My 2DOF arcade machine
Discussion in 'DIY Motion Simulator Projects' started by Petar2, Sep 26, 2014.
  1. bsft
    He could probably set the motors to hold still with non motion games.
    I know I can do that with JRKS.
  2. Petar2
    Petar2 Member
    Valencia
    715Coins
    In my almost without configuring anything, these engines are irreversible if not receive voltage, do not move to anywhere, they are hard as a rock and you can sit without fear that the seat is moved.
  3. bsft
    problem solved then.......
  4. siantic
    siantic Member
    616Coins
    So the motors are always working to keep the seat blocked?
  5. siantic
    siantic Member
    616Coins
    ok, very well
  6. Petar2
    Petar2 Member
    Valencia
    715Coins
    I've also thought about safety, before a sudden there will be a push button type mushroom cut current engine when placing games without movement, interrupted current shall also mention mere precaution.
    This is the button, so I put it there to try, but I have yet clear your location.
  7. siantic
    siantic Member
    616Coins
    very good!
    I suppose that you have connect it to the power supply HP DPS-600PB... in the input position o directly to the pins 6, 10, 8 to turn it on?
  8. Petar2
    Petar2 Member
    Valencia
    715Coins
    Directly to the input source
  9. siantic
    siantic Member
    616Coins
    What type of button you've bought?
    How many Volts and Ampere it manages?
  10. Nick Moxley
    17,056Coins
  11. siantic
    siantic Member
    616Coins
    Hi @Nick Moxley, i have a this power supply:
    HP DPS-600PB
    Input: 240V - 50/60Hz - 8.6A(Max)
    Output: 575W(Max) +12V 47A
  12. Nick Moxley
    17,056Coins
    All i did was use the 4-6-8-10 pins.....4 and 8 together and 6 and 10 together to the 3 separate "blocks" on my switch. Each block control's a 4/8 and 6/10 lead which when using a (Normally closed block) works exactly as it should, Button up is power on and kills when you push the button.
    Different PSU's but you should get the idea,
    Multiple blocks and Illuminated, These are aavailable for only Some of the kill switches.
  13. siantic
    siantic Member
    616Coins
    @Nick Moxley so if i connect the switch directly to the pin of the power supply instead of the input of the power supply i can not consider the Ampere of the switch?
    The emergency stop button is a simple NC On-Off switch with 2 pin?
  14. Nick Moxley
    17,056Coins
    Most of these switches are rated at 300-600v so no worries on the power.
    Yes the blocks can either be had in NC or NO. So its up to you how you want it to work.
    here's a link to a Spare block and close look at the switch i got.
    http://www.ebay.com/itm/221397882989?_trksid=p2059210.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    he has other Voltage switches too, I choose 12v for the fact i can run the LED off the PSU when powered On.
    NC or NO blocks
    http://www.ebay.com/itm/321215203765?_trksid=p2059210.m2749.l2649&ssPageName=STRK:MEBIDX:IT
  15. Petar2
    Petar2 Member
    Valencia
    715Coins
    I finally finished the structure and mounted electronics.
    At the moment I am running x-sim because with simtoolls I can not connect to Arduino, I have to put myself calmer and running.
    I leave a video with an underpowered car and a basic profile to test the simulator.
    I believe that I can refine simtoolls movements, and ask for help in the appropriate section if I am not able to make it work.
    And yes, I am a bad driver ...... I promise improvement, although I'm riding pots and disassembly ..... but there is no excuse for not training.;)
  16. bsft
    Looks good man, at least you know it works.
    Whos code are you trying to use for Simtools, did you ask them ?
  17. Petar2
    Petar2 Member
    Valencia
    715Coins
    To set simtoolls I used the firm of Prilad, look at all the information I found on various post fuy not able to make it work.
    For x-sim I'm using the firm of sirnoname, which works with sinaptrix.
    When I tried Prilad, simtoolls me not indicate anything, showed no mistake .....
    I have to put more time and tranquility to reconfigure.
  18. value1
    15,025Coins
    Hi @Petar2
    Possibly a dumb question, but can you see flickering data in Tuning Centre?
    (You can open Tuning Centre in the System Tray
    TuningCentre.jpg )
  19. Petar2
    Petar2 Member
    Valencia
    715Coins
    Well it may seem silly question, it is not much, because I did not look at .....
    Thanks for the hint, I'll look as soon as I put forward the motion.
    Now I'm thinking of using the firm smc3 for arduino, I think with the 10 bits of arduino take advantage, as it will comment that this test has gone.
    A greeting
  20. Petar2
    Petar2 Member
    Valencia
    715Coins
    Due to illness, this was stranded in time.
    Now almost 10 years later, I return to the project, cleaning and reviewing all the electronics and starting again from scratch with software.
    There will be an update soon, now everything is disassembled to assemble and review
