Arduino UNO/Duemilanove 2dof firmware
Discussion in 'SimTools compatible interfaces' started by prilad, May 29, 2013.
  1. berty
    berty Member
    164Coins
    and in which I engage the pin 6 servos.
    Sorry for my english.
  2. berty
    berty Member
    164Coins
    Hi everyone. When I use the Arduino Nano, which pin do I get involved. For the same as the Arduino UNO ??
    Thank you for your response.
  3. prilad
    Dubna, Russia
    9,657Coins
    3DOF, DC motor, Arduino, 4DOF
    Yes, @berty, Arduino Nano has the same pin names as Arduino Uno.
  4. Alexandre Kostik
    Alexandre Kostik Member
    realtor
    Brasil
    422Coins
  5. prilad
    Dubna, Russia
    9,657Coins
  6. hooshang
    hooshang Active Member
    275Coins
    @prilad
    hi friend,is there any simple DIY solution for isolation(opto.. or galvanic or any...)
    thank you
    Hooshang
  7. Alexandre Kostik
    realtor
    Brasil
    422Coins
  8. Alexandre Kostik
    realtor
    Brasil
    422Coins
    @prilad help me !!!:sos:sos:sos LOL .....I am unable to connect xSimcontrol because accuses the following sentence ... "not enable COM- port . Check COM -port setup" .... go into the setup and click on COM and aprecem doors , being featured in the COM4 ... I click on it and " Error !!! C'ant open port" which appears ... do I hit the setup? thanks
  9. prilad
    Dubna, Russia
    9,657Coins
    @Alexandre Kostik , try to delete file "xSimCtrl.ini" and then run program. It will help to setup COM-port...
    And about signal "sequence" - yes, you can use PWM and IN1 pins from optoisolator as PWM and DIR pins 74ls02
  10. Alexandre Kostik
    realtor
    Brasil
    422Coins
  11. Alexandre Kostik
    realtor
    Brasil
    422Coins
    @prilad !!! ard which code I use ?
  12. prilad
    Dubna, Russia
    9,657Coins
    See topic. You can use any enabled *.hex file. In first try with *57600*
  13. Alexandre Kostik
    realtor
    Brasil
    422Coins
    Ok @prilad !!!
    links would look like ?
  14. prilad
    Dubna, Russia
    9,657Coins
    I'll draw the right schematics tomorrow
  15. Alexandre Kostik
    realtor
    Brasil
    422Coins
  16. michto35
    michto35 Member
    france
    102Coins
  17. Radioproffi
    Lviv
    1,632Coins
    There was a problem - when active use lost connection with arduino. Helps only disconnecting and reconnecting USB port and restart the utility.
    Arduino Uno - Monster Motor Shield - 2 wipers, arduino_uno_by_Ale_v3
  18. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,943Coins
    Hi @prilad ...
    I hope U R doing well my friend ...:thumbs
    pls. have a lock to the attached optical light detector IC datasheet of a regular optical-mouse :grin .
    Can an optical-mouse be used as a motion feedback X or Y sensor with the Arduino ?
    I'll be dedicated for all the hardware and interfacing testing ... All members opinions and experiences are welcomed too :cheers
    With my best Regards ...
    Spe;)edy
  19. Nur
    Nur New Member
    36Coins
    2DOF, 3DOF, Arduino, JRK, 4DOF
    How and where to download firmware?
  20. Nur
    Nur New Member
    36Coins
    Как и куда заливать вашу прошивку? переводчик не так перевел
