfectly now in SCN Util just need to hook up simtools and get driving :) My motor brackets need strengthing too as they a wee bit bendy
  7. -kevin-
    128Coins
  8. SilentChill
    20,598Coins
    I got my new motor brackets made yesterday and got it setup , its amazing how much power those little motors have. I have to get some more steel rod as i chopped too much off, doh !! Should have it setup up with simtools tonight and Asseto Corsa im hoping :) 100_2081[1].JPG 100_2082[1].JPG 100_2083[1].JPG 100_2084[1].JPG 100_2085[1].JPG 100_2086[1].JPG 100_2088[1].JPG 100_2089[1].JPG
    Total cost so far is around £200, its ruff around the edges alot but this is just a test :p
  9. SilentChill
    20,598Coins
    Yes that is a chopped up old felt tip pen i used to connect the potentiometers :D
  10. eaorobbie
    20,491Coins
    Well done !! A video of it in motion would be cool to see.
  11. SilentChill
    20,598Coins
    I got serious issues with my pots, they giving off loads of noise its the way they are connected because when i slightly bend the brackets the noise stops and everything okay. Its not good as they are making the motors overheat :( Im gonna have to find some alternative to pen casings lol
    I did get it all hooked up to simtools ok and it was working perfectly all be it with alot of noise going on. Will have to try again tomorrow work looms at 6am grrrrrrr
  12. bsft
    the motors could be overheating as they are probably being overdriven 2-3 times their rated current. Ive had that issu with wipers, just put fans on them.
  13. SilentChill
    20,598Coins
    No they arent even moving and they are getting hot, its an awful noise they are making when they are just sat there nothing.
    Its how my POTS are connected need to stop the jitter/noise what ever it is :)
    153,001Coins
    +11,116 / 56 / -2
    You really have made very quick progress...am looking forward to a video once the pots are sorted.
  15. SilentChill
    20,598Coins
    Wow just got these donated to me ! One works the other doesn't have to ser what's wrong. I work it out at 100rpm hope that is fast enough ? t
  16. AceOfSpies
    AceOfSpies Living the Dream!
    Kilwinning, Scotland
    19,614Coins
    Yes @ SilentChill 100 rpm will do nicely. :thumbs
    Mike
  17. SilentChill
    20,598Coins
    Looks like one is totally knackered but the other is sweet, think it would be able to lift my house lot of power. Luckily my mate has another he can get hold of so should be able to replace my wiper motors soon :)
  18. SilentChill
    20,598Coins
    Hope you like, it still needs tweaking but so far so good im well impressed with your software guys frikkin awesome :)
    And thanks for all the help you have given !
  19. bsft
    looks good.
    153,001Coins
    +11,116 / 56 / -2
    You should be really pleased with yourself, great job and thanks so much for the videos.
