Pololu Jrk 12v12
Discussion in 'SimTools compatible interfaces' started by Frakk, Sep 29, 2010.
  1. BartS
    BartS Member
    417Coins
    1 sec = 1000ms milliseconds
    1 sec = 1000000us microseconds
    To corrects BSFT post
  2. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    from my experiment about 1 and half yr ago with my controller, 1ms is necessary for high kP setting to make it smooth. 10ms pause with kp = 25 can cause the motor to oscillate :thbd: .
  3. bsft
    Not that it make too much difference if you are using cheap motors but if you have good motors with no slack, you sure can get better detailed motion curve...
    Oh really ! Lets see you put some motors larger than wipers on yours. THEN you can advise.
  4. bsft
    OK,thanks for that, google is lying to me.
  5. bsft
    Thats where PID comes into play to smooth oscillation.
  6. BartS
    BartS Member
    417Coins
    http://www.google.co.uk/search?q=mi...s=org.mozilla:en-GB:official&client=firefox-a
    I dont think google is lieing to you, its easy to get milliseconds and microseconds confused, abreviated both you would think to be ms however microseconds is represented by a µs to be accurate.
  7. BartS
    BartS Member
    417Coins
    Your motor osscilation is coming down to the resolution of the input, the resolution needs to be tuned to the magnets in the motor and the speed you read the input at. Ideally a half motor rotation needs to equal 1 unit resolution on input that is if you have a 2 magnet motor which should equal exactly 2 units in resolution, if you have four magnet motor 1 full turn should be tuned to a 4 unit resolution on input. This priniple should quite easily eliminate your osscilation problem provided you can convert your input sample fast enough to compare.
    Its best to read input direct from the motor axel rather than the driven gearboxed, reading input from the driven gearbox causes unsettling problems for instance my motors are 25:1 on a 2 magnet motor 25 x 2 = 50 so I need 50 units of resolution to accurately be able to stop and hold the motor in a selected position at its magnets meating points.
    From the above you should be able to see that a comparison gearbox of 60:1 altho maybe slower would be more accurate at holding a certain accurate position.
  8. eaorobbie
    20,480Coins
    well we dont have any issues with the jrk, quiet wrapped with the motion , so how about stop downing the unit and stop hijacking a thread that none of you guys have this unit.
  9. bsft
    Thats right what Eaorobie says, the jrks work just fine. So if you dont own JRKS , then you have no place to bag them. so maybe you should buy them , use them , then comment!
  10. tronicgr
    tronicgr
    All right, sorry for asking then. Well I guess there is no need for something better. I should keep it myself. Its clearly wasting of time since you can't compare a fresh of the shelf commercial product with something DIY... Never mind!
  11. Roadster2
    Roadster2 Member
    1,195Coins
    I haven't invested in either one yet as I'm still contemplating which type of motion system to build. I do however appreciate having a choice and I can see from many of the postings on here that your boards, and help/advice, are very well thought of.
    So, keep up the good work .....
  12. bsft
    Its not a matter of keeping it to yourself, I am just stating that I have NEVER built a tronic card, so I cannot comment on that.
    I believe the tronic card is quite good from what other builders have done.
    The JRK was a simple setup for me, and I am happy to recommend it as I have USED it.
    All I am reading here is information written by people from, as far as I know, have not used a JRK.
    Sure I may have made comments in the past to people whom were trying to build your old 1.5 amc and hbridge and the never ending issues they seem to have. However, I only suggested they buy jrks, and save themselves a headaches, or at least, get their sim going and work on the tronic later.
    If you want to start a t AMC vs JRK thread so we can compare PROPERLY, I suggest you do so.
  13. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    Cool guys..we are here not for fight. long story short. last years i setup my own experiment to test how fast x-sim USO can go in milliseconds when you REALLY need them. here is the screen capture of my test.
    Windows take about 2.09 millisecond to send 8 bit binary signal to controller at 19200 baud-rate. even with pause = 1 ms on USO software. That is the Windows hardware restriction/limitation for uart communication. The more bit you send the longer period it take. In other word you will never ever achieve pure 1ms hardware refresh rate unless you built your own special .dll for your hardware.
  14. bsft
    Nice work there kubing, good to see an actual result.
  15. tronicgr
    tronicgr
    My tests shows completely different story here... In this capture I show the timing of capturing a data frame of AB<16bit_value><16bit_value>
    As you can see there is plenty of time for AMC to receive data, calculate and position the motors within a 1millisecond (1ms) :mug1:
    Here is the capture file that you can analyze in depth with scanalogic software (free) here: http://www.ikalogic.com/ikalogic-products/scanalogic-2/downloads/
    amc uart data capture (scanalogic).zip
    Thanos
  16. kubing
    kubing Member
    kelantan Malaysia
    350Coins
    115kbps obviously faster than 19200kbps.
    the screen shot was taken more than years ago. With AMD Athlon x2 running windows vista 32bit. Long before USB implementation on hardware side. I dont know if my picotech oscilloscope give me a wrong reading but here is my 16bit timing for same baudrate
    Sirnoname suggest me to built my own .dll for my hardware due to windows limitation. But i solve my problem when i use 115kbps to 256000kbps baudrate to comunicate with USB version of my hardware. I push my hardware to calculate PID as fast as 0.2 - 0.4ms. At about 3.00a.m Sunday morning i realize at this speed the controller can run faster than SCN5 if you want. the only limitation is wiper motor itself. I learn something very important that morning. You know what? 1-5ms of delay only can be feel by your body when you have super fast controller to sense that. that why i always use 1ms pause on my hardware. :yes:
    Jrk is good board on the market available today if you want some fun. for accuracy i have no comment.
  17. tronicgr
    tronicgr
    Well, its not only to be able to feel it but to minimize the motor overshooting too... Better refresh rate less chance of overshooting the motor aka smooth transitions in direction changes.
    BTW here is some math to confirm my capture:
    115200 / 8 = 14400 bytes per second ----- 14400 / 1000 = 14.4 bytes per millisecond ( I use only 6bytes per ms having space for more)
    19200 / 8 = 2400 bytes per second ----- 2400 / 1000 = 2.4 bytes per millisecond (For 6bytes you need at least 3ms !!! )
    Thanos
  18. silmar
    silmar New Member
    - 78Coins
    Hooo...this is too confuse, I need to learn more
  19. bsft
    @silmar , you already own an arduino, forget about this thread.
  20. Chumet1
    Chumet1 Member
    - 2Coins
    2DOF, JRK
    I'm waiting until someone has finished.
