A few questions before I start my build
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by getti, Feb 27, 2015.
  1. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    what arduino code are you using and how many MMs ?
  2. getti
    getti Currently building my first 2dof seat mover...
    Canada
    45Coins
    Sorry I'm really new to this and some of the terminology I'm unsure about, what is MMS? Also I know nothing about code.
  3. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    If you are using an arduino then you need to upload a sketch (code) there are a few that have been made by members of the forum
    MM are monster moto shield used to send power to the motors
  4. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,056Coins
    Arduino, 4DOF
    It depends on the power (in amps) you need. But basically a 575W power supply will provide something like 45 amps. This should be enough for a 2 DOF, managed by one MM arduino shield.
  5. getti
    Canada
    45Coins
    Ok, I have no clue how to do that. I'm trying to take it one step at a time so I'll worry about code when I get to that point. Just need to know how many power supplies to order?
  6. value1
    14,242Coins
    The answer is one post above yours:
  7. bsft
    Buy jrks instead
  8. getti
    Canada
    45Coins
    Hello motion guys, I'm back. Had a great summer, did lots of racing and now the snow is about to fly so it's time to get serious about sim racing. I've got all the parts needed for my build and I've been working on some plans which I thought I'd share. Let me know what you think.
  9. bsft
    Looks fine to me, a "go kart" style frame
  10. GIB SimRacing
    GIB SimRacing Active Member
    Barossa Valley, SA
    983Coins
    Yeah looks good. I like it.
  11. getti
    Canada
    45Coins
    Yea I also decided to use a fiberglass kart seat which weighs almost nothing so should hopefully help make this a snappy rig. I'm thinking about shortening the back piece by 6 inches cause the angle of the rods seems a bit much??...
  12. GIB SimRacing
    Barossa Valley, SA
    983Coins
    This is what I built:
    This works well for me and should give you a starting point at the very least.
    I can't really say that I have any issues with this setup.
    • Useful Useful x 2
  13. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,340Coins
    2DOF, Arduino, 4DOF
    @getti , check the height of the wheel in your design, or make it adjustable
  14. getti
    Canada
    45Coins
    Thanks for this!
  15. getti
    Canada
    45Coins
    Yes, wheel height and distance will both be adjustable. It looks like it's high in the sketch but thats just cause its a kart seat. It stops below the armpits, the upper body is above the top of the seat.
  16. getti
    Canada
    45Coins
    I bought this power supply awhile back and I figured get it prepared. I just can't seem to read any voltage when I touch the contacts with my meter. Is there something I need to do to get it to make power? When I plug it in the fan spins but that's it....[​IMG]
    153,920Coins
    +11,156 / 57 / -2
    See here for details on how to mod a HP PSU, it is very simple to do: www.xsimulator.net/community/threads/how-to-modify-a-server-power-supply-for-12v.5774/
  18. GIB SimRacing
    Barossa Valley, SA
    983Coins
    Yes, have a look at the link noorbeast posted above. You have to make a couple of connections between some of the small pins of that power supply.
  19. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    • Useful Useful x 2
  20. getti
    Canada
    45Coins
    Is that 2 connections for the positive and 2 for the negative?... Cause it looks like 4 contacts.
    Also, for the small ones on the middle can anyone tell me which two go together on one side of the switch and which go on the other side of the switch?..
