Showroom DX - Compact Simulator
Discussion in 'DIY Motion Simulator Projects' started by noorbeast, Sep 29, 2014.
  1. noorbeast
    153,001Coins
    +11,116 / 56 / -2
    Nice idea @Martin van Hagen.
    I am just planning to pull it apart yet again and do some additional wiring, some upgrade and maintenance jobs and add some more braided wiring covering secured with billet clamps.
  2. Leo Burton
    Leo Burton Active Member
    London, UK
    2,639Coins
    @noorbeast Did you ever modify your Kor-FX vest? Putting the transducers into your seat harness? Sounds like a good idea.
    I also backed it on Kickstarter, and I've got to say, I love it! Its changed gaming for me.
    I mostly use it for Battlefield and COD, but I love it for driving games as well.
    Having said that, its going back in for repair because the wiring is loose inside it. Keeps switching off and on when I lean forward.
    153,001Coins
    +11,116 / 56 / -2
    I am using the Kor-Fx for testing, I am actually looking at Dayton puck transducers for the final harness. The Kor-FX is OK for the test but what I want is to program the tactile effects as you do with SimVibe and I am looking forward to SimTools directly supporting bass shakers, which @yobuddy is working on.
    I will pull the sim apart again starting next Tuesday, and part of that is adding the upper speaker rail with harness guides, so will post some further pictures and info once I get it done.
  4. alexis67
    alexis67 Member
    288Coins
    awesome construction ! very very good
  5. Seth2Christ
    Seth2Christ Member
    216Coins
    Nice job. It's clean and design
    153,001Coins
    +11,116 / 56 / -2
    Thanks @Seth2Christ.
    I just pulled it apart today to do a bunch of improvements, so will post some updates soon.
  7. MasterYoda
    MasterYoda Active Member Gold Contributor
    Portland/USA
    322Coins
    2DOF, SCN5
    That's it the flight config I always wanted... I would keep it for flight and make a SCN based rig for racing! Gr8 job!
  8. bsft
    Or use DC motors and JRKS for the racing rig
    153,001Coins
    +11,116 / 56 / -2
    Thanks @MasterYoda.
    My sim was actually built for experimentation rather than for flight or racing, but it actually handles both pretty well, particularly in VR, as it is specifically being developed to explore the possibilities of motion and VR. Hence why it is so configurable, to test various ideas and scenarios. It can easily convert between full frame and seat shaker modes. I can have all the Clubsport and Warthog HOTAS controls mounted at the same time if I want and just swap out the pedals, or I can use the quick release control mounts to swap between race and flight modes, with the center mount joystick pivoting out of the way to make getting in and out easy.
    My rig is still under development and at some stage I will add things like traction control. At the moment the current upgrades I am working on are around serviceability, useability, sound and haptics.
    153,001Coins
    +11,116 / 56 / -2
    My compact sim is back in bits again for some upgrades.
    I have shortened the motor lever arms, so I don't have to worry about catching my ankles on them. I would never have used the additional 60 CTC holes so have just left the 40 and 50mm CTC options. I have also swapped out the dainty but pretty hard rubber feet for some really big ones that are way more flexible, seen toward the bottom left of the picture, to better isolate the rig while I am experimenting with haptics.
    To improve serviceability I have made up this slide out tray to mount the JRKs, as they live under a fan which is embedded into the frame, so are impossible to get to without pulling the sim apart. I made up some perspex runners for the tray and plan on using a magnetic clasp to lock it in place. The 8KG magnetic lock I got is actually too much, so I will probably end up using a 2KG one instead.
    I still need to add the new fuse box, rout the wiring through the back of the tray, add the new wiring connector blocks and put the JRK heatsinks back on, then do a bunch of wiring to the new control box.
    Unfortunately I also managed to accidentally break off a very small chip on one JRK board when removing the old wire block, which I am replacing with bigger wire connecting blocks. :(
    I have another dead JRK, so perhaps I can steal the chip off that and re-solder it to this one, nothing to lose in trying.
    This is the start of the new control box, which will also mount the HOTAS joystick in front of it. The kill switch and audio controls for sound and haptics are mounted. The hole is for the inbuilt Nexus 7 tablet, which will act as the computer screen when using the Rift without needing to run the ultra short throw projector, and for a bunch of apps that provide in game controls. I still need to add JRK monitoring LEDs and reset switches, using @Archie's brilliant idea.
    The control box will eventually be mounted with a quick release to allow it to conveniently pivot to the right, to maintain easy access getting in and out of the sim when the rig is in full frame mode and the joystick is mounted HOTAS style.
    I will add more upgrade details as they progress over the next few weeks.
  11. SeatTime
    Modding, it never ends:). Just a question on looking at your pictures, do you have heatsinks on your JRKs - cannot really tell - I'm sure you use to have them fitted?
  12. Boomslangnz
    4,172Coins
    Bugger about the broken chip on the JRK man but hopefully your upgrades go well! Good thinking too to try isolate any vibration with the rubber feet
  13. noorbeast
    153,001Coins
    +11,116 / 56 / -2
    Yes @SeatTime I have heatsinks for the JRKs, but they are off while I am making the new sliding tray, as it is a really tight fit and I didn't want to catch one on the frame while testing the fit by sliding the new tray in and out. The heatsinks will go back on once all the new wiring is in place.
  14. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    As always, superb craftsmanship @noorbeast I always enjoy looking at your updates as you tinker and plan.
  15. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
    Great work! Ich warte nicht , um die Arbeit an meinem Projekt unter Inspiration ! :)
  16. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,944Coins
    Thanks @RaceRay for making this thread sticky ... just to give this smart guy a Big Thank You :cheers.
    153,001Coins
    +11,116 / 56 / -2
    Thanks @speedy and @RaceRay, the community recognition is very much appreciated.
  18. speedy
    Alexandria , Egypt
    7,944Coins
  19. thechemist
    thechemist New Member
    East Coast
    566Coins
    A well deserved build and thread, congrats.
  20. francky foor
    francky foor Member
    france (nord)
    347Coins
    2DOF, SCN6
    bravo very good!!!
