Resolved Assetto Corsa plugin
Discussion in 'SimTools Plugins' started by ericRacer, Nov 15, 2013.
  1. Nick Moxley
    Plugin working fine with RC 1.0 ? ? ? Havent had a chance to check it out yet.
  2. value1
    15,082Coins
    Yep, works fine. I tested it yesterday for ½ hour.
  3. jugnor
    jugnor Jugnor Gold Contributor
    Mechanical designer
    Nantes - FRANCE
    249Coins
    2DOF, SCN5
    Anyone get a good setting and profile for AC? I cant make it work as I wish
    EDIT: I got 2 SCN5 150mm
  4. SilentChill
    20,596Coins
    Yeeehaaaaaa they have just updated the game with the fix for the RIFT !!! They had messed up a file on the steam release apparantly
  5. scalhoun
    scalhoun Active Member
    Software Engineer
    Pennsylvania
    968Coins
  6. SilentChill
    20,596Coins
    Im struggling to get a decent setup on my rig using rufus's code.
    Anyone have a decent setup for a 2dof
    im gonna keep fiddling but cant get it to feel right seems i cant get any proper heave no bumps coming through at all over rumble strips.
  7. SilentChill
    20,596Coins
    Ignore last post just realised there is a new Plugin lol DOH !!
  8. SilentChill
    20,596Coins
    Nope still cant get it setup right just all feels really lazy and I cant get any kinda kicks out of heave it use to kick me in the back when I changed gear and could feel all the rumble strips and bumps in the track there is none of that.
    Anyone any ideas ? I must be doing something wrong im thinking
    I have heave set to 0.5 and still only getting very minimal movement but all still very slow.
  9. scalhoun
    Software Engineer
    Pennsylvania
    968Coins
    I'll send you mine when I get a chance. Are you running jrks?
  10. SilentChill
    20,596Coins
    no monstermotos , cant get it setup i aint had no issues with every other game this is doing my heed in !
  11. SilentChill
    20,596Coins
    Hahahahahahahaha IM A FLIPPING FOOL !!!!!!!
    I had the profile in the game manager on the gaming machine set to 45% !!! ooooooops
    Just tried it and Oh my fu%^n god its the best driving game expierience I have ever had its just unbeleivable !!!!!!
    Driving round Spa with the biggest smile on my face ever wow just frikkin wow !!!
  12. dahfl
    dahfl New Member
    Administrator
    Mülheim Ruhr
    485Coins
    3DOF, DC motor, Arduino, 6DOF
    i used plugin 3.0.5.0 with rc 1.0.6
    in gamedash the gear is one higher as in game. i replaces the value in gamedash but his is not the best solution.
    any ideas ?
  13. Rinus janssens
    Rinus janssens Active Member
    environmental construction
    Holland
    2,153Coins
    SCN5
    Are you allready have a good one and do you want to share it with the rest of the community ?
    Otherwise 'll see what I can do.
  14. dahfl
    dahfl New Member
    Administrator
    Mülheim Ruhr
    485Coins
    now i test rc 1.08 with plugin 3.0.6.0 but the same error:
    • gear is 1 higher as in game
    • no data for shift light, fuel %, car model and trackname
    anyone have ideas ???
    DashApp Data:
    Speed [km/h], RPM, gear, shift light, fuel [lt], fuel [%], car model and track name. Additional values are feasible, yet not implemented.
  15. RacingMat
    21,060Coins
    I'll have a look tonight (last AC version via Steam)
  16. RacingMat
    21,060Coins
    I have the same behaviour: shift is offset +1
    Maybe du to the new version of AC
    Let's ask @value1 if he can fix it?!
  17. value1
    15,082Coins
    Could it be that this was the case from the very beginning? Reverse = 0, neutral = 1, first = 2, etc.?
    I was too lazy to check the proper implementation of the new wchars in the plugin (end of August). So there might be a bug that needs fixing…
  18. value1
    15,082Coins
    I checked the old Assetto Corsa Tech Preview v0.9.9 and already there it was like Reverse = 0, Neutral = 1, First = 2, etc.
    The car model and trackname, etc. will be fixed soon.
  19. Rinus janssens
    Holland
    2,153Coins
    SCN5
  20. nclabs
    196Coins
    Dudes, I think the 1.0 version of Assetto Corsa broken something. I can't use SimTool and not even the Rift. WTF. >_> @value1 can you update the plugin? Thank you very much!
