New Build motion Sim
Discussion in 'DIY Motion Simulator Projects' started by Nath Older, Mar 18, 2014.
  1. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    Just multiply by .621
  2. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    This is the part I think deals with speed and it already has the math to convert it
    the line Vel=round(Vel/1.609); from googling around should be what sets MPH ive tried playing with the line
    but no luck :(
    @prodigy you are correct 100KPH divided by 1.609 is 62MPH:thumbs
    void Display_Velocidad()
    switch(TramaSerie[2])
    case 255:
    module.setDisplayToString("r", 0,0);
    break;
    case 0:
    module.setDisplayToString("N", 0,0);
    break;
    default:
    module.setDisplayToString(String(TramaSerie[2],DEC), 0,0);
    Vel=(TramaSerie[4] << 8)| TramaSerie[3];
    if (SYSTEM==ENGLISH)
    Velocidad=String(Vel,DEC);
    Speed=Velocidad.length();
    switch (Speed)
    case 1: Velocidad2=" "+Velocidad;
    break;
    case 2: Velocidad2=" "+Velocidad;
    break;
    default: Velocidad2=Velocidad;
    break;
    module.setDisplayToString(Velocidad2, 0,5);
    Modo_Hud=0;
  3. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    I tried that to still no joy
  4. Nath Older
    Nath Older Member
    Laboratory Supervisor
    United Kingdom
    271Coins
    Same here, had a quick try, no luck. [​IMG]
  5. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    EDIT:
    I have tested the code myself and read the readme file a bit and found proper solution.
    There is a line at beginning of Arduino code:
    const byte SYSTEM=METRIC; //shows KMH
    change it to
    const byte SYSTEM=ENGLISH; //shows MPH
    And if someone want to displayt his name when starting the dashboard - as some signal sign that dashboard is connected, find this part of Arduino code and add the bolded piece:
    void setup()
    // Inicializar puerto serie a 9600 baudios
    Serial.begin(9600);
    Modo_Hud=-1;
    Mode_Buttons=0;
    Previous_Mode_External=0;
    External_Control=true;
    module.clearDisplay(); //clears the display
    String name = "PrOdIgY"; //sets a start up name
    module.setDisplayToString(name); //prints the name
    delay(3000); //small delay 3.0 sec
    Change my name "prodigy" to whatever you want, but keep in mind that it cannot display diagonal lines, so letter like "R" or "K" would not display nice, experiment with lowercase or uppercase letters like I did.
  6. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    #define METRIC 0
    works a treat thank you
  7. prodigy
    Croatia
    6,698Coins
    I have edit my post above with proper solution which I've found in creators readme file.
    The solution before was working accidentally I guess :)
  8. Nath Older
    Nath Older Member
    United Kingdom
    271Coins
    Thankyou so much
  9. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    @prodigy Thank you for the solution and thank you for the display name its nice to see something displayed on the tm1638 so at least you know the arduino code has worked :cheers
    @Nath Older sorry for the little highjack of your thread but we got there in the end :thumbs
  10. Nath Older
    Nath Older Member
    United Kingdom
    271Coins
    @Daguru Not a problem. It was mainly down to you that I now have a working dash readout. Thanks guys, much appreciated.
  11. Nath Older
    Nath Older Member
    United Kingdom
    271Coins
    So, I finally get my Sim up and running along with a simple dash. Cant believe how good it feels.
    I'd like to thank EVERYONE who has helped me out and made this possible, I rate this forum as one of the very best on the net, great people and a very good easy to use website.
    Here is a quick video i put together, not the best but just a simple one to show you guys my SIM
    i'm sure I will be around alot as I already have some ideas to build myself a sequential gear changer and maybe a more advanced dash, but first I will enjoy what I have :D
    • Winner Winner x 3
    152,571Coins
    +11,087 / 56 / -2
    Great job @Nathan Older and I really appreciate that you took the time to string the build and motion video together...Thunderstruck is perfect!
    Your rig looks and works great, time to enjoy it.
  13. eaorobbie
    20,488Coins
    Shame ya not using GameDash, it works well in all the games listed above and Im slowly but surely adding more content, I do have new code for the Ard but its a hex file from now on. Sorry it has appeared as well as my rc motion code all over the net with no credit coming back to the author so now all code I produce will be hex files , uneditable.
    152,571Coins
    +11,087 / 56 / -2
    It is a shame people take without giving appropriate credit @eaorobbie!
  15. Nath Older
    Nath Older Member
    United Kingdom
    271Coins
    I am looking to use game dash, I just managed to get the other one working straight away, its only a simple dash at the moment but it will grow with more read outs so I will definitely be upgrading to game dash. Thanks for all the comments and help guys
  16. Nath Older
    Nath Older Member
    United Kingdom
    271Coins
    Just thought id stop in and say, WOW i just cant stop playing on this sim!!
  17. Nath Older
    Nath Older Member
    United Kingdom
    271Coins
    Oh, and this weekend i will be looking at upgrading to gamedash.
  18. Nath Older
    Nath Older Member
    United Kingdom
    271Coins
    Hi guys, I have just been setting up my motion sim to work with Race07. I downloaded the game through steam, I have installed the plugins on both computers and have patched the game in my game manager, but for some reason I dont get any movement at all ? The Sim is working fne with rFactor but nothing on Race07. I think I have patched the game from steam correctly, Steam/SteamApps/Common/Race07 . When I start the game up, the game manager says, Game Running and my game engine starts as the "Axis Assignments" and "Interface Settings" are grayed out. But when i race i get no motion. Any ideas ?
  19. bsft
    have you done anything with tuning centre numbers yet?
    152,571Coins
    +11,087 / 56 / -2
    Some pictures of your settings would be really helpful.
