JRK 21V 3A motor controller, Concentric LACT12p-12V-20 (110LB) linear actuator, X-Sim
Discussion in 'New users start here - FAQ' started by Deijan5, Mar 12, 2014.
  1. Deijan5
    Deijan5 New Member
    Las Vegas, Nevada, US
    567Coins
    2DOF, JRK
    here is my tuning center. I try the game, still moves very slowly. I'm not sure if I made any changes longtime ago that it might caused this issue.
  2. bsft
    PID is the problem
    get your mouse and highlight the "p" number, back space to delete.
    Try putting in 0.5, the "apply settings"
    go to "d" and do the same with a 0.5, apply settings
    Leave "I" at 0
  3. Deijan5
    Deijan5 New Member
    567Coins
    2DOF, JRK
    Thank you, I did all that and still there is a long delay to respond. I'm not sure if there is bug in the Sim program. It was fine for the first 4 to 6 month. I didn't change anything before our conversation and all of the sudden the actuators not returning to neutral position. Can you help? Thank you
  4. bsft
    can you take and post a screen shot of the interface settings from game engine please
  5. Deijan5
    Deijan5 New Member
    567Coins
    2DOF, JRK
    i this what ypu asked. Please let me know if you need any other information. Thank you,
  6. Deijan5
    Deijan5 New Member
    567Coins
    2DOF, JRK
    I hope these screen shots help. Please let me know if you need any other information. Thank you,
  7. Deijan5
    Deijan5 New Member
    567Coins
    2DOF, JRK
    Hi there,
    I hope all is well. after some modification to the seat, I wanted to start playing the Dirt3. The speed of the movement has been adjusted however I have an issue with the degree of Roll and Pitch. Is there anyway to put a limit for the angle of roll and pitch. For example, the roll should not be more than + or - 6 degree and same as pitch. I'm getting almost +,- 80 degree in movement.
    Thank you,
    153,703Coins
