2DOF compact seat mover
Discussion in 'DIY Motion Simulator Projects' started by pipis2015, Mar 14, 2015.
  1. pipis2015
    pipis2015 over-boost
    Athens, GREECE
    10,248Coins
    thanks for taking the time to watch the video.
    Well, since its a seat mover i thought it was better to start with forces (sway and surge) and then move to angles (Pitch or Roll).
    As far as the heave issue, i can well understand what you say about the vertical forces, but i don't feel confident messing with it at the time.
  2. Nick Moxley
    It takes time to Know what your doing and how to adjust particular area's of motion, No worries. You'll get it all figured out in due time.
    153,045Coins
    +11,116 / 56 / -2
    And don't forget we are here to help, so if you are stuck or unsure then post pictures of your settings and a video of your rig moving and members will jump in with advice.
  4. Nick Moxley
    LOL u like that Noorbeast, 2 rating in 1 post. :cheers
    • Funny Funny x 2
  5. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    It moves pretty good, considering wipers and the narrow motor position / rod connections, usually people set motors wider and connect to corners of the seat base. Are you running those wipers at 24V or 12V?
  6. pipis2015
    Athens, GREECE
    10,248Coins
    12volt
    Pwm 215 to 255 depending on distance... the more distance the bigger pwm.
    My weight: 63kg.
  7. pipis2015
    Athens, GREECE
    10,248Coins
    This is a test run @ nordschleife endurance with formula abarth(AC). #2
    DOF used are (picture above explains ratio):
    sway:30%(10% smoothing)
    surge:60%
    roll:15%(10% smoothing)
    pitch:30%(10% smoothing)
    Tuning center settings:
    Roll:10
    Pitch:10
    Heave:1.5 (not used)
    Yaw:180 (not used)
    Sway:2
    Surge:2.5
    As i have already said, tilt is maxed at 3.5 degrees.
    The simulator seems to give quite detailed info of the track and motion while being "comfortable" enough for me to keep me playing for hours.
    One thing has changed ... the whole experience is not a game at all any more.
    • Like Like x 5
  8. Leo Burton
    Leo Burton Active Member
    London, UK
    2,639Coins
    Great work @pipis2015! I have the same Gameracer seat, and I love the fact that you've made it reversible back to static sim if you need it to be! Very well planned build and great documentation! Thanks for sharing!
  9. Nick Moxley
    Why may i ask aren't you running any heave ?
    IMO your missing out BIG time..... the actual Detail in the track, The humps and bumps....I HIGHLY suggest turning it on and using it.
  10. bsft
    Its an ard and wiper sim. Remember Nick we had this brought up before by a member who could not get bumps out of AC, but Pit who runs winches and ard and yo and me who run big motors and JRKS could.
    The wiper motor guy had to get faster motors
    153,045Coins
    +11,116 / 56 / -2
    Likely design would be a factor in how well or otherwise a wiper motor sim could do heave. It is certainly worth turning on and finding out.
  12. pipis2015
    Athens, GREECE
    10,248Coins
    OK, thx all for the nice comments.
    Next test I ll give heave a try to see the result and give you some feedback.
  13. Rocket man
    Rocket man Member
    Canada
    - 325Coins
    I got 2 HP model DPS-600PB power supplies today off eBay for $20 Canadian plus $20 to ship http://www.ebay.ca/itm/Lot-of-2-DPS...805?pt=LH_DefaultDomain_2&hash=item2edefe1bb5. I'm very excited!
  14. Rocket man
    Rocket man Member
    Canada
    - 325Coins
    Going to use one for each 180watt motor I got
  15. jimmytm3
    jimmytm3 Member
    Boilermaker
    macksville, New South Wales Australia
    171Coins
    2DOF, Arduino, JRK
    Hello going to purchase the Arduino Uno R3 and the Pololu Dual VNH5019 motor driver shield for Arduino were did you get the firm ware for this im just trying to do my home work and figger this stuff out
  16. pipis2015
    Athens, GREECE
    10,248Coins
  17. pipis2015
    Athens, GREECE
    10,248Coins
    (took me some time and effort to tune it to my taste...but... i have to say...)
    ...so true...
    i cant thank you (and @noorbeast) enough for insisting to add heave to the setup.
    ...tarmac became so detailed and live...
    ...heave adds a whole new level to the experience...
    thanks again
  18. Nick Moxley
    No problem pipis, glad your enjoying it. Now lets see an updated video. :thumbs
  19. Blame73
    Blame73 Well-Known Member
    8,306Coins
    Heave turns tracks to another level. The smile on my face when it bumps on the finish line at Imola, the straight at Nordschleife, a curb that makes you take off... I love heave
  20. f1iceman
    925Coins
    Very well done like the video and its compact setup you can not fault , you could have one in the office and play a sneaky lap or two and nobody would know :) cool
    lol.
    I want to see and up dated video with heave.
