New Build motion Sim
Discussion in 'DIY Motion Simulator Projects' started by Nath Older, Mar 18, 2014.
  1. Nath Older
    Nath Older Member
    Laboratory Supervisor
    United Kingdom
    271Coins
    From the game manager
      42.9 KB
      729
      50.4 KB
      731
  2. Nath Older
    Nath Older Member
    United Kingdom
    271Coins
    from the game engine
      92.5 KB
      738
      80 KB
      742
      91.4 KB
      716
      61.4 KB
      675
    153,770Coins
    +11,149 / 57 / -2
    I will presume it gets data input in the Tuning Manager, though there is none in the picture you posted, so I am guessing the game was not running.
    Try loading up the game and in the Tuning Manager hit 'Capture Min Max' then 'Reset'. It will zero all the settings.
    Drive a lap or two in something that has a bit of give in the suspension at about 80% normal pace, don't hit anything.
    Go back to the Tuning Manager and hit 'Save New Settings' then press 'Capture Min Max' to turn capture off.
    Fine tune the motion settings from there to suit your sim and personal preferences.
  4. Nath Older
    Nath Older Member
    United Kingdom
    271Coins
    this is taken when the car is sitting in the garage ticking over
      64.7 KB
      681
  5. Nath Older
    Nath Older Member
    United Kingdom
    271Coins
    Looks like following your instructions did the trick well, Thanks so much. Works a treat
    153,770Coins
    +11,149 / 57 / -2
    Now you have motion going you can use the Tuning Manager to tweak the settings. Often things like heave need a more refines setting, and for heave that can often be down to 0.5 or even less.
    You can also uncheck the tick on Surge, which will let you enter different numbers manually for Min and Max. Having a lower Max number than Min helps simulate a snappy gearshift jolt.
    Have fun tweaking.
  7. Nathan Older
    Nathan Older Member
    211Coins
    Been tweaking the sim lately, working great still. but need to improve my dash. If I remember i tried a sim dash but wouldnt get it working right, will give it another try and get the results on here. no doubt will be needing some help from the pro's:)
