2 DOF SimuKit Build
Discussion in 'Commercial Simulators and Peripherie' started by Leo Burton, Mar 23, 2015.
  1. Leo Burton
    Leo Burton Active Member
    London, UK
    2,639Coins
    Thanks @Nick Moxley
    Ok will give it a go.
    I haven't got around to the tuning min/max settings yet.
  2. Nick Moxley
    what do you mean you haven't gotten around to min/max setting's ?
  3. Leo Burton
    London, UK
    2,639Coins
    In the Fine Tuning Centre. I haven't gotten into that to edit the max/mins after capturing data.
  4. Nick Moxley
    FIY the "captured" min max's might not always translate to quality motion, but again with time you'll realize what does what and can fine tune from there. Out of sheer curiosity what are you min/max's on which games ?
  5. Wanegain
    Wanegain Active Member
    Bruxelles
    2,008Coins
    Min/max is one of the first thing to tune. It's very important! Your profile depends on these values ;)
  6. Leo Burton
    London, UK
    2,639Coins
    So, I moved my Steam install from my SSD drive to my D Drive to make space. All went well, except I can't re-patch Burnout Paradise.
    Dirt 3 and F1 2013 are fine as the patch location is the my documents folder on C drive. Is there a way to delete the patch so I can redirect it to my D drive? The option to 'delete patch' is greyed out. Thanks.
  7. Leo Burton
    London, UK
    2,639Coins
    Sorted it out. Found the cfg file and deleted it. Burnout is backup and running.
  8. Seth2Christ
    Seth2Christ Member
    216Coins
    Good job.
    The tutorial of Wanegain is really well done.
  9. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    Good job!
    Nice idea of the joint self-made!!!
  10. Leo Burton
    London, UK
    2,639Coins
    Thanks @Seth2Christ and @ilbiga
    Yes, @Wanegain's tutorial is super easy to follow for a complete noob like me. It gave me the confidence to dip a toe in the sim world.
    Every step is covered, no welding required. Wanegain supplies the U-joint as part of the kit. Can be built in a day, if you're handy with power tools! It's small enough that is fits in a corner (so its semi-tolerated by girlfriend!)
    Loving this sim more everyday. There goes my social life!
  11. Wanegain
    Bruxelles
    2,008Coins
  12. Leo Burton
    London, UK
    2,639Coins
    So decided to re-enforce the brackets after getting some gear slipping, so I took the brackets to my local car garage, and they very kindly welded me a brace for a tenner.
    I have run the profiles at 100%, and no gear sipping! So I'm very happy now.
    While I took it apart I took the opportunity to paint it, and I made the stupid mistake of choosing gloss paint, (should have gone with a matt/satin finish). It came out terrible, was painting outside and bits of fluff kept landing in it, then it started raining, the primer didn't seem to take so the paint kept absorbing into the edges.
    But it doesn't matter, the important thing is it can run at full power with no slipping now. Theres still a tiny bit of play, but not enough to disengage the pot gears.
    Don't let the pictures fool, it looks a lot worse in person! lol
  13. Paul Shortland
    Paul Shortland Active Member
    Northampton - UK
    317Coins
    2DOF, AC motor
    Nice gold paint job :)
  14. christian
    christian Member
    Germany/München
    967Coins
    2DOF, SCN5, SimforceGT
  15. Leo Burton
    London, UK
    2,639Coins
    Thanks @Paul Shortland
    If something's worth doing, it's worth doing tacky!
  16. Leo Burton
    London, UK
    2,639Coins
    Another good thing about the SimuKit is the footprint. It stores away nicely in a corner.
  17. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    Any chance of a pic or two regarding how your wheel and pedals are attached to the top piece of MDF?
  18. Leo Burton
    London, UK
    2,639Coins
    @Paul Shortland
    I just drilled 4 x 10mm holes in the chair base, after finding the centre of gravity.
    Because of the COG of my full frame choice (I think the simukit was designed to be a seat mover), I needed to adjust the pivot point forward, on the top MDF plate, and move the motors back. Chair Base.JPG IMG_3926.JPG
  19. Leo Burton
    London, UK
    2,639Coins
    IMG_3927.JPG Sorry, I misunderstood.
    The pedals and wheel are part of the GameRacer Elite cockpit.
  20. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    Gotcha, I see how it fixes. Mine will be more home made but nice to see the detail :thumbs
