First attempt at a 2DOF motion sim
Discussion in 'DIY Motion Simulator Projects' started by SilentChill, Jul 24, 2014.
  1. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    I think I need to think about traction loss for my sim after watching that video....... :D
  2. SilentChill
    20,601Coins
    Another update video with the fans working as they should :) Sorry about the noise but I cant hear the im the rift and my headphones on :D
  3. francky foor
    francky foor Member
    france (nord)
    347Coins
    2DOF, SCN6
  4. Archie
    Wollongong, NSW, AU
    3,797Coins
    "I feel like a midget though..." Brilliant :D
  5. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,948Coins
    Thanks @RaceRay for making this thread sticky ... just to give this smart guy a Big Thank You .
  6. francky foor
    francky foor Member
    france (nord)
    347Coins
    2DOF, SCN6
    the Wind :think:sos
  7. dmk90
    dmk90 New Member
    Brisbane, Australia
    258Coins
    Hey mate, great thread! .. love your traction loss setup. I'm definitely going to be doing the same.
    Got some questions for you.
    1. How heavy do you reckon your current rig is?
    2. How many moto monsters are you using? .. 1 per motor?
  8. SilentChill
    20,601Coins
    I use 1 MM per motor so I have 3 in total. And it is heavy lol I have no idea of actual weight.
  9. nachofly
    nachofly New Member
    274Coins
    thanx a lot Craig, im gonna use this as a guide line to build my own....i cheked all the items you bought on ebay...but im not sure how did you set them up, i guess im gonna had to use my imagination...and more reading...best regards
  10. SilentChill
    20,601Coins
    @nachofly Welcome !
    Yes you need to do lots of reading of the forums, also don't forget the FAQ section lots of good information there too.
    Good luck with your build :)
  11. SilentChill
    20,601Coins
    PIKES PEAK DIRT RALLY :)
  12. SilentChill
    20,601Coins
    RIP my little one time for an upgrade and i'm afraid I need your motors. Its been emotional
    New topic to follow once I finish the sketchup, which I can say has been an experience in itself to learn how to use but I got it hooked up to SimTools and everything working.
  13. noorbeast
    153,818Coins
    +11,150 / 57 / -2
  14. nachofly
    nachofly New Member
    274Coins
    +1 here, still having a hard time to fin the proper DC motors...want something powerful... but i could only fin 1200 US per piece...which is off my budget.....ive been following all your videos and post man...are you sharing that sketch????
  15. nachofly
    nachofly New Member
    274Coins
    this might be a good option???
    i cant post links cause im a nooooob....
    here are the specs
    NEW MILITARY SURPLUS UNIT
    Motor with Manual Brake OR 24VDC ELECTRIC BRAKE
    0.67HP / 7000 RPM AT FULL LOAD
    24VDC / 39AMPS AT FULL LOAD
    NSN: 6105-01-241-4944
    LAB TEST:
    INPUT VOLTAGE: 6VDC....4500 RPM @ 7.5AMPS NO LOAD
    12VDC....10,500 RPM @ 8.5 AMPS NO LOAD
    24VDC....18,000 RPM @ 11 AMPS NO LOAD
    Duty Intermittent: 1 min. @ full load / Followed by 3 min. rest
    ALSO CAN OPERATE CONTINUOUS AT LIGHTER LOADS
    This unit was made for the US military…very high quality..cost was several thousand dollars each
    Motor Dimensional Specs
    Motor Length – 7 ¾”
    Motor Width w/ Side Connector – 5”
    NEMA 34 Mount
    Shaft Dia. - .4800”
    Shaft Length - .905”
    Motor Has a Pinon Shaft with 13 teeth
    WEIGHT: 8.25 LBS
    COMES WITH WIRING DATA
    i also saw that you like airplanes, are you pilot??...
  16. SilentChill
    20,601Coins
    @noorbeast The motors I have have a label on saying 125w 13.5 amps 100rpm however I think they are much more than that. I have 13cm arms on them at the moment and I have had a clamp meter on they are pulling more than 30-40amps . Even with hours of use they don't get hot they are just warm. I have no idea why they are labelled so low I'm sure they'd pull 60-70amps if I had the power supply and mm's to try. I can't even turn the power in scn to the top as they cut the psu's cut out all the time I think it is only set at 180 at the moment. I have new 65amp psu's for the new build and also 2 xmm's per motor.
    They are big motors so I think they will easily cope with the platform weight that I will make.
    All will be revealed soon. :D
  17. SilentChill
    20,601Coins
    @nachofly What gearbox are on those motors. The specs look good but I'm not an expert at all I just try stuff and if it works it works.
    I'm not a pilot no lol. Wish I was, I do like casual flight simming but not too serious.
  18. nachofly
    nachofly New Member
    274Coins
    i also saw that you like airplanes, are you pilot??...man i wish i could up load the pictures or even give you the link...
    i uploaded a pic of it.
    im not an expert either as you can see...pretty much obvious... but i dont think this items have a gear in it.
    i found a good source of info for a 6DOF... ill post it tomorrow, its 4:20 AM here and i gotta work tomorrow... so yeah.... nite nite for me.
    153,818Coins
    +11,150 / 57 / -2
    The performance does indeed suggest the stated specs are way off. Are they easy to come by, as many European members are looking for suitable motors?
  20. SilentChill
    20,601Coins
    They are Italian make and they are not cheap, but I take them out of dead bits of machinery at work so guess I'm little lucky. Although been hard to come by as of late.
    http://www.transtecno.com/en-en/.
