News 3dof linear acurator with steper motor 12Nm
Discussion in 'DIY Motion Simulator Projects' started by misoswan, Apr 8, 2015.
  1. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,943Coins
  2. cthiggin
    cthiggin Active Member
    Self-Employed
    Montgomery AL USA
    15,209Coins
    Never give up on your dream, and believe me, at midnight, body hurting, dirty, and looking at the mess I had made, along with some positive accomplishment, - well, at times I just wanted to sit on the floor and cry..........but Never did I give up..........and at this point, even though I'm not at full movement yet, I am having fun in my static sim platform, Buttkicker and all..........and I have forgotten those crying on the floor days.........
    Good luck and many blessings to all.
    Tom
    • Winner Winner x 3
  3. misoswan
    misoswan Active Member
    1,032Coins
    3DOF, Arduino, JRK
    beautiful words give strength to hold on .
    thanks TOM
  4. speedy
    Alexandria , Egypt
    7,943Coins
    Hi @misoswan ...
    How are you doing in the frame work ?
    Have you started on it ? ... Or you are still in the designing phase ?
  5. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    Hi @speedy
    just now I in the phase of collecting, ordering, planning.
    I will keep you posted.
    hopefully everything goes well.
  6. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    Can someone help me. where i can to buy . thanks
    152,523Coins
    +11,085 / 56 / -2
    You could try an Ebay search for steering column universal joints, they are pretty compact and strong.
  8. cthiggin
    Self-Employed
    Montgomery AL USA
    15,209Coins
    Small universal joints in picture - steering knuckles will also work fine. Good prices on Ebay.
  9. speedy
    Alexandria , Egypt
    7,943Coins
    @misoswan ... You may need also to search eBay for a "flange u-joint" ...
    these are ready with flange to be bolt mounted from both sides ... select the 3" flange diameter
  10. speedy
    Alexandria , Egypt
    7,943Coins
  11. misoswan
    1,032Coins
    3DOF, Arduino, JRK
  12. misoswan
    1,032Coins
    3DOF, Arduino, JRK
  13. speedy
    Alexandria , Egypt
    7,943Coins
  14. cthiggin
    Self-Employed
    Montgomery AL USA
    15,209Coins
    Here's what I used (attachments) for Kill Switch (8.00 US eBay)
    Contactor - eBay - about 45.00 US............(attachment)
    The steering knuckle your purchased is fine - for a heavy "platform like mine", big U-Joint the only way.
    FOR SPEEDY - How would you propose to affix the shaft to the Flange Bearing - welding would probably destroy the bearings???? GREAT alternative to a u-joint.
  15. speedy
    Alexandria , Egypt
    7,943Coins
    @cthiggin ... just make a notch/groove to the shaft where to screw the bearing to the shaft with the side screws ... I'm sorry the first pictures didn't have it .
  16. misoswan
    1,032Coins
    3DOF, Arduino, JRK
  17. speedy
    Alexandria , Egypt
    7,943Coins
    Nice @misoswan :thumbs ... SEW Eurodrive Movitrac Type: MC07B005-2B1-4-00 and here is it's manual ... have you checked the input current for it ?
  18. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    just do not tell me I'm the wrong bought......
  19. speedy
    Alexandria , Egypt
    7,943Coins
  20. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    already have a bad day....
