SeatTime's DC motor Sim
Discussion in 'DIY Motion Simulator Projects' started by SeatTime, Dec 28, 2013.
  1. SeatTime
    Busy with the festive season, but have managed to source and hand fit the required main tube, support tube/rail and multi-turn pot. Decided not to use the purchased support rail, as it was heavy and not really needed for an actuator (maybe if I was building a CNC machine). Now to build the frame to support all this and the motor.
    • Like Like x 6
  2. Nick Moxley
    Curious what the Flex coupler is for the on the Far Right with the red bushings.
  3. SeatTime
    That's were the motor will connect.
  4. SeatTime
    Concept drawing below : although the motor will be covered as that is were the base mounting point will be.
  5. SeatTime
    Actuator build continues.
    • Like Like x 6
  6. bsft
    makes more sense to me now
  7. Nick Moxley
    Ah now i see it. Cool beans buddy, Keep it up.
  8. MikeG
    MikeG Member
    Semi retired
    Perth Western Australia
    1,839Coins
    looks god but 1 q if i may.
    If your not using the the rail and bearing what will function as the anti rotation for the nut
  9. SeatTime
    As previously stated I did not use the purchased support rail, as shown in the photo I replaced the heavy solid shaft and support with a steel tube and still used the bearing.
  10. MikeG
    MikeG Member
    Semi retired
    1,839Coins
    dopey me missed that bit :oops:
  11. SeatTime
    Building of the Actuators mechanical parts has basically been competed, I just need to wire up the pot, limit switches and fail-safe relay. If testing goes OK, I will wrap it in alloy sheet.
  12. bsft
    looking good man.
  13. noorbeast
    152,123Coins
    +11,066 / 56 / -2
    Looking forward to seeing it in action @SeatTime.
    Were there any unexpected gottchas in the build or did it fall into place as simply as it looks in the photos? I am guessing keeping everything square and aligned may have been the trickiest part.
  14. SeatTime
    Alignment is certainly key, this although can be simplified by cutting items together in groups (so they are all the same size) and drilling the end plates while they are clamped together (ensures holes for the shafts are aligned). The Ball screw nut bracket was also complex to design. I had purchased a solid steel one which was very heavy, so I decided to built my own light weight version (may try a commercial alloy one in the future) as this is part of the mass being driven by the motor. The design also had to enable parts to be removed if required. I'm also very interested in seeing how it performs in regard to speed/torque.
    • Informative Informative x 3
    152,123Coins
    +11,066 / 56 / -2
    Do post a video when you do get it running @SeatTime, I am sure there are a few of us that will be interested to see it in action.
    Do you have a project parts source list and cost break down? I have a feeling you will get others who want to follow in your footsteps.
  16. bsft
    After the first actuator project has stalled I was doing, and I doubt its going to happen again anytime soon, I , also have been looking at ball screws to make my own as well.
    I can get the alignment fairly well sorted with HDPE plastic blocks as they are cut square, and finer alignments are not that difficult.
    The only hassle I would have is finding a suitable shaft to go over the ball screw, I think I might have to have a shaft off to the side, but driven by the centre screw thingy. Well, it may make it easier for me.
    Still well done @SeatTime , good to see some work coming along, it will work out cheaper than buying one, but still cost a bit.
    My other units were up to $500 for the pair and still not assembled.
    Back to square one again.
  17. SeatTime
    My center shaft is just 25mm Steel conduit and an end coupling (already had some). Hand finished to ensure it runs well in the ball raced front linear bearing, really not that expensive ($18 from EBay - an Australian supplier). The dearest part was the Taiwanese (meant to be better quality) 500mm Ball Screw and end bearing ($160)- Australian supplier. If you got it all from China, you could do it cheaper (just allot longer delivery times). I ended up not using some of the other stuff that I purchased.
  18. SeatTime
    Actuator Test video on Assetto Corsa, - formula car, tarmac, heave only , no sound. Testing looks promising :) - They are not too loud, the G27 force feedback sound you can hear when I go over the ripple strips is louder. Will try and get more up later with other DOFs/load tests, but unfortunately my camera battery went flat:rolleyes:.
    152,123Coins
    +11,066 / 56 / -2
    That is looking really impressive @SeatTime :thumbs
    Have you had a chance to do some initial load testing yet?
  20. SeatTime
    Another video with sway and surge thrown in. Still have to rig up a platform on top of the main shaft for load testing. Although I did try leaning my weight on it using a piece of wood (with my son driving) and it did not fail (that's not a very scientific test though :p).
