Tutorial From AtoZ : 2DOF arduino wiper playseat
Discussion in 'DIY Motion Simulator Projects' started by RacingMat, Aug 8, 2013.
  1. bsft
    Using Mats pic, @treza , do you see what I mean now? Centre of gravity and pivot are two different things. Higher above centre of gravity is ideal, especially if the builder is planning to add screens to it.
    And if you have a better idea, then add to this thread. I have been though 11-12 different designs , mostly building them myself. I know what limits are in design.
  2. bsft
    get OVER it
    • Dislike Dislike x 1
  3. eaorobbie
    20,506Coins
    @treza been through many builds too, motor underneath do not extert the same power as shoulder mounts, built them both, shoulder mounts can handle a greater mass, the higher you move an object above its centre of rotation the easier you can move it, having the motors underneath requires alot more force, the sketch and calc is in correct.
  4. Tech2123
    Tech2123 Tech2123
    Wa. USA
    314Coins
  5. RacingMat
    21,088Coins
    hello Tech2123!
    You're sharing the link of the motors you bought or you're asking for suitability?
    Did you get all the other pieces?
  6. Tech2123
    Tech2123 Tech2123
    Wa. USA
    314Coins
    OOps, I did order these yesterday! ill have em in 2 weeks. The Sim is all done. I had wiper motors installed But 1 of the wipers were defective, so instead of wipers I just waited for the big gear motor.
    I Should be installed and running in 2 weeks or so.
  7. RacingMat
    21,088Coins
    Thanks for sharing your supply link ;)
    Great news! :cool:
    The first time our DIY sim comes to live and moves, is really much fun and pleasure!
    We would enjoy seeing some pics and vid!
  8. 741852cp
    741852cp Member
    china
    106Coins
    2DOF, AC motor
    Hello RacingMat
    My project 2DOF use your firmware, I have a problem?
    Axis1 greater than -90% to -100%, Axis1 motor sport reverse, Axis2 motor stops.
    Axis2 greater than -90% to -100%, Axis2 motor sport reverse, Axis1 motor stops.
    The phenomenon of a person, who has the same?
  9. 741852cp
    741852cp Member
    china
    106Coins
    2DOF, AC motor
    [​IMG] [​IMG]
  10. RacingMat
    21,088Coins
    Hello!
    Congrats for your project!
    Can you load the presets (in Resources section)? To be sure everything is setup (interface...)
    Yours
    Mat
  11. Historiker
    9,212Coins
    Hi 7, I have had that issue when my pots hit the end stop. There is a quick short and my Arduino reverses itself. I cannot see if you have pots connected to the motors though.
  12. 741852cp
    741852cp Member
    china
    106Coins
    2DOF, AC motor
    Replace the potentiometer, the same.
    My bad English
    Ooops
  13. RacingMat
    21,088Coins
    Hi!
    I've sent you a piece of code for testing via PM ;-)
  14. RacingMat
    21,088Coins
    Finally I have setup quickly 2 motors on a Motomonster and I have been able to test by myself (successfully) :)
    I have updated the 2 Arduino firmware with the bug correction
    (<Axis> send 2 Hex Byte for values from 17 to 255
    for values below 16, there was a bug as a single Hex Byte only was sent and incorrectly read.)
    Sorry for inconvenience!
    • Winner Winner x 3
  15. 741852cp
    741852cp Member
    china
    106Coins
    2DOF, AC motor
    Thanks to quick reply, reciprocating phenomenon has disappeared.
    Great knowledge and work. I am a beneficiary
    Thank you:thumbs
    • Friendly Friendly x 2
  16. dualclick
    dualclick
    first of all congratulations for the work, I wanted to know why (SWF VALEO NIDEC ITT 404,458) must be irreversible? What does it mean how do I understand that it is irreversible? thanks in advance sorry for the language are Italian and use google translator
  17. RacingMat
    21,088Coins
    @dualclick If your motors are irreversible then your simulator stays perfectly horizontal when the power supply is cut :)
    That's very convenient and mandatory in my opinion
    but some people cope with reversible motors
  18. frenchfly
    frenchfly Member
    Mold Maker
    Winnipeg, Canada
    - 338Coins
    2DOF, JRK
    I have these motors and they work very good with no need to cut ground wires. Like Mat says it's very nice to have your sim sit still when not in motion.
  19. dualclick
    dualclick
  20. bsft
    mmmm......a lot of people with OCD it seems ;)
