My 2dof sim in progress
Discussion in 'DIY Motion Simulator Projects' started by alexis67, May 10, 2015.
  1. alexis67
    alexis67 Member
    288Coins
    I wait on my motor monster and then i can do somes test.
    I think a computer power supply will be ok
    Des que je recoit ma motormonster je fait des essais. Je pense qu'une alim de pc devrais suffire
  2. alexis67
    alexis67 Member
    288Coins
    First problem today !
    I have unmount my motor and i have see that i cannot disconnect the ground . What for motor can i buy ? ( i need cheap motor my project need to be discount )
    Premier probleme aujourd'hui !
    J'ai démonter mon motor et vu que je ne peux pas deconnecter le charbon de terre , quel motor je peux acheté ? ( un moteur pas chère le project doit etre low cost )
    153,824Coins
    +11,150 / 57 / -2
  4. alexis67
    alexis67 Member
    288Coins
    153,824Coins
    +11,150 / 57 / -2
  6. alexis67
    alexis67 Member
    288Coins
    Smolka are writted 39€ but i see 80€. Do i have miss everything ?
    153,824Coins
    +11,150 / 57 / -2
    Price change since the original listing @alexis67 :(
  8. alexis67
    alexis67 Member
    288Coins
    Ok then is to much money. What you mean about my ebay link ? Is the motor good ? For the ground ist not a problem i can modify it
    153,824Coins
    +11,150 / 57 / -2
    I am guessing that if you plan to run a 24V motor on a 12V PC PSU, as you plan, then it will likely be slow.
  10. alexis67
    alexis67 Member
    288Coins
    no no , i have a 24v power supply :)
  11. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    i dont think Moto Monster can run with 24V read the specs of MM to be sure before blowing it
  12. alexis67
    alexis67 Member
    288Coins
    • Old Old x 1
  13. alexis67
    alexis67 Member
    288Coins
    I have order the motor. I first try it with 12v when is not good i buy a sabertooth shield.
    Yesterday i have build the base and put the moving part on it.
    J'ai commander le moteue 24v jessayerai en 12v et si c'est mauvais je prendrais une sabertooth pour passer en 24v
    Jai fabriquer la base du chassis et monter la partie mobile dessus
    base :
    braking max angle :
    steering angle ( not reel )
    153,824Coins
    +11,150 / 57 / -2
    Nice work there @alexis67.
    With a CV joint if there is any unwanted lateral twist you can add a control bar between the top and bottom frame.
  15. francky foor
    francky foor Member
    france (nord)
    347Coins
    2DOF, SCN6
    its moving fast
    sa avance vite
  16. alexis67
    alexis67 Member
    288Coins
    Yes its fast. But i need somes days waiting on my motor.
    In this time i can add my handbrake and rubber buffer on the floor.
    Oui rapide mais la je doit attendre mes moteurs. En attendant je vais mettre mon frein a main et des patin caoutchou pour la liaison au sol
  17. francky foor
    francky foor Member
    france (nord)
    347Coins
    2DOF, SCN6
    frein a main fait maison ?
    handbrake homemade?
  18. alexis67
    alexis67 Member
    288Coins
    oui je récupère celui de mon ancien seat
    yes i take it from my old seat
  19. francky foor
    francky foor Member
    france (nord)
    347Coins
    2DOF, SCN6
    s'est un manche de brouette ; belle invention tu ma l'air bon bricoleur
    has a wheelbarrow handle; the wonderful invention you my good handyman air
  20. alexis67
    alexis67 Member
    288Coins
    Non c'est une poignée d'une machine agricole :).
    Je travail dans la maintenance industrielle et bricole depuis tout petit sa aide.
