GEAR MOTOR 12 VOLT 150/160 rpm 25:1 ratio
Discussion in 'Motor actuators and drivers' started by -kevin-, Aug 20, 2014.
  1. -kevin-
    -kevin- Fast e Furious
    Termo Tecnico industriale
    128Coins
    No reply? it was so bad as an idea? :(
    Oh well, let's move to the engines ... ;)
    How about these?
    http://www.ebay.it/itm/12V-DC-Geare...al_Components_Supplies_ET&hash=item58b2cd2323
    But you have to buy them with the shaft left and right ... I'm in the UK and in theory will not pay customs fees.
    And the same website that I linked eaorobbie few posts up and more are also on ebay
    I saw that the plastic gear and absorb 23 A a little too what do you think?
    Or I could buy engines and gearboxes apart but I do not like so much because they are 25: 1
    In practice, if you buy this http://www.ebay.it/itm/25-1-MCP-4-G...al_Components_Supplies_ET&hash=item19d5f00f2f
    I owe this match http://www.ebay.it/itm/12V-DC-Motor...al_Components_Supplies_ET&hash=item58b2dc4233
    And if my calculations are not wrong .... would 25x156 = 3900 then would be 156 RPM right? too fast for my project .....
  2. bsft
    156 rpm fine. We have that speed about on our motors and with 40mm ctc lever it translates to about 300mm per second linear travel, which rivals SCN.
  3. -kevin-
    128Coins
    Ok for the speed I agree, but the problem is, that my next project will most weight of the upper structure, the engines must also raise the tv / monitor 32 ", in addition to my weight of 83 kg and other things that put. then I do not know if I need a lot of speed to 156 RPM, because it would be detrimental to the couple. many would NM ratio 25: 1 and 156 RPM? calculate it I do not know. Perhaps balancing the weight can be well who make ?
    Those with a ratio of 60: 1 as you can see I'm a bit slow 65RPM run like a windshield wiper, however, are 30 NM. I'm really undecided on this:confused:
  4. bsft
    ok, thats an issue. If you run a shoulder mount, it will be ok, but for sure use 60:1 with 45mm ctc levers.
    I think you are using the K8055, so I am not sure what the actual linear speed of the motors will be.
    I am using calc based on the JRK.
    You can try with 25:1 boxes and if you find the motors do not move it well, then go to 50 or 60:1 boxes.
  5. -kevin-
    128Coins
    I have not! K8055 I used it in the old project 2 DOF, this is a new project and is based on 4 DOF then the interfaces I have yet to decide which one to use ... since the price of JRK and fell from 100,00 € to 73,00 perhaps will opt for this solution, but not so much economic as compared to arduino + moto monster etc.. However, I have yet to properly evaluate the speech of electronics.
    This time I will not use levers linked behind his back to the T, but I will link the levers behind the sedile..metto a drawing as an example:
    for this type of connection which most recommended and 25: 1 or 60: 1? calculating that should raise the + or - 120 kg then obviously that will be balanced!
  6. bsft
    Still too low if you plan a 5-10kg tv on it as well, shoulder mount would be best. and 60:1 with all that weight being moved. I built a sim like that for a friend a while ago, with tv on it, really needed 60:1 to move it properly and shoulder mount. It really struggled with motors mounted lower.
  7. -kevin-
    128Coins
    I do not know if I got it right I'm sorry. So, if I mount levers low as in the drawing, it takes engines with a ratio 25:1.
    If however, I mount levers high behind his back to the engine with better T ratio 60:1?
  8. insanegr
    insanegr !N$@n€
    Athens
    16,725Coins
    it is the opposite from what u saying here. you need 60:1 if you mount them on the base and 25:1 if you mount them near your shoulder
  9. -kevin-
    128Coins
    In fact, it seemed to me strange ... I understood the opposite.
    So the engine 60: 1 are good for me. Thank you
  10. prilad
    Dubna, Russia
    9,663Coins
    3DOF, DC motor, Arduino, 4DOF
    You should understand - the big gear ratio gives more torque and less angular speed. And vice versa.
  11. graz
    graz New Member
    mechanic
    melbourne australia
    - 28Coins
    thanks for the link for those motors, I am new to this but have been doing some research and was going to go with motion dynamics motors but i'll definetly be checking this mob out especially as I am in point cook and looking at their address I could walk ther in 10 mins so a big thanks again for the link
  12. -kevin-
    128Coins
    Ok @prilad lad questo l'ho sapevo. Quello che non capivo e dove andavano montati dietro alle spalle o alla base... grazie
    Grazie @insanegr per avermi chiarito le idee:thumbs
    Ok @prilad lad this I know. What I do not understand where they went and mounted behind the back or at the bottom ... thanks.
    @insanegr Thanks for letting me clear ideas :thumbs
  13. soraz
    soraz Member
    Noale VE, Italia
    5,165Coins
  14. -kevin-
    128Coins
    Ciao @soraz
    Grazie per le info molto utili a chiunque vuole acquistare questi motori ;) io ho abbandonato l'idea e ho continuato con i tergicristallo e fino adesso non mi posso lamentare :thumbs comunque sono riuscito a recuperare 2 motori da un sollevatore di persone però li devo ancora testare.. sò che alzano persone fino a 200 kg come giri del riduttore li ho comparati con i tergicristalli e sono anche più veloci... se tutto và bene li userò come sollevamento e urto visto che hanno una coppia elevata e sono anche più veloci e i tergicristallo li uso per la perdita di aderenza e accellerazione e frenata ;)
    Hello @soraz
    Thanks for the info very helpful to anyone who wants to buy these engines ;) I abandoned the idea and continued with the wiper and so far I can not complain :thumbs anyway I managed to recover 2 engines of a linkage of people, however, will have to yet to test .. I know people who raise up to 200 kg of gear turns as I have compared with the wipers and are also faster ... if all goes well I will use them as lifting and shock as they have high torque and are also more fast and windscreen wipers use them for the loss of grip and acceleration and braking;)
  15. Evan Rowlands
    Evan Rowlands EMR Industries
    Melbourne Australia
    - 82Coins
    motion dynamics $89.00 AUD 61/1 gearbox 100watt 50nm
    or a 200watt version 100nm $189.00AUD
    i have used the 100watt motors and there very powerful moves 200kg with the right COG
