Hi there. So interesting forum you got here, that I had to do my own 2 DOF Full frame in stainless
Discussion in 'DIY Motion Simulator Projects' started by Ken50, Mar 29, 2015.
  1. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    That's my intention!
  2. Nick Moxley
    Nuts Meet Mr Belt sander, Lol Exactly what i did at first. :thumbs
  3. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    I have ordered these pots for my rig,any objections? Will it do with the proper gearing?
  4. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    Actually it was a drill bench ;-)
  5. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    I've found these gears on EBay, as you can see it's 15t and 83t,shouldn't that be perfect for a 3 turn potentiometer?There's also some slipper clutch I thought I could use to protect the pot's from over turn?
    153,710Coins
  7. bsft
    continuous single turn pot 360 deg, never breaks from overshoot.
    I used to use the gear method myself with 3 turn pots, until I moved to 360 deg pots.
    No need to use gears, connect the pot on the back of the motor shaft.
  8. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    But did you feel a difference, when you changed?
  9. bsft
    I could not notice a difference even in fine motion.
    Reason I changed is that it costs me $26 for 360 deg pot as opposed to $8 for gears and $35 for 3 turn pot, which could still break if it overshoots far enough.360 deg pot made sense for cost. Performance, negligible.
  10. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    The motors is on the way, and today I've ordered the Pololu 12v12 cards, that should be the last,now I can see the finish line!
  11. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    Hi again, can someone show me a rig using the crap pot motors from EBay with the 25:1 gears?Please? Anyone? I would like to see what to expect, as I am waiting for mine!
  12. bsft
  13. Svensson
    Svensson New Member
    Sweden
    284Coins
    Nice build! I'm wondering what kind of thickness you have on the steel tubes?
  14. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    It's 1.5 mm.
  15. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    Sorry, it's 30x30x1.5 mm,and 25x25x1.5 and the smallest :20x20x1.5 brushed stainless 316 L
  16. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    Might as well be iron tube,makes no difference in stiffness, but, fortunately, stainless is my profession, so that's what is on the material shells!
  17. Svensson
    Svensson New Member
    Sweden
    284Coins
    I see. Just wanted to know the size of the tube you are using. It looks so much better with stainless, good job so far!
  18. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    DSC_0030.JPG Hi again,haven't been in here for a while, went down with the flu! Here's how I connected the mowing chair part to the base,all in alu to keep the weight down.
  19. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    Now,is there a best angel on push/pull rods?I'm mounting the motor brackets!
  20. Ken50
    Ken50 Speedgeek
    Stainless Steel
    Denmark
    340Coins
    I was thinking,wouldn't it be the best to put motor and seatbracket mounting point in line with pivot,look at drawing! DSC_0032.JPG
