can build 6DOF by using 3 Arduino bord?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by aboodix5, Dec 1, 2013.
  1. berty
    berty Member
    164Coins
    It will take a little bit, because I have long worked with x-sim. But what concrete settings?
  2. RacingMat
    21,040Coins
    first: USO settings
    next: what kind of effects you're using
  3. berty
    berty Member
    164Coins
    This is my USO settings. I do not know what datapacket where I enter, but the platform with 6 servos works well.
    Effects: 1. PITCH
    2. YAW
    3. BANK
    4. VERTICAL VELOCITY
    5. SLIP BALL VALUE
    6. TRUE AIR ACCELER.
  4. eaorobbie
    20,473Coins
    That's about half the information needed, the important ones are totally blank ie the datapacket statements.
    So it receiving a 16bit number on a 8bit output, lol.
    Ok for SimTools with the information provided so far the interface setting needs to be
    ComPort - the port its connected too - COM5
    BitsPerSec - 115200
    Data Bits - 8
    Parity - None
    Stop Bits - 1
    Output - Bit Range - 16
    Output - Type - Binary
    Startup Output - nothing provided ?
    Interface - Output - nothing provided ?
    Shutdown - Output - nothing provided ?
    Axis Assignments well you need to set 6 axis for 6DOF. Plenty of info on site for them.
  5. berty
    berty Member
    164Coins
    So we still need to know: Startup Output, Interface - Output, Shutdown - Output Am I right?
  6. eaorobbie
    20,473Coins
    Yes, even ask original producer he pops in here now and again to gloat and disappears again. At least he say hello.
  7. tronicgr
    tronicgr
    Hmm.... Why are you using USO still? There is plugin for the AMC1280USB... at least for x-sim:
    http://motionsim.blogspot.com/2013/05/6dof-software-plugin-for-x-sim3-is.html
    The plugin autodetects speed/comport/version/number of motors....
    If you want to hack your way to simtools using the AMC1280USB for 6DOF, read here this thread:
    http://www.xsimulator.net/community/threads/my-6dof-reproduction-of-ckas.5359/
    • Dislike Dislike x 1
  8. berty
    berty Member
    164Coins
    Yes I know, my mistake, I had it set to another comport. (on Arduino)
  9. tronicgr
    tronicgr
  10. berty
    berty Member
    164Coins
