Kanuk's first foray into the world of motion simulation...
Discussion in 'DIY Motion Simulator Projects' started by kanuk, Jan 27, 2015.
  1. kanuk
    kanuk If it ain't moving, it ain't simulating...
    Eng
    Melbourne Australia
    2,380Coins
    It has begun!
    And @noorbeast you are so right when you say the project starts simple...and then all the additions come creeping in! You should see what's in my head now! LOL
    This weekend is one of progress.... I have everything in my hot little hands right now bar the moto monster shields.....
    Wish me luck!
    PS. Please don't judge the condition of my garage... that's DSC_0006.JPG what happens when you have just moved and then decide to start a project without unpacking properly! :D
    152,529Coins
    +11,085 / 56 / -2
    :thumbs Keep them photos coming!
  3. kanuk
    Eng
    Melbourne Australia
    2,380Coins
    I have a question...
    What should I use for rods? M12 x 1.75 rose joints do the job? OR should I get sway bar links and extend?
    152,529Coins
    +11,085 / 56 / -2
    M12 x 1.75 rose joints would do fine.
  5. kanuk
    Eng
    Melbourne Australia
    2,380Coins
    Great! I have ordered those and I presume that 12mm threaded steel rod would be perfectly functional yes?
    And the base is now together. The bracing is going on now.... It seems to have no torsion twist whatsoever at the moment, so the bracing is only going to help it along further.....
    152,529Coins
    +11,085 / 56 / -2
    Looking good @kanuk :thumbs
    Most use square box tubing with nuts welded either end for the rods, with some threaded rod either end to connect to the heim joints. Mine are unusual as I created them from solid aluminum round bar, which I tapped either end.
  7. michto35
    michto35 Member
    france
    102Coins
    Beautiful project, mounted with professional materials, it promises a beautiful simulator good luck to you.
  8. kanuk
    Eng
    Melbourne Australia
    2,380Coins
    @michto35 Thank you so much for your kind words sir.... This project is inspired by good people like yourself and the help of some truly stellar forum members. I feel blessed to have such a repository of knowledge from people like @noorbeast @eaorobbie @bsft @RacingMat and all the others.
  9. kanuk
    Eng
    Melbourne Australia
    2,380Coins
    So, here's the completed Uni-joint on the plate....
    Now I'm gonna clean it up for some paint......
  10. kanuk
    Eng
    Melbourne Australia
    2,380Coins
    DSC_0011.JPG And here is the Chair brace.... tested my welding and grinding ability (both of which I am not very good at! LOL) :)
    And also about to be painted.
    152,529Coins
    +11,085 / 56 / -2
    It looks just fine @kanuk, and plenty strong enough!
  12. RacingMat
    21,058Coins
    Looks very good! :thumbs
    You will have to reinforce the motor mounting, it's too weak with a simple L square shape ;)
  13. kanuk
    Eng
    Melbourne Australia
    2,380Coins
    @RacingMat
    Indeed sir! There is a lower half on the inside that's not mounted yet and the motors will be strung together with a reinforcement bar between them.... so yes. they will be sufficiently braced (onehopes anyway!) :D
    152,529Coins
    +11,085 / 56 / -2
    I know my motors are rock solid with my brace bar adding significantly to the rigidity.
  15. kanuk
    Eng
    Melbourne Australia
    2,380Coins
    Oh yes! Question....
    If I were to use pots instead of encoders, would a 10K linear wirewound be ok?
  16. RacingMat
    21,058Coins
    10k linear is fine!
    personnally, I would recommend CERMET pot and I have read that wirewound don't give good measures... but some people have found different information and say that wirewound is as good.
  17. kanuk
    Eng
    Melbourne Australia
    2,380Coins
  18. kanuk
    Eng
    Melbourne Australia
    2,380Coins
    So, my 3 and a half year old walks into the garage this morning and says
    "Dad. What are you doing? Why are you being so noisy?'
    To which I reply, "daddy's working on a project honey..."
    Ava - "What are you doing?'
    Me - "Building a chair honey... "
    To which Ava replies "but we have SO many chairs Dad!"
    Me - "But this one moves honey..."
    Ava - "Dad. So does the one in your office. It's on wheels. If you need it to move, I will push you around while you are sitting on it..." And she said this with the most pragmatic of expressions on her face. I am sure she thinks her Dad had gone nuts! LOL :D
    My princess. My love of my life. All grown up and being a nagging woman..... @ 3 and a half...Sigh.... ;)
    • Funny Funny x 3
  19. kanuk
    Eng
    Melbourne Australia
    2,380Coins
    so.... ctc levers that i've designed. Does it look alright?
    Any advice?
  20. kanuk
    Eng
    Melbourne Australia
    2,380Coins
    Ok.....
    CTC Levers are in process.
    Pivot point is painted and drilled
